Go Back   Canon Digital Photography Forums > 'Photo Sharing' section > Sports
Reply
Thread Tools Display Modes
Old 7th of November 2010 (Sun)   #1
llie19
Default First outing with 7D+70-200 2.8 II
Unfortunately did not turn out as stellar as I thought it would. I used manual mode, 1/1000 shutter speed at f/2.8, af expansion around center point. The background blur is there, which is nice, but somehow the sharpness just does not come close to what everybody makes it out to be. I was expecting the pictures to be razor sharp, but they don't really look that much superior to the other pictures I took with a 550D+55-250 (1/10 the price of 70-200 2.8 II). I am baffled. As much as I am aware of my photographic incompetence, I really want to be assured that my newly purchased lens is a good copy.
I also posted these on the lens sample thread, and someone mentioned that the overcast lighting may have contributed to the (perceived) lack of sharpness. I really just hope it's my poor shooting, or me being paranoid, not anything wrong with the lens.
llie19 is offline   Reply With Quote
Old 7th of November 2010 (Sun)   #2
llie19
Default Re: First outing with 7D+70-200 2.8 II
These are some previous shots with 550D+55-250 posted here. Putting aside the lighting differences for a moment, I can't really tell much difference in pure image quality, and I thought upgrading from 55-250 to 70-200 II would make the difference between night and day.
http://photography-on-the.net/forum/...d.php?t=950270
http://photography-on-the.net/forum/...d.php?t=953176
http://photography-on-the.net/forum/...d.php?t=946332
http://photography-on-the.net/forum/...d.php?t=936974
Old 7th of November 2010 (Sun)   #3
canonnoob
Ignored by the TF and i am soo confused
canonnoob's Avatar
upgrading lenses doesnt make up for technique. your images show focus being off and you have too slow of a shutter speed. White Balance is also off as well as the images being a tad dark. Just because you got a new lens doesnt mean that you are now going to get the most amazing shots ever. I tried looking for some settings to get an idea of what you were shooting at, but alas, no setting information.
Dave W.- "I don't want to be famous, I just want to make great photographs"
Gear
Springfield, Mo Sports Photographer
Model Mayhem
SportsShooter
Selling Gear: 1D mk II N
canonnoob is offline   Reply With Quote
Old 7th of November 2010 (Sun)   #4
llie19
Thank you. I completely agree that the photographer makes the biggest difference in picture quality, but if you read what I wrote I am not putting any blame on the lens, in fact I want all the blame to be on myself, thus the lens is working fine.
Somehow all the pictures lose their exif after being uploaded into flickr. Here is one set of basic info, and most pictures should have the same:
Exposure 0.001 sec (1/1000)
Aperture f/2.8
Exposure Program Manual
White Balance Auto
Old 7th of November 2010 (Sun)   #5
LiberationFrequency
In soccer I like to keep shutter around 1/2000, and whatever the iso ends up being, thats what it is. I regularly end up shooting iso400 during daytime to keep the shutter up (clouds depending) and leaning to the right a touch. It might seem excessive but the noise is basically non-existent if you frame it right.
LiberationFrequency is offline   Reply With Quote
Old 7th of November 2010 (Sun)   #6
canonnoob
canonnoob's Avatar
ISO? I would assume you didnt have the ISO pushed too much, these are at least 1/3rd stop or so underexposed. That is contributing to the issue.
Gear
Model Mayhem
SportsShooter
Old 7th of November 2010 (Sun)   #7
DHMN
This kind of does sound like blaming the lens though....
The biggest problem in your comparison is.. the shots with the 55-250 were shot in sunlight.. these all look like late afternoon and cloudy so I doubt that ISO 400 even at F2.8 would be enough in the given situation.
EOS 7D Sigma 70-200 F2.8 (1.4 extender outdoors) are the workhorses. 50D for backup, EF 70-300MM USM f/4-5.6 IS, Freelance photographer for local newspapers and my website viewthroughmylens.net
DHMN is offline   Reply With Quote
Old 7th of November 2010 (Sun)   #8
pprice
pprice's Avatar
Underexposed for sure is one of your issues (as said), and I agree you need a fester shutter speed for these (maybe due to the fast action, camera shake, who knows).
