Thread started 08 Oct 2010 (Friday) 13:31
Fixing a Dented Filter Ring: The Poor Man's Guide
Paul ­ Tinworth
Oct 08, 2010 13:31 |  #1
FOR YOUR LEISURELY PERUSAL
THE IDIOT WITH ACCESS TO A GARAGE PRESENTS
How to Fix a Dented Filter Ring on a Lens
FOR THOSE WITH A RATHER LIMITED FAITH IN THEIR WALLET
AND AN OVER-WHELMING DESIRE FOR HITTING THINGS REPEATEDLY
Oi oi! How goes it? :D
A little while ago I was a complete twat and pranged my 24-70L. I don't even know how I managed it, but I had dented the outer portion of the lens filter thread.
"Gosh-darnit," I said in my best Deep South accent learnt from watching the American documentaries True Blood and Deadwood, "I'm not going to spend my easily-spent money on repairing this expensive thingy!"
And thus I set about finding a hammer.
Exhibit #1:
IMAGE: http://farm5.static.flickr.com/4154/5062166141_76a93e8cdf_b.jpg
First off, I found some soft wood. I'm not very scientific, so I can't tell you what sort it is - all I know is that I was able to mark it purely by pressing a thumbnail against it. The relevance of this is so that when you place the wood against the filter thread and apply pressure that it will [hopefully] mould against the metal thread instead of misshaping it.
Ideally, this soft wood needs to be circular in shape, with at least one flat side so as to be flush against the front element. I don't have much patience for inanimate things, so I used whatever I could find; if you're meticulous/sensible, cutting a circle with a diameter slightly smaller than the filter thread would be perfect to retain shape.
To add some semblance of protection, I found a soft, cheap dish cloth to place the lens on while it sat on the work-bench. Furthermore, I placed a lens cloth between the soft wood and the filter thread, just for a tiny bit of extra shock absorption and to stop any rough wood rubbing against the front element of the lens. You may wish to use more protective materials such as thick cloth or polystyrene.
Exhibit #2:
IMAGE: http://farm5.static.flickr.com/4149/5062197687_05eeb1edb3_b.jpg
With the basic set-up ready, I gave the wood a few taps and determined it was working, albeit very slowly, before realising I was using my hammer (which was a fairly tiny one) a bit too close to the front element. To combat this (and to allow me to hit it harder without risking smashing the glass), I found another wedge of wood (hardness irrelevant, as it was to be placed on the existing wood and not the lens), as shown below.
Exhibit #3:
IMAGE: http://farm5.static.flickr.com/4107/5062476349_d670f0a89b_z.jpg
Repeat. And repeat again.
After every half-dozen hits, I'd take the lens away from the bench to look at it. From here it really is all trial and error; I found towards the end that I was risking bending a portion of the thread *outwards*, so I stopped.
With a small application of vaseline, I gently managed to get a 77mm CPL to bite on the thread. Joy! The first time around I got about half a full turn, then undid it a bit, and tried again. At the time of writing, my CPL sits securely on my 24-70L. Not flush, but secure, and able to be removed without any difficulty.
Exhibit #4:
IMAGE: http://farm5.static.flickr.com/4151/5063087100_4f3bd3b621_b.jpg
While a lot of this may make some of you DIY buffs smirk or turn your noses up, I hope this tiny bit of stupidity and elbow grease will help someone else avoid a sizeable repair bill!
I'm off to the Algarve for two week's holiday and I fully intend to enjoy using my new CPL on my 24-70L.
Happy shooting! :D
~ Paul
Current kit: Fujifilm X-T1 | XF 16-55 f/2.8 | XF 50-140 f/2.8 | XF 56 f/1.2 | XF 80 f/2.8 Macro
Previously owned: Canon 5D Mark II | 40D | 50 f/1.4 EX | 24-70 f/2.8L | 70-200 f/2.8L | 430EX
Paul Tinworth Photography (external link) - Portraits, Weddings, and Events | Gear-list & feedback
SiaoP
Oct 08, 2010 15:53 |  #2
Seems feasible as it's only a filter thread. But it will be a pain if the dent went further than just the front thread area.
My Flickr (external link) | Gear List
rklepper
Dignity-Esteem-Compassion
Joined Dec 2003
Oct 08, 2010 17:26 |  #3
I am not sure I would do that with the filter still on the lens. You are a braves soul than I.
Doc Klepper in the USA
I
V-Wiz
Joined Sep 2009
Oct 08, 2010 17:31 |  #4
Good job, I may need to try this on my Father Minolta Lens.
