Reply
Thread Tools Display Modes
Old 10th of November 2010 (Wed)   #1
peregrineflier
peregrineflier's Avatar
Default What makes IS work?
Hi, it seems like my IS works better in brighter light, but I really don't know what makes it work, so I am not sure what to make of this. : )
Tom
Thanks, Tom the Peregrineflier Lyle Washington
Canon 1D mk3, Canon 100-400 L, Canon 300mm f/4L IS
http://peregrineflier.smugmug.com/
peregrineflier is offline   Reply With Quote
Old 10th of November 2010 (Wed)   #2
wunhang
Default Re: What makes IS work?
From wikipedia....
In Nikon and Canon's implementation, it works by using a floating lens element that is moved orthogonally to the optical axis of the lens using electromagnets.[3] Vibration is detected using two piezoelectric angular velocity sensors (often called gyroscopic sensors), one to detect horizontal movement and the other to detect vertical movement.[4] As a result, this kind of image stabilizer only corrects for pitch and yaw axis rotations,[5] and cannot correct for rotation around the optical axis. Some lenses have a secondary mode that counteracts vertical camera shake only. This mode is useful when using a panning technique, and switching into this mode depends on the lens; sometimes it is done by using a switch on the lens, or it can be automatic.
Some of Nikon's more recent VR-enabled lenses offer an 'Active Mode' that is intended to be used when shooting from a moving vehicle, such as a car or boat, and should correct for larger shakes than the 'Normal Mode'.[6] However, Active Mode, when used under normal shooting conditions, can result in poorer results than the 'Normal Mode'.[7]
Most manufacturers suggest that the IS feature of a lens be turned off when the lens is mounted on a tripod as it can cause erratic results and is generally unnecessary. Many modern image stabilization lenses (notably Canon's more recent IS lenses) are able to auto-detect that they are tripod-mounted (as a result of extremely low vibration readings) and disable IS automatically to prevent this and any consequent image quality reduction.[8] The system also draws power from the battery, so de-activating it when it is not needed will extend the time before a recharge is required.
Canon 5D II | Canon XSI (IR) | 35 L f/1.4 | 17-40 L f/4.0 | 24-105 L f/4.0 IS | 70-200 L f/4.0 IS | Zeiss 100 MP | C/Y 50mm f/1.7
::SmugMug::
wunhang is offline   Reply With Quote
Old 10th of November 2010 (Wed)   #3
Steve-R
Steve-R's Avatar
The IS system is not affected by light levels. It relies on measurements from the rate gyros to counteract the rotational movement of the lens. The autofocus system, on the other hand, will work better in brighter light, so perhaps you are seeing the effect of more accurate focus on your photos.
Another factor could be that brighter light means faster shutter speeds available, so the IS system will have less movement to correct for (less work to do).
Steve
Canon 40D,
10-22, 28-105, 70-300 f/4-5.6, 100 f/2.8
Tamron 17-50 f/2.8, Tokina 10-17 Fisheye, Tokina 35 f/2.8
Steve-R is offline   Reply With Quote
Old 10th of November 2010 (Wed)   #4
Replaces
Replaces's Avatar
+1 on that.
"If you don't walk today, you have to run tomorrow."
Nikon, then Canon, then Nikon again. But I still love POTN over NikonCafe.
Nikon D90, MB-D80, Nikkor AF-D 50mm f/1.8D, AF-S 18-105mm f/3.5-5.6G VR, Nikkor AF-S 24-70mm f/2.8G, Nikkor AF-S 70-200mm f/2.8G VR.
Replaces is offline   Reply With Quote
Old 10th of November 2010 (Wed)   #5
sangjiny
sangjiny's Avatar
Yup.
Leica M9
Pentax 645D
Rolleiflex 2.8FX
Mamiya 7
Zeiss ZI Ikon
sangjiny is offline   Reply With Quote
Old 10th of November 2010 (Wed)   #6
CyberDyneSystems
Wait, all that time and all I get is "Cream of the Damn Crop" ?!!!!!!!!!!!!!!!!
CyberDyneSystems's Avatar
More reading here;
http://photography-on-the.net/forum/...24#post1066324
CyberDyneSystems is online now   Reply With Quote
Old 10th of November 2010 (Wed)   #7
gasrocks
gasrocks's Avatar
Electricity?
gasrocks is offline   Reply With Quote
Old 10th of November 2010 (Wed)   #8
richardfox
richardfox's Avatar
Originally Posted by gasrocks View Post
Electricity?
Yeah. I invented electricity several years ago. I get a royalty of .01 per volt. Please forward your check as you're past due!
The autofocus systems draw from the camera battery just like the IS.
Canon 50D gripped, EF 50/1.8, EF-S 10-22, 17-40L, 24-105L, 70-200 f/2.8L, 100/2.8 macro, 100-400L, 300 2.8L, Canon 500 f8 mirror with chipped EF mount, 580EX, 1.4x and 2x Canon teleconverters, Canon EF Life-Size converter.
richardfox is offline   Reply With Quote
Old 10th of November 2010 (Wed)   #9
Wade Rose
Wade Rose's Avatar
wow I have to remove my lightning rod from my Lens LOL
Wade Rose
All photos posted on flickr
http://www.flickr.com/photos/60992828@N00/
Canon 5D mark II
Canon 40D
Wade Rose is offline   Reply With Quote
Old 10th of November 2010 (Wed)   #10
Gabe63
If you have bright light you dont need IS.
16-35IIL, 50L, 70-200 2.8 IS L, 200L F2.
Gabe63 is offline   Reply With Quote
Old 10th of November 2010 (Wed)   #11
dektol
Is is the best thing that ever happened for me! Bright Light don't do anything for me, as I am 80 years old and need all the help I can get.
Dave
dektol is offline   Reply With Quote
Old 10th of November 2010 (Wed)   #12
turkleten
+1
Your shutter speed takes care of that!
7D | 50mm ƒ1.4 | 17-50 ƒ2.8
Gear | Feedback
turkleten is offline   Reply With Quote
Old 10th of November 2010 (Wed)   #13
ScullenCrossBones
ScullenCrossBones's Avatar
Al Gore invented IS. And on the seventh day, he rested.
Gear
Mama done took my Kodachrome away...
ScullenCrossBones is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Which EOS makes the Best IQ? Chappy Canon EOS Digital Cameras 7 13th of December 2009 (Sun) 20:12
What makes RAW different? battletone RAW, Post Processing and Printing 5 1st of October 2009 (Thu) 22:25
What makes a pro...a pro? picturepages General Photography Talk 56 26th of March 2006 (Sun) 22:19
My Break at Work... Yeah I bring a camera to work. cjm Urban Life & Travel 20 15th of September 2005 (Thu) 22:30
