Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Talk About Photography > Macro Talk
Reply
Thread Tools Display Modes
Old 31st of October 2010 (Sun)   #1
hayath
hayath's Avatar
Default Flash bracket question
Had a question on flash brackets always being used to the left of the lens.
Wanted to originally post it here, but figured the general lighting forum could provide wider views.
Please do post in your responses on
http://photography-on-the.net/forum/...php?p=11196788
TIA
Cheers,
Hayath
Flickr | Blog | Picasa
hayath is offline   Reply With Quote
Old 1st of November 2010 (Mon)   #2
Wallpap3r
Wallpap3r's Avatar
Default Re: Flash bracket question
Assuming your question is directed toward those using macro flash brackets, theyre fairly different compared to normal flash brackets and youll get different responses depending on if theyre using it for macro or not.
40D || 50 1.8 II || 18-55IS || 85 1.8 || 430EXII || YN560 x2 || Cheap umbrellas x2 || QBox 24 || Cheap macro crap
Wallpap3r is offline   Reply With Quote
Old 1st of November 2010 (Mon)   #3
hayath
hayath's Avatar
Thanks, was initially a macro question, but i guess a bracket that could move sideways would be more versatile (I do not like carrying too much equipment in the camera bag).
Have a simple DIY idea that I've been working on, shall post the results soon
Hayath
Old 11th of November 2010 (Thu)   #4
artyH
Which brackets do folks recommend? I haven't done much macro photography, since back in the film days. Even then, it was mostly copy work.
I have the 430EXII with a diffuser on the way.
artyH is offline   Reply With Quote
Old 11th of November 2010 (Thu)   #5
sapearl
emailed Tim some prozac
sapearl's Avatar
Hi Arty - If you're doing a lot of heavy duty work - couple of times a month - weddings, social events, etc, then Newton, Custom, RRS are excellent choices. These are well machined, most tend to be light weight, versatile and have a number of flexible features - but they are quite pricey. Usually they run $275+ when you add in the necessary extras. I own a Newton myself - it's wonderfully compact and performs as advertised.
If you're doing light work that's not too demanding, there are a number of Stroboframe and similar products you can pick up for under $100. These are perfectly fine for casual use.
Most of the time I bounce flash with my 580ex. As far as diffusers go, I use the Lumiquest products on occasion, and sometimes the Stoffen. Most of the time I can achieve what I need simply by bouncing, with he little card extended. Diffusers and light modifiers are fine, but many people misuse them not really understanding their proper working environments. At best they allow you to achieve pleasant lighting effects; at worst they do little to enhance the image and drain your flash batteries. - Stu
sapearl is offline   Reply With Quote
Old 11th of November 2010 (Thu)   #6
artyH
Hi Sapearl - I am not a professional and I would like to keep costs down. Are there any specific models that are recommended?
I came across this Custom model:
http://www.adorama.com/CBCBJ.html
I assume that it needs a flash mounting plate. Any experience with these or similar ones?
I can't justify $275 for an occasional use bracket. I would like to get reasonable quality, but not necessarily professional quality - I just want a bracket to work and help me get macro shots.
I'd hate to lose my flash because of a collapsing bracket.
I also figured I would get the Canon cord.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Question: Flash Bracket? lawlz_xD Small Flash and Studio Lighting 7 28th of July 2010 (Wed) 11:31
Flash Bracket Question treaks Small Flash and Studio Lighting 1 10th of December 2009 (Thu) 13:56
Newbie question on L bracket and flash bracket WT21 Accessories & Storage 10 24th of November 2009 (Tue) 17:11
flash bracket question imhotep Small Flash and Studio Lighting 1 28th of November 2006 (Tue) 16:26
Got a bracket for flash, but I have a question? Lunajen Small Flash and Studio Lighting 9 8th of November 2006 (Wed) 20:58