Gripped 5D Mark II l 24-105 F/4 L l 70-200 F/4 L l Tokina 12-24 F4 l 50mm 1.8 l Sigma 600 Mirror l B+W KSM CPL l B+W 6stop ND filter l Hitech 0.6 GND l YN-468 Flash l Kenko Pro 300 1.4 TC l Induro Tripod, Vanguard 250 Ballhead.
TuanTime
Oct 08, 2010 17:46 as a reply to  @ V-Wiz's post |  #5
I don't think that was done with the filter on, I think he put the filter on after to show that he can put one on after the fix.
mjww
Oct 08, 2010 17:46 |  #6
Nice tip! I am sure there are many variations to this trick, but your result seems to be a round as new! Hope you take batter care of the lens the next time! :-)
Equipment list - According to the wife - "how many more lenses do you need? Yet another camera?"  ???
MR ­ MACHINIST
Oct 09, 2010 17:17 |  #7
Good work and nice tip this is similar to the work I do all day, you know fixing stuff no one else will touch with a 10' pole. How does it look with the filter off?
mike1187
Joined Sep 2009
Oct 10, 2010 00:57 |  #8
This post reminds me of a somewhat similar situation I encountered a while back. I picked up an older 400mm RMC Tokina lens on ebay quite inexpensively. When the box arrived I could hear broken glass rattling around inside.
I opened the box and found the lens rolling around loose in the box, protected by only a single layer of bubble wrap, and the filter that was on the front was shattered... the threads looked similar to your "before" photos. Since I didn't really have anything to loose at that point, I smashed out the rest of the glass filter and was going to leave it like that.. but decided I might as well make it right.
So.. I covered the front element of the lens, and fired up my dremel. I was able to split the filter ring down to where it met the front of the lens, and grab it with a pair of pliers and twist. The filter ring snapped, and peeled out like a snap ring leaving the original threads on the lens un-damaged!
This experience almost made me want to buy some cheap ebay filters, remove the glass and install them on my lenses just to protect the threads.. although I have not done that yet LOL!
Canon T1i / Canon T3i / 18-55mm IS / 55-250mm IS / 50mm 1.8 / Canon 24-105mm F4 L / Sigma 400 5.6 APO
My Feedback
lettershop
A lame title from the TF
Joined Sep 2009
Oct 10, 2010 06:34 |  #9
nice job. quick, put that lens up on EBay, Brand new in Box!!!
1DX, Gripped 60D,10-22mm, 18-135mm, 70-200mm f/2.8L IS, 24-70L, TS-E 24mm f/3.5L II, 100mm f2.8 Macro, 50mm f/1.4, 60mm 2/2.8 Macro, 580ex, 430EXII, Pocketwizards, Softbox, Tamron 1.4X TC, Canon 2x TC, GT3541LS, BH-55
MARK1992
Oct 10, 2010 06:51 |  #10
"Set about finding a hammer."
Your name, "Jeremy Clarkson" by any chance? :lol:
Brilliant guide, potentially a lifesaver.
richardfox
Oct 10, 2010 08:40 |  #11
I've done the same exact process a couple of times. Just about any mechanical problem can be fixed if one is very careful. My best repair/modification was removing the FD mount completely from my 500mm f/8 reflex Canon lens and mounting an EOS flange with a focus confirmation chip. Microsurgery, yes, but it works like a champ and focuses to infinity (actually, well past). Just have to be really careful when drilling mounting holes as you don't want any dust getting into the lens.
Now, why did I do this? The 500mm f/8 is slow, manual focus, but very light and compact. Want a covert long telephoto? A 500mm mirror is the answer if you can live with the donut effect in the bokeh. It's great for long-range candid shots!
Canon 50D gripped, EF 50/1.8, EF-S 10-22, 17-40L, 24-105L, 70-200 f/2.8L, 100/2.8 macro, 100-400L, 300 2.8L, Canon 500 f8 mirror with chipped EF mount, 580EX, 1.4x and 2x Canon teleconverters, Canon EF Life-Size converter.
Paul ­ Tinworth
Oct 11, 2010 09:38 as a reply to  @ richardfox's post |  #12
SiaoP wrote in post #11059948 (external link)
Indeed - I was lucky the damage wasn't worse!
rklepper wrote in post #11060403 (external link)
I'd heartily advise against doing so! I went about the steps described without any filter on the lens (not that I could've put one on in the first place). I'm definitely more stupid than I am brave. ;)
MR MACHINIST wrote in post #11065204 (external link)
Thanks! It still looks a bit scratched up, but I don't get a sinking feeling at the pit of my stomach when I look at it now. ;)
MARK1992 wrote in post #11067764 (external link)
Nope, but I am a fan! :lol: Thanks for the kind words!
~ Paul
10,870 views & 0 likes for this thread
Latest registered member is CCYMINUM
803 guests, 441 members online
