Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Talk About Photography > General Photography Talk
Reply
Thread Tools Display Modes
Old 23rd of August 2010 (Mon)   #1
Gadabout
Default obnoxious white balance, help?
So recently in all the photo's I've been taking that have been out in the sun, the white balance makes them all way way orange/etc. I have it set to auto white balance and I've only gone through a few of the default white balances but I've never set a custom one.
So how exactly do I set one if I'm out on the streets and do NOT have a grey card? Do I just keep playing with it, shoot more to the right? for colder white balance and vice versa for warmer?
Gadabout is offline   Reply With Quote
Old 23rd of August 2010 (Mon)   #2
SkipD
SkipD's Avatar
Default Re: obnoxious white balance, help?
Simply shoot in RAW and worry about the white balance in post-processing (during the RAW conversion step).
You can probably find something that is white in one of the images out of several done in the same light. Click on that with the eyedropper white balance tool in post-processing software and then transfer the numbers acquired that way to the rest of the series.
Skip Douglas
A few cameras and over 45 years behind them .....
SkipD is offline   Reply With Quote
Old 23rd of August 2010 (Mon)   #3
tracknut
tracknut's Avatar
The card does not have to be gray specifically, it needs to be neutral, from grays to white. So a white piece of paper will work. Presumably that could be easier to find.
That is, in addition to the raw/pp method Skip suggests.
Dave
Performance/sport dog photographer
"Always available to shoot your dog"
tracknut is offline   Reply With Quote
Old 23rd of August 2010 (Mon)   #4
zerovision
zerovision's Avatar
pp is always a good way to adjust for the right white balance, but if you don't use a grey card for the first shot of each location, then you may still be unhappy with the results.
You can always shoot Kelvin mode "K". Look at the different presets in you WB such as direct sunlight, shade, cloudy, etc. Each should show Kelvin temperature as you scroll through each icon. Use that temperature as a starting point based on what you are looking for. If it is still too worm then dial the Kelvin temperature down until you get the results you are looking for. You may still have to tweak it in pp.
You can also spend the money and get an expo disc for each of your lenses, but they run $99 each. Then you can do a custom WB anytime anywhere.
zerovision is offline   Reply With Quote
Old 23rd of August 2010 (Mon)   #5
PhotosGuy
Moderator
PhotosGuy's Avatar
Some people swear that AWB is OK outdoors. I'm not one of them, & AWB really sucks under artificial light. I ran a test indoors & have never used it since. Notice that the very last exposure in the 2nd image of tests was of a gray card, & it's way off.
http://photography-on-the.net/forum/...ad.php?t=54281
If you shoot white paper ON THE METER READING, it will photograph gray, just what the cam needs for Custom WB. Use that exposure for the WB set-up.
It's pretty good for adjusting exposure too, when there are bright highlights that aren't important in the frame.
What’s best for exposure, Gray cards, white paper, expensive attachments for the lens?
Gray Card…White Paper. What’s best?
www.FrankCizek.com
PhotosGuy is offline   Reply With Quote
Old 25th of August 2010 (Wed)   #6
Wilt
Wilt's Avatar
Beware of using just any old white paper to set WB !!!
Keep POTN alive and well with member support http://photography-on-the.net/forum/donate.php
Wilt is offline   Reply With Quote
Old 26th of August 2010 (Thu)   #7
zerovision
zerovision's Avatar
I like the x-rite color checker passport. Check out their website. I works great for adjusting for skin color.
Old 26th of August 2010 (Thu)   #8
JWright
JWright's Avatar
What camera are you using?
If it's one that has the capability of white balance shift and bracketing, I'd check to make sure you haven't accidentally changed those settings.
John
JWright is offline   Reply With Quote
Old 31st of August 2010 (Tue)   #9
mistat0m
I just go with RAW and fix the WB in post. I'm too lazy to try to get it right for jpegs.
mistat0m is offline   Reply With Quote
Old 1st of September 2010 (Wed)   #10
neilwood32
neilwood32's Avatar
I always use RAW for the ability to adjust WB after the event. Not simply because the camera might have missed the correct setting but also because I occasionally like to use a different one to alter the tone of an image.
Having a camera makes you no more a photographer than having a hammer and some nails makes you a carpenter - Claude Adams
Keep calm and carry a camera!
neilwood32 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
CBL Color and White Balance Lens vs ExpoDisc Digital White Balance Planet2010 Accessories & Storage 4 22nd of June 2010 (Tue) 19:21
What white balance mode for when you're SETTING a custom white balance? Laramie Canon EOS Digital Cameras 25 6th of March 2009 (Fri) 11:15
White Balance for Canon 50D, and does flash effect balance? TheShooterMan Canon EOS Digital Cameras 8 25th of December 2008 (Thu) 20:55
To white balance or not to white balance? That is the question? Obtong RAW, Post Processing and Printing 14 16th of December 2008 (Tue) 02:34
Differences between white balance 1 and white balance 2 satnitefever Canon G-series Digital Cameras 1 27th of April 2003 (Sun) 18:26
