Thread started 07 Oct 2010 (Thursday) 20:28
60d wireless trigger
thatguy215
Oct 07, 2010 20:28 |  #1
hey guys, i just recived my 60d in the mail the other day and cant seemed to fire my 430exii with the built in transmitter. The manual says to look at flash units manual but i dont have that with me right now.
would someone please show me how i can do this??
msowsun
Gallery: 14 photos
Oct 07, 2010 21:27 |  #2
You can download the 430EX II manual here: http://a248.e.akamai.n​et …anuals/280/2804​30exii.pdf (external link)
See page 26.
Mike Sowsun / S110 / SL1 / 80D / EF-S 24mm STM / EF-S 10-18mm STM / EF-S 18-55mm STM / EF-S 18-135mm STM / EF-S 18-135mm USM / EF-S 55-250mm STM / 5D3 / Samyang 14mm 2.8 / EF 40mm 2.8 STM / EF 50mm 1.8 STM / EF 100mm 2.0 USM / EF 100mm 2.8 USM Macro / EF 24-105mm IS / EF 70-200mm 2.8L IS Mk II / EF 1.4x II
thatguy215
Oct 07, 2010 21:48 |  #3
thanks...ill give it a go
robonrome
Oct 07, 2010 21:49 |  #4
Try this?
according to page 140 of my manual fully automatic shooting with one external speedlite..
1) popup flash
2) select "flash control" in menu
3) select "built in flash" function setting
4) select flash mode - select ETTL and press "set" button
5) select wireless func - select the option that shows just the speed light picture and press "set" button
6) set channel and make sure your speedlite is in slave mode on the same
channel
7) set "firing group" to All
should now fire external speedlight while the built in is popped up but not fire the built in.
rob - check my galleries at http://hardlightimages​.zenfolio.com/ (external link)
Zenfolio coupon discount when signing up - 93R-NCK-DUT
Canon 5D Mkiii; Sony RX100; Lumix G5; 17-40L; 24L TS-E F3.5 Mk2; 24-105L IS; 40 F2.8; 135L; 70-200L F2.8 IS MkII; Ext II 1.4x; 580 exII; 270 ex... other filtery stuff:)
thatguy215
Oct 07, 2010 22:04 |  #5
cool guys. Thanks alot. i thought i had to go through the external flash menu but guess not :D
robonrome
Oct 07, 2010 22:07 |  #6
thatguy215 wrote in post #11055688 (external link)
no that's the beauty of the 60D... can be all all done via the camera:D
msowsun
Gallery: 14 photos
Oct 07, 2010 22:32 |  #7
robonrome wrote in post #11055706 (external link)
Yes, you need to go into the camera 's built-in flash menu and select "Wireless function" "enabled".
Then you must also take the 430EX II and set it to "slave". I don't think this can be done using the camera's external flash menu.(please correct me if I am wrong) I am pretty sure you must take the flash in your hand and set it to "slave" as per page 26 of the 430EX II manual.
robonrome
Oct 07, 2010 22:42 |  #8
msowsun wrote in post #11055852 (external link)
yes, that's true, I meant that you can control the flash from the camera. you do have to set it as slave.
apersson850
Oct 08, 2010 01:48 as a reply to  @ robonrome's post |  #9
The external flash menu controls an external flash mounted in the camera's hotshoe.
Slave flashes are controlled by the camera's internal flash, so it's the menu item controlling the internal flash you should use.
Anders
5,854 views & 0 likes for this thread
Latest registered member is jainlemos
762 guests, 423 members online