It is pretty easy to tell if you have a sharp copy just by throwing it on a tripod and taking some controlled shots.
1D MKIII 16-35 2.8L MKII 24-70 2.8L 70-200 2.8L IS 300 2.8L IS (few others) Bunch of AB lighting
Southern by the grace of God
pprice is offline   Reply With Quote
Old 7th of November 2010 (Sun)   #9
chrisg19
I have found that if it isn't absolutely necessary I try not to use the 2.8 with the lens for best sharpness as well. It seems when it is opened all the way up it is not as sharp. When you have to use it for indoors or something, then the 2.8 is great, but if I am able to, I use something higher.
chrisg19 is offline   Reply With Quote
Old 7th of November 2010 (Sun)   #10
llie19
I see. Part of my mistake must be that I am still doing things the old way by not setting shutter speed high enough (55-250 has a max aperture of 5.6 on the long end, and I don't like high ISO if I don't absolutely need to), and the results is some motion blure especially on the ball. That makes sense, will raise the shutter speed next time. I guess with f/2.8 doubling the shutter speed from before is not a problem.
Old 7th of November 2010 (Sun)   #11
llie19
I used evaluative metering for these, should I have looked at the photos and decide to up the exposure compensation? I raised the exposure and brightness in LR, but I agree some still look underexposed. How do you all set the metering on a cloudy day? Thanks.
Old 7th of November 2010 (Sun)   #12
SuzyView
Ms Moderator and Grandma
SuzyView's Avatar
I haven't read if you did any sharpening to the final images. There is always some USM needed even if you shoot 1/1000. I shot at 1/2000 yesterday with my 7D and 70-200 2.8 IS Ver I and the images turned out fine, but I still needed some tweaking. It's normal to do that. Also, ISO was at 100-200 as it was very bright. Wide open, f2.8 is great, go to 4.0 and it's really great. Your shots are acceptable. It's really in how you are capturing the images and how you're sharpening after.
5D2 7D & G12, the new iPad, iPhone 5 , 5 L's & 2 Primes 23 bags - 4 Domke, 3 Lowepro, 1 Crumpler, 2 Tamrac, 5 Kata, 3 Thinktanks, 1 Pelican, 1 Tenba bag, 1 Epiphanie Paris & 2 Coach Handbag! And no excuses.
My children are the reason, but it's the passion that drives me to get the perfect image of everything.
My Gear and Wishes
SuzyView is online now   Reply With Quote
Old 7th of November 2010 (Sun)   #13
Dennis Valet
Also, any post processing on these? Doesn't look like you sharpened them in LR or PS
Dennis Valet is offline   Reply With Quote
Old 7th of November 2010 (Sun)   #14
llie19
OK, that part I was questioning the lens performance, but I was really just worried. In hindsight I guess if you want 1/2000 shutter speed at 2.8, you might have to bump ISO to as high as 800? I shot in manual mode, and set the shutter speed and aperture, and let ISO be automatic, is this a good way to shoot under this condition?
Old 7th of November 2010 (Sun)   #15
SuzyView
SuzyView's Avatar
I set my ISO as low as it can get, around 100-400 outdoors, 5000 on my 7D the other night for football. Aperture makes a huge difference for sharpness and speed, so f2.8 is really pushing it. I only shoot 2.8 in extreme conditions, not in bright light, but at night, don't have much of a choice. Still, I shoot M as well, speed is what I adjust most of the time.
My Gear and Wishes
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Outing with 30 palaima Critique Corner 2 14th of February 2010 (Sun) 07:01
First outing with the 5D II cadams Birds 7 9th of February 2009 (Mon) 19:59
70-200 2.8L 1st outing. Steve Greenaway Sports 20 14th of February 2008 (Thu) 14:55
First outing with my MK3 KevB Birds 10 30th of January 2008 (Wed) 02:54
My first outing with the 10D Kenal0 Canon EOS Digital Cameras 9 30th of June 2003 (Mon) 12:36
