Thread started 25 Oct 2010 (Monday) 13:11
Camera Left Camera Right definition please
jvinlove
Oct 25, 2010 13:11 |  #1
Hello all, first let me say all of the images in this thread are fantastic and some are even Pham-tastic!!! I have a question that hopefully can be cleared up, Cam left and Cam right, what exactly does this mean is the OCF imeadiatly to your left or right when shooting, or is this mean to the left or right of the subject, I am fairly new to OCF and seem to be a little frustrated when I look at alot of my test I'm either to dark or blown way out never a middle ground no matter how I adjust shutter for ambient or appeture for flash, and even flash power seems to be non consistent. I am wondering if it is my flash distance to subject which brings me back to cam left and cam right
If I put my OCF to my left it seems harsh same with cam right. I hope I did not confuse you as much as I am, please help of any sugustions on how to understand lighting settle more.
Canon 5Dc, 5D2, 5D3 :: 70mm-200mm f4L :: 85mm f1.8 :: 50mm f1.4
apersson850
Oct 25, 2010 13:16 |  #2
I'm not sure which images you are referring to, since there are none in this particular thread.
Personally, I always see left and right as I see it when I use the camera. How the subject sees it I don't care.
Anders
FlyingPhotog
Cream of the "Prop"
Oct 25, 2010 13:21 |  #3
Camera Left / Camera Right are in relation to where the camera is pointing and the opposite of where your subject is looking (provided, of course, they're looking at the camera!)
Camera Left = Subject Right
Camera Right = Subject Left
Jay
pantherphotos
Oct 25, 2010 13:21 |  #4
That's the way I understand it also. Cam left means my left and cam right means my right. Although I did see one image where someone had said they had flash cam left, but based on shadows, it was obviously cam right. So this may be a good question to ask!
Eric
Canon EOS 1D MkIIn | Tamron 28-75 f/2.8 | 70 - 200 f/2.8L | 50 f/1.8 II | 2x YN560 flash
My Blog: http://pantherphotogra​phy.wordpress.com/ (external link)FACEBOOK (external link)
jvinlove
Oct 25, 2010 13:41 as a reply to  @ pantherphotos's post |  #5
Im sorry, the photo's in the single light, multi light and alien bees threads,
i guess my confusion stems from the term itself in relation to where the light is actually placed ... in my mind if i hear camera right or left, i imagine that I can reach to my right and left and grab the light. So like if you look at Phamsters images and he says deep octa cam right at 6foot does he mean that the light is to my right but 6 foot from the subject, and then obviously that doesn't include how near or far i am from the subject
FlyingPhotog
Cream of the "Prop"
Oct 25, 2010 13:44 |  #6
jvinlove wrote in post #11162038 (external link)
The distance to/from the subject doesn't really matter. The illumination is predicated on Light <--> Subject distance. Whether you're six feet away or 6,000 feet, the subject is lit at an equal value so long as the light doesn't move.
Jay
Tawcan
Joined Apr 2004
Oct 25, 2010 13:51 |  #7
Like what other have mentioned already, camera left/right is to relation to the photographer. It's the same ideas as when you climb and ski and say...
Climber's left = skier's right
Climber's right = skier's left
The distance from the light to the subject matters; the distance of your to the subject doesn't matter. As long as the light to subject distance stays consistent and the output power stays consistent then exposure should be the same regardless how far you are from the subject.
boblai.com (external link) |Facebook Fanpage (external link) | Flickr (external link)
jvinlove
Oct 25, 2010 14:04 |  #8
OK thanks makes more sense i know its a basic question and i appreciate the help, i just need to keep practicing, i think a big part of my problem is flash <-->Subject if i have it to far away it almost seems no matter what a do shutter or aperture its either to dark or to bright, light fall off is to quick and i am under or over exposing.
bobbyz
Oct 25, 2010 14:37 |  #9
jvinlove wrote in post #11162171 (external link)
Need to pick up the basics. And get a lightmeter even a cheapy one to make the life easier.
5dmk3, 35L, 85L II, 300mm f2.8 IS I, 400mm f5.6
Fuji XT-1, 14mm f2.8, 23mm f1.4, 35mm f1.4, 56mm f1.2, 90mm f2, 50-140mm f2.8
jvinlove
Oct 25, 2010 14:43 |  #10
already got on L-358
bobbyz wrote in post #11162358 (external link)
gonzogolf
dumb remark memorialized
Oct 25, 2010 14:47 |  #11
Keep in mind in terms of light softness there are two basic rules that apply. Bigger is softer, and closer is softer. Given a fixed size of modifier, the closer you get it to the subject the softer the light it will give. At a fixed distance a bigger light source will be softer than a smaller one.
bobbyz
Oct 25, 2010 17:15 |  #12
jvinlove wrote in post #11162393 (external link)
Then why you aren't nailing the exposure? Even if meter is off from camera (which it can) that offset should be same all the time.
René ­ Damkot
Oct 25, 2010 20:07 |  #13
Yep, you
Shutterspeed has no influence on flash exposure, only on ambient.
Flash exposure depends on flash setting and distance, aperture and ISO.
Ambient exposure depends on ambient light, aperture, shutterspeed and ISO.
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
Pyromaniac
Joined Dec 2004
Oct 25, 2010 21:18 |  #14
When the says the light is at camera right at 6 foot, what he means is that light is generally to the right side of the camera and 6 feet high.
www.actionstills.com (external link) | Ohio POTN Google Calendar (external link) | Blog (external link)
klr.b
Oct 27, 2010 16:09 |  #15
Tawcan wrote in post #11162099 (external link)
Climber's left = skier's left
Well that's certainly confusing...that must be why I dont' climb or ski ;)
gordon
Gear and Feedback
11,533 views & 0 likes for this thread
version 2.0 /
Latest registered member is CanucksFan
563 guests, 292 members online
