Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > RAW, Post Processing and Printing
Reply
Thread Tools Display Modes
Old 5th of October 2010 (Tue)   #1
Nickc84
Nickc84's Avatar
Default Can these harsh shadows be repaired?
I like this image but the shadow on the grooms face looks awful and I have tried everything in CS5 with no luck. Anyone?
Nickc84 is offline   Reply With Quote
Old 5th of October 2010 (Tue)   #2
Peano
Peano's Avatar
Default Re: Can these harsh shadows be repaired?
Most likely no fix. It appears that you didn't shoot raw.
Peano
RadiantPics.com
Peano is offline   Reply With Quote
Old 5th of October 2010 (Tue)   #3
chestercopperpot
I don't think it looks horrendous. Certainly not ideal, but I don't think the picture is totally worthless. Just a thought - and it may not work at all - but since you cant lighten the dark areas, did you try darkening the light areas on the guy to make it less of a transition?
Michael
5D Mark II
16-35mm 2.8L II; 35mm 1.4L; 85 1.2L II; 70-200 2.8L IS II
chestercopperpot is offline   Reply With Quote
Old 5th of October 2010 (Tue)   #4
katodog
katodog's Avatar
It can be fixed, somewhat, but with the JPG image you won't like the results. You'll get imperfections in the image trying to recover shadows and such with a JPG. It can be done with pretty good results though, if you don't blow the image up too much. If you have a RAW it can be fixed with better results though, and probably easier than doing a JPG too.
For this shot, I opened it in Lightroom, upped the exposure by 1 and the fill by 35. I then export it as a new image so as not to overwrite the original. I take the saved image and copy it, then paste it as a new layer over the original in PSPX2. Then, it's just a matter of using the eraser tool to go over the spots i want to keep original, and then dodge the shadows to make them look a bit better.
The animation makes the shot look like crap, but you get the idea. with a RAW you would have a much broader spectrum of what you could do, and it would be a lot easier to recover areas and brighten areas, etc.. with my edit it looks similar to what you might get with a reflector aimed at them from the right, so it doesn't end up looking too bad. A little bit of work to smooth out any imperfections in the JPG and it might not look too bad. But, like I said, you wouldn't get away with blowing it up very much, if at all. Sadly, there's no way to completely get rid of the shadows in the JPG, at least not without a boatload of work.
The only stupid question is the one that goes unasked - Photographers shoot to thrill, not to kill
My Gear - Flickr - Facebook
Smoke Photography - Sound-Activated Paint
katodog is online now   Reply With Quote
Old 5th of October 2010 (Tue)   #5
ChasP505
"brain damaged old guy"
ChasP505's Avatar
Originally Posted by Nickc84 View Post
Anyone?
If you're asking for editing help, please enable "Image Editing OK" and post a link to the original image file.
Chas P
"It doesn't matter how you get there if you don't know where you're going!"
ChasP505 is offline   Reply With Quote
Old 5th of October 2010 (Tue)   #6
Bobster
Bobster's Avatar
is it even your image? seems it was taken with a Pentax K20D, your sig says 7D...
Robert Whetton Dorset Portrait & Events Photographer | Photoshop Guru
DIY Monitor Hood | Gear | Tweet | Google+ | Get your focus spot on
Bobster is offline   Reply With Quote
Old 5th of October 2010 (Tue)   #7
Nickc84
Nickc84's Avatar
Yeah, I had a k20 few months back. Ill try to link the raw file
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
How do you avoid harsh shadows? Kauaicrazed People Talk 5 21st of October 2008 (Tue) 16:42
Any way to process out harsh flash shadows? Picture North Carolina RAW, Post Processing and Printing 3 30th of January 2008 (Wed) 05:27
Harsh Shadows from trees outdoors... CanonLaw Small Flash and Studio Lighting 5 30th of July 2006 (Sun) 18:05
Removing harsh shadows Thompsunshine RAW, Post Processing and Printing 4 18th of July 2006 (Tue) 18:14
