Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Talk About Photography > General Photography Talk
Reply
Thread Tools Display Modes
Old 17th of September 2010 (Fri)   #1
WINDY.
Default Wrong ISO speed for film, what should I do?
Hi there,
I've been shooting a lot of film recently these days. Currently using an AE1, most of the situation I shoot requires a film speed of ISO 400. I've set the ASA speed of the camera to 400 and for the first time I loaded a portra 100 daylight film. Had about 20shots so far, to realise that I've been metering at ISO400...
Will my photos all be underexposed because of this? I don't know what I should do now after realising this mistake. Should I change to ISO100 on my camera then continue shooting? I've been shooting slides so I don't know is it possible to be able to recover my exposure?
I had a lot of keepers at least and hope to be able to have them usable, any help here?
WINDY. is offline   Reply With Quote
Old 17th of September 2010 (Fri)   #2
krb
krb's Avatar
Default Re: Wrong ISO speed for film, what should I do?
You could finish the roll at ISO 400 and have the lab push them 2 stops, but I have no idea how they would turn out.
-- Ken
Flickr
Gear list
krb is online now   Reply With Quote
Old 17th of September 2010 (Fri)   #3
Photon Phil
Photon Phil's Avatar
Well I'd hoped you'd rated 400 as 100 because the headroom is tremendous. But I think you will get something you can work with the scans from, even underexposed. Just correct your settings on cam now and keep shooting.
Bodies: SONY A850 / Pentax K100D / D70 (18-55VR, 55-200)
Primes: Minolta 28 ff2.8 / Minolta 50 f1.7 / Minolta 50 f2.8 Macro
Zooms: 35-70 f4 / 100-200 f4.5 Lights: AB800 / AB400 & CSRB's
Classics:
Pentax Super Tak 50 f1.4 / Pentax SMC 50 f1.4,f1.7,f2.0
Photon Phil is offline   Reply With Quote
Old 17th of September 2010 (Fri)   #4
sapearl
emailed Tim some prozac
sapearl's Avatar
Hi Windy, sorry to hear about your misfortune - that can be very frustrating.
Basically, having shot your Portra 100 film at an ASA of 400 means they will be 2-stops underexposed. A number of your shots will certainly be underexposed, but you may be pleasantly surprised by some of the results since you are shooting slide film, if you have them processed in the conventional manner.
One alternative is that you could continue to shoot everything at 400 on that roll and then tell the lab to "push process" it, explaining what you did, and that may save some of the images. Or you could just change to 400, continue to shoot at the corrected ASA, and hope for the best. Do you have plans to scan any of these slides, or were you going to project them in the (old) conventional manner? - Stu
sapearl is offline   Reply With Quote
Old 17th of September 2010 (Fri)   #5
D Thompson
D Thompson's Avatar
+1. I wouldn't change the ISO for this roll, just make sure the lab knows so they can process.
Dennis
Canon 5D 20D l Dennis Thompson Photography
I have not yet begun to procrastinate!
We'll be friends until we are old and senile. Then, we'll be new friends every day thereafter.
D Thompson is offline   Reply With Quote
Old 17th of September 2010 (Fri)   #6
Lizzy7
Hi Windy,
I'd probably remove the film now (or carry on shooting at 400 if it's not really important stuff) and take it to the lab and let them know.
I was a bit confused, you said you were shooting portra but then you mentioned slides? Portra is a neg film and goes through C41 process. C41 pushes ok although I think we could only push one stop on the machine we had
Lizzy7 is offline   Reply With Quote
Old 17th of September 2010 (Fri)   #7
sandpiper
sandpiper's Avatar
Not a good idea.
Keep shooting at 400 until you finish the roll and just have it push processed as others have mentioned. Back in the days before we had 6400 ISO to play with, we would often set the exposure a stop or two underxposed for the whole roll, then pushprocess to correct it.
I certainly wouldn't recommend changing the ISO now as then you can't correct for the error
sandpiper is offline   Reply With Quote
Old 17th of September 2010 (Fri)   #8
Wilt
Wilt's Avatar
Portra 100...a color negative film, I believe. Color neg has long enjoyed a very wide latitude of exposure, acceptable results from -2EV to +3EV. Underexposure will result in somewhat muddy, less saturated shadow tones, but otherwise the prints will be pretty acceptable, without resorting to push processing. If underexposed to a greater degree than -2EV, I'd follow the recommendation for push processing.
Keep POTN alive and well with member support http://photography-on-the.net/forum/donate.php
Wilt is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
High Speed - what am I doing wrong Ken Robertson Critique Corner 3 24th of September 2009 (Thu) 22:38
FILM ISO Speed and changing it. Lookin4filters General Photography Talk 7 5th of September 2008 (Fri) 05:04
Shutter speed - Film speed - Focal length - Sports photography ddlj81 Sports Talk 6 11th of November 2007 (Sun) 20:00
Wrong Shutter Speed? tsamarin Motorsports 13 18th of August 2007 (Sat) 11:30
right place - wrong shutter speed! spud159 Motorsports 8 27th of July 2006 (Thu) 00:40
