Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Canon EOS Digital Cameras
Reply
Thread Tools Display Modes
Old 19th of August 2005 (Fri)   #1
ShutteringFocus
Default 550EX not working correctly on D30
I cannot push any buttons on my 550EX when it is connected to my D30. I have tried everything I can think of.
The only thing I can do is push the back light and make the screen light up green. I cant change any settings or fire a test flash.
If I pull the flash back in the shoe just a little bit so that the connection is lost, then I can push the buttons and change the settings. But when its connected to the camera, I cannot change anything.
I've also had some trouble where the flash continually fires over and over when connected to the camera.
Any ideas about what might be going on here...and/or how I could get it fixed?
ShutteringFocus is offline   Reply With Quote
Old 19th of August 2005 (Fri)   #2
ShutteringFocus
Default Re: 550EX not working correctly on D30
I had a thought, is there any way to do a reset on the flash. I was having trouble with my iPod once and I called in to apple and they told me this button combination to push which reset the whole iPod. Can I do that with the flash at all?
(only problem is I dont think the flahs is my problem...I think my hot-shoe might be crapped)
Old 19th of August 2005 (Fri)   #3
ShutteringFocus
Its the camera...because now the flash wont fire...and also my built in flash (when used without the 550 of course) will not fire and I get error 80 which is the error that says the flash will not recharge after the first TTL fire.
So something about the flashes on my camera is messed up.
^%$&(*^&^) .... Maybe its time for that upgrade?
Old 19th of August 2005 (Fri)   #4
robertwgross
robertwgross's Avatar
Look on the bright side. You've always had envy of the newer Canon cameras. Even though the old D30 has been your favorite, maybe it is time to move on. Take the lessons that you've learned from it and move up a step.
You could probably get the D30 repaired. However, the repair cost would be a major portion of the overall value of the thing. The cost might even be more than what it is worth.
Or, get a new camera coming and then send the old D30 in for repair. Once it comes back, you can use it as a backup camera.
I'll tell you, when you walk into a wedding shoot with two or three cameras slung around your neck, the other photographers will get out of your way.
---Bob Gross---
robertwgross is offline   Reply With Quote
Old 19th of August 2005 (Fri)   #5
DAMphyne
"the more I post, the less accurate..."
DAMphyne's Avatar
Have you ever used that camera with another flash?
I used my D30 with my Phototrons (without the voltage regulator) and had to send it in for repair.
Not Cheap.
Just a thought
David
Digital set me free
"Welcome Seeker! Now, don't feel alone here in the New Age, because there's a seeker born every minute."
www.damphyne.com
DAMphyne is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Gear.php Not Working Correctly segal3 EE 2 Bugs 1 8th of October 2006 (Sun) 20:02
Suggestion: consider a sticky about the search function not working correctly Picture North Carolina Forum Talk 0 23rd of August 2006 (Wed) 21:29
550EX Speelight isn't working karenl39 Small Flash and Studio Lighting 4 16th of July 2006 (Sun) 07:54
Feedback not working correctly? MMCM Version 1.0-1.5 discussion 0 19th of January 2005 (Wed) 03:07
AEB working correctly? afinegold Small Compact Digitals by Canon 0 15th of September 2003 (Mon) 17:09
