Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Canon EOS Digital Cameras
Reply
Thread Tools Display Modes
Old 30th of August 2005 (Tue)   #1
Trumper
Default L lenses question and a White balance question
Are the L series lenses always white in colour?
I ask this because i was lucky enough to be able to borrow a friends 100-400 L IS lens on holiday.Because of this i was very aware of my responsibilities to it's well being.
The problem was that although other photographers were quick to say nice things about the lens even if it was only attached to a D30 [since discovering the sharpening tool i have fallen head over heels in love with this old trouper again] but i was very self concious of anyone else not so amiable getting their grubby little mitts on the lense as well by hook or by crook.
Do they make the L series in black as well so it doesn't stand out in a crowd?
The next question,on my D30 the Auto White balance seems very blue and cool,i have been using the sunny settings on the white balance menu and it seems 100% better,any ideas please.
Thanks for looking.
I have enclosed a sharpened and unsharpened photo of Whitby Church taken on the D30,is it normally this soft?
Trumper is offline   Reply With Quote
Old 30th of August 2005 (Tue)   #2
nigelch
Default Re: L lenses question and a White balance question
Not all L lenses are white, just the long ones. They are a little conspicuous, but the kind of folk who would bang you on the head to steal the lens would still steal it if it were pink!
I would refer you to the other thread about sharpening, but my question is; how the hell did you get a picture of Whitby Abbey with the sun shining? I have been there several times over the years, and it ALWAYS rains!
Nice light,
N
Nigel Cheffers-Heard
photography+design
Topsham, Devon, UK
+44 (0)771 261 4514
nigelch is offline   Reply With Quote
Old 30th of August 2005 (Tue)   #3
davepgh1
The black "L" lenses have a red stripe on them, and are much larger, therefore anyone who knows lenses will spot them.
davepgh1 is offline   Reply With Quote
Old 30th of August 2005 (Tue)   #4
Jim_T
Jim_T's Avatar
On the lenses... The white ones have a red stripe too.. (It's a universal 'L' trademark).
On white balance.. It's pretty subjective... Basically it's what you like.. If white balance is important, then you should be shooting RAW, or if you prefer JPEG, then you should be setting up a custom white balance for sunlight using a grey card..
Edit.. On the softness.. You should have posted unsized crops of the image rather than shrinking the whole image down.. Shrinking an image tends to mask softness.. Yes.. The early Canon DSLR's didn't use as much internal sharpening as the point and shoot cameras.. As a result they tend to need more sharpening to look the same..
Jim_T is offline   Reply With Quote
Old 30th of August 2005 (Tue)   #5
GyRob
i think white balance should be what YOU want it to be as long as your happy with it, i often make my pics warmer because i like them like that , and yes it is a little soft well the one i tried was.
Rob.
GyRob is offline   Reply With Quote
Old 30th of August 2005 (Tue)   #6
Perfect_10
Perfect_10's Avatar
my 70-200 L has a black lens hood .. is that correct ??
My Gear List
Perfect_10 is offline   Reply With Quote
Old 30th of August 2005 (Tue)   #7
Incomplete Pete
Incomplete Pete's Avatar
Larger?! The black L lenses are the small ones, 200mm or less!
The reason the L lenses are white is, for one thing, down to exposure as they are aimed at pro use so they always stand out on the sidelines. They're also white because white reflects better than black, thus they won't heat up in the sun and distort the lens, somethign which isn't an issue on the smaller lenses, but as they get the bigger they're more prone to distortion.
Incomplete Pete is offline   Reply With Quote
Old 30th of August 2005 (Tue)   #8
RTMiller
RTMiller's Avatar
That's correct.
RTMiller is offline   Reply With Quote
Old 30th of August 2005 (Tue)   #9
Trumper
Thanks for the replies,regarding the sun at Whitby we were very lucky [hates to rub salt in the wound Gulp] we had sunshine for nearly 10 minutes LOL.
I was'nt sure about the size of pictures we could post on here so kept them small,if i can i' ll crop some details for you.
I could'nt shoot RAW i took 860 photos in 2 weeks up there,i would've needed so many cards or a storage device.
Old 30th of August 2005 (Tue)   #10
davepgh1
Reading the original post, I think that "Trumper" was suggesting that black "L" glass would not draw as much attention. I was comparing black "L" with "non-L" glass, and the red stripe and size would still make them stand out. I get as many comments on my black 16-35L and 24-70L as i get with the white 70-200L IS
Old 30th of August 2005 (Tue)   #11
Trumper
Yes ,the white stands out to everyone whether they know what they are looking at or not,a black coloured lens to someone not into photography just looks like a black lens.
Old 31st of August 2005 (Wed)   #12
ron chappel
Honorary Moderator
ron chappel's Avatar
I'm not sure if your particular D30 is overly soft but it is entirely normal for canon DSLR's to give softish images with standard settings.You have to bump up the in-camera sharpness settings (if the D30 has them) and/or sharpen in photoshop.
Are you aware the the D30 suffered from a slight colour cast? There were lots of hints and fixes being bandied about when the D30 was all the rage.Maybe the white ballance issues are related to that?
Here are some links about how to fix the D30 colour cast and manipulating white ballance in general
http://www.lonestardigital.com/D30_Colors.htm
http://www.edigitalphoto.com/tips_te...05edp_playing/
ron chappel is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
White balance question gateruner Canon EOS Digital Cameras 16 16th of February 2007 (Fri) 06:00
white balance question erin753 General Photography Talk 4 2nd of July 2006 (Sun) 16:51
White Balance Question MonteCeco Small Flash and Studio Lighting 12 14th of March 2006 (Tue) 18:19
White Balance Question Souwalker Canon EOS Digital Cameras 3 4th of February 2006 (Sat) 05:42
White Balance Question talons40 Canon EOS Digital Cameras 7 27th of January 2006 (Fri) 17:05
