Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > RAW, Post Processing and Printing
Reply
Thread Tools Display Modes
Old 12th of November 2010 (Fri)   #1
Oppositeday
Default Purple spot... [Images inside]
Working yesterday, and everything looked fine in camera, then I get home and get them on the computer... There is this purple spot in a lot of the shots. Not ALL of them, just some of them. I don't think it's light flare, because it's in some, and not in others, that are taken in the same spot with the same amount of light.
Anyone have any ideas? I've never had this problem with this lens before....
edit for sizing. re-sizing one sec.
http://imgur.com/ne1z6.jpg
http://imgur.com/E1BDO.jpg
And no spot here, though it was taken in the same spot, same settings....
http://imgur.com/jQ67m.jpg
FLICKR
Oppositeday is offline   Reply With Quote
Old 12th of November 2010 (Fri)   #2
JakAHearts
JakAHearts's Avatar
Default Re: Purple spot... [Images inside]
Do you have a filter on your lens? I cant see the images at work but it sounds like that could be it.
JakAHearts is offline   Reply With Quote
Old 12th of November 2010 (Fri)   #3
chauncey
chauncey's Avatar
Looks like lens flare, would not necessarily be present in all images. Where you using a lens shield?
Gear...Ds Mk III, 16-35 f/2.8, 24-105 f/4.0, 70-200 f/4 and f/2.8, 300 f/2.8, and assorted other stuff.
chauncey is online now   Reply With Quote
Old 12th of November 2010 (Fri)   #4
Oppositeday
No filter, and had a lens hood on it. Some of the ones with the spot were taken with no visible light source other than above. I really couldn't see it being flare, thought I could be wrong.
FLICKR
Old 13th of November 2010 (Sat)   #5
Lowner
"I'm the original idiot"
Lowner's Avatar
I can only see it in the first image. Is it possible its a shop sign?
As you say, flare seems an unlikely cause given the location. Odd reflective surfaces can always surprise though.
Richard
http://rcb4344.zenfolio.com
Lowner is offline   Reply With Quote
Old 13th of November 2010 (Sat)   #6
TTk
TTk's Avatar
Take a shot of a white wall (inside or outside) and see if you have the purple mark then.
TTk is offline   Reply With Quote
Old 13th of November 2010 (Sat)   #7
weeatmice
weeatmice's Avatar
What lens are you using? It appears that it happens at a different place (unless you cropped these images?) so that indicates its not a sensor thing. Does it happen with many lenses or just this one?
Doesnt quite look like lens flare to me besides the lighting isnt so harsh to expect lens flare in the first pic at least.
Twopixel.co.uk | 500px | flickr | Twitter | Pinterest
weeatmice is offline   Reply With Quote
Old 13th of November 2010 (Sat)   #8
René Damkot
Moderator
René Damkot's Avatar
What software? Possibly you unintentionally copied over a local adjustment done to another image in LR using synchronise?
Why Color Management.
Color Problems? Click here.
MySpace
Get Colormanaged
Twitter
René Damkot is offline   Reply With Quote
Old 13th of November 2010 (Sat)   #9
Oppositeday
It's in the second one as well, right over his right eye
Tried this, no purple mark
Some of them are cropped yes, and it's generally in the same spot.
And I don't think this happened. I'm very meticulous in lightroom, though I suppose it is a possibility. I don't see it happening multiple times though.
FLICKR
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
The 7D's spot AF works great, picture inside 2004ep3hatch Canon EOS Digital Cameras 11 19th of April 2010 (Mon) 23:32
Help: Purple spot on LCD screen - Canon SD790 New_sd Small Compact Digitals by Canon 6 18th of August 2009 (Tue) 23:09
Red On the Outside, Purple on the Inside IzakTaylor Macro 2 18th of May 2007 (Fri) 04:27
Purple Spot Problem mrr74 Canon EOS Digital Cameras 14 10th of February 2007 (Sat) 19:00
Black spot on the camera- inside hawk911 Canon EOS Digital Cameras 4 31st of December 2006 (Sun) 17:44
