Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Canon EOS Digital Cameras
Reply
Thread Tools Display Modes
Old 17th of August 2005 (Wed)   #1
Photojournaliste
Default Firewire port issues - 1DsMarkII
Well this is my first post on this forum, so here goes...
I'm having a small issue with the 1DsMarkII and was wondering if anyone out here could help me out... I thought I'd throw this one out here, although I doubt I'll find what I'm looking for.
At the studio where I work, we shoot directly from camera to computer (thus avoiding all the storage issues on CF card, and we can see the results immediately in Phase One). With the 1DsMarkII we have the chance of being able to plug in a firewire connection to the camera, it's absolutely awesome (compared to a USB download).
Although we do most shots on tripod, I tend to like to do my "beauty/model" shots handheld - force of habbit I guess - only thing is that the firewire port on the camera has jiggled so much we already had to fix it once.
Does anyone know of a contraption to lock-in the firewire/USB/video/whatever connectors into the camera so they don't jiggle and damage the ports?
If you want to answer that I should buy the wireless system camera-to-computer: 1) it's not available in China (we're thinking of buying it on our next trip in Japan in September), 2) although fast it has only one channel and we have 8 shooting areas in our studios.
Philippe Roy
Freelance photographer and journalist
www.photojournaliste.ca
Shanghai, China
Photojournaliste is offline   Reply With Quote
Old 17th of August 2005 (Wed)   #2
malcolmx
Default Re: Firewire port issues - 1DsMarkII
There is no locking device that i have ever seen in the uk but you can get flexible crocodile holders that you could tape to the tripod and use the clip to hold the cable close to the port
might work?
MALCOLM
___________________________________
LRPS EOS IDSMK2 +BITS
malcolmx is offline   Reply With Quote
Old 17th of August 2005 (Wed)   #3
HKFEVER
HKFEVER's Avatar
I have the same problem, the fire wire plug port is not tight or strong enough for daily use. And I am afraid I will break it within the first session.
HKFEVER is offline   Reply With Quote
Old 17th of August 2005 (Wed)   #4
Camo 757
You have to go wireless, that really is the only solution for "tethering"
60D gripped/Tamron 17-50 VC 2.8/Tamron 60mm Macro 2.8/Canon 70-300mm IS
Camo 757 is offline   Reply With Quote
Old 18th of August 2005 (Thu)   #5
Photojournaliste
Thanks guys!!
I actually found (on another forum) a kinda viable solution til we get the wireless system:
I found this on Kodak, the clamp would work when off the tripod.
QUOTE
Use the Cable Clamp Assembly to secure your FireWire cable to your camera. The Cable Clamp Assembly consists of the Cable Clamp Bracket (Part No. 4E2751) and a Cable Clamp Knob (Part No. 4E2752) which must be ordered separately.
Use the cable clamp assembly to:
Provide strain relief to the DCS IEEE Cable when the camera is handheld.
Improve FireWire connection reliability.
Prevent damage to the FireWire connector.
The cable clamp assembly can be installed to allow left- or right-side exit of the DCS Pro Back IEEE Right-Angle Cable.
Philippe Roy
Shanghai, China
Old 18th of August 2005 (Thu)   #6
HKFEVER
HKFEVER's Avatar
Any picture or links that show how it works?
And I need to found a right angle fire wire cable.
Old 18th of August 2005 (Thu)   #7
KennyG
KennyG's Avatar
I know a studio that uses flash extension brackets and simply tie-wrap the cable to them.
Ken
Professional Motorsport Photographer
2 x 1D MK-II, 7D, 17-40L, 24-70L, 70-200 2.8L IS, 100-400L,
300 2.8L IS, 500 4.0L IS, 85 1.8, 50 1.4, 1.4 & 2.0 MK-II TC.
KennyG is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1DMk2 Firewire port - have there been any field failures? Lightstream Canon EOS Digital Cameras 5 22nd of July 2007 (Sun) 09:01
1DSMarkII N will be out in Feb 2006? RaymondCheung Canon EOS Digital Cameras 3 20th of October 2005 (Thu) 05:56
1DS mk2 - BAD FIREWIRE PORT? iannnn Canon EOS Digital Cameras 2 14th of June 2005 (Tue) 07:28
1DSmk2 - dodgy firewire port?? iannnn Canon EOS Digital Cameras 2 9th of May 2005 (Mon) 11:28
Canon 300D & Firewire port Sherman Canon EOS Digital Cameras 1 4th of November 2003 (Tue) 06:21
