Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Talk About Photography
Reply
Thread Tools Display Modes
Old 19th of August 2010 (Thu)   #1
LM7
Default Canon EF 70-200mm f/4 USM L & Tripod Collar Mount.
Hello!
Searching for advice, knowledge with Canon EF 70-200mm f/4 USM L.
Looking to buy this lens for nature-stills. Would it work without Tripod Collar just mounting the camera, or the Tripod Collar is necessary?
I'll appreciate your advice!
Leon
LM7 is offline   Reply With Quote
Old 19th of August 2010 (Thu)   #2
raiyo
Default Re: Canon EF 70-200mm f/4 USM L & Tripod Collar Mount.
for the weight of f/4 u dont need a tripod collar. search and you'll find more of these post.
raiyo is offline   Reply With Quote
Old 19th of August 2010 (Thu)   #3
CJM Photography
User is banned from forums
It isn't necessary but It sure is much more convenient, I have one that I bought from amazon for $12
CJM Photography is offline   Reply With Quote
Old 21st of August 2010 (Sat)   #4
LM7
Thanks for replies!
I guess Canon does not include a Tripod Collar with the lens for a reason. But there is the place on the lens for a tripod collar.
I'll be using this lens to capture far objects mostly 105mm - 200mm. And I do have a steady Manfrotto set for the purpose.
I wanted to know what people get shooting at 100-200mm. This is not IS version so I would guess it would be better to balance the gear.
I didn't know I can buy the Mount for $12. Thanks, I'll read more about it.
Leon
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Has anyone used the "Cowboystudio Tripod Collar Mount Ring for the Canon EF 70-200mm" thegfxman Accessories & Storage 23 25th of October 2010 (Mon) 22:44
Canon 70 - 200mm F4L tripod mounting collar Raindancer Accessories & Storage 13 13th of March 2006 (Mon) 01:14
