Thread started 25 Aug 2010 (Wednesday) 23:43
Which settings for sharpening in LR?
Els
Aug 25, 2010 23:43 |  #1
Which settings do you use under Amount, Radius and Detail in the sharpening tool in LR?
1) for print
2) for web/slideshows
Thanks in advance!
Els
5DII | 135L
PixelMagic
Aug 26, 2010 00:06 |  #2
You might want to read this article carefully. It was written for Lightroom 1.1 but the principles are still the same: http://lightroom-news.com …oom-11-update/sharpening/ (external link)
tonylong
...winded
Gallery: 60 photos
Aug 26, 2010 00:21 |  #3
Amount differs with subject, ISO/noise level and personal taste. For low ISO shots that are landscape/scenic/high detail shots I'm fairly generous with my amount, say at 90-100.
Radius I honestly never mess with, never delved into it.
Detail is pretty dramatic with LR3 -- use with care, but it could make certain things really "pop" (or it can make an image look like trash if you overdo it).
I use Masking a fair amount with high ISO images with a lot of noise, to smooth out noise/lower sharpening in areas of smooth tones and colors like a blue sky or whatnot.
Tony
tonylong
...winded
Gallery: 60 photos
Aug 26, 2010 00:22 |  #4
I would also carefully read the LR3 Help for the Details panel, and also check out the brush adjustment for sharpening/smoothing.
Tony
Els
Aug 26, 2010 01:04 as a reply to  @ tonylong's post |  #5
Thanks to both of you! I will do more reading in the help info in LR (I already am reading, but not up to the sharpening section yet). You are right that it varies depending on the type of image, and I definitely want to learn how to apply the masking and adjustment brush for sharpening certain parts of an image.
And thank you for the article, PixelMagic!
So much to read/learn!
Els
5DII | 135L
FlyingPhotog
Cream of the "Prop"
Aug 26, 2010 01:17 |  #6
It also depends on your final output...
You'll usually want to apply slightly more aggressive sharpening to images for print than you will for electronic viewing. This helps offset the tendency of the ink to "spread" on a print.
Jay
Els
Aug 26, 2010 01:43 |  #7
FlyingPhotog wrote in post #10790257 (external link)
Interesting, thank you!
Els
5DII | 135L
1,348 views & 0 likes for this thread
version 2.0 /
Latest registered member is Lausti
736 guests, 412 members online
