Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Talk About Photography > Sports Talk
Reply
Thread Tools Display Modes
Old 2nd of September 2005 (Fri)   #1
smassey
Default Polarizers and Sports Photography
Hi everyone. I recently picked up a Canon 70-200L F/2.8 lens that I plan on using for sports photography. When I was at the camera store, the salesman said that I would eventually need a polarizer if I plan on shooting outdoors.
Does anyone use a polarizer when shooting outdoor sports photography?
Sean Massey
Massey Photography
Canon 20D
Canon Digital Rebel XT (backup)
Canon 70-200 f/2.8L
Canon 50mm f/1.4
Sigma 28-105 f/2.8-4.0
Epson Stylus Photo R1800 Printer
smassey is offline   Reply With Quote
Old 2nd of September 2005 (Fri)   #2
CoolToolGuy
Boosting Ruler Sales
CoolToolGuy's Avatar
Default Re: Polarizers and Sports Photography
I use one whenever I can (when there is enough light). A polarizer makes the colors more pure and gives better saturation by reducing the reflections. Racecars, sports jerseys, even the grass on a field all respond to a polarizer.
When I buy a new lens I get a UV filter for it and I make sure that I have a polarizer that fits it. If it is a new filter size I get a new polarizer in that size.
My 2 cents.
Have Fun,
Rick
My Gear list
CoolToolGuy is offline   Reply With Quote
Old 2nd of September 2005 (Fri)   #3
gasrocks
gasrocks's Avatar
Polarizers cost you a variable amount of light, usually 3-4 f/stops. Many sports pix wouldn't happen with that loss. Poliz. work sometimes in some situations, I doubt I would have it along if I was only going out for sports pix. Depends on the sport, of course. I am thinking action, and close-ups of action. A wide scenic shot of the golf course would be another matter.
gasrocks is offline   Reply With Quote
Old 2nd of September 2005 (Fri)   #4
CoolToolGuy
Geez, what polarizer do you use? The rule of thumb that I have used for 30 years is 1.5 to 2 stops. That is workable - but if you cut 3-4 stops it can make a difference. I would shop for another brand of polarizer if you are losing 4 stops.
Have Fun,
Rick
My Gear list
Old 2nd of September 2005 (Fri)   #5
frydryce
frydryce's Avatar
the extra stop can help you to have a slower shutter speed with lower apertures to capture motion blur nicer. ived used it for some motor sports events successfully.
however as soon as the sun starts setting you'd want to take off the polarizer.
and like said above, it all depends on what you want to do. outdoors photography doesnt require a polarizer. its just a sales point that salespeople use to get you to buy high margin items.
Canon
40D - Canon 17-55 f/2.8 IS - Tamron 28-75 f/2.8 - Sigma 70-200 f/2.8 - Sigma 1.4x TC
...Great images are a result from the lens behind the camera... Flickr!
frydryce is offline   Reply With Quote
Old 2nd of September 2005 (Fri)   #6
Curtis N
Master Flasher
Curtis N's Avatar
I don't know where you buy your polarizers, but one like that could also be used as a lens for a welding helmet.
1 1/2 - 2 stops would be a closer approximation.
Chicago area POTN events
Flash Photography 101 | The EOS Flash Bible | Techniques for Better On-Camera Flash | How to Use Flash Outdoors | Excel-based DOF Calculator
Curtis N is offline   Reply With Quote
Old 2nd of September 2005 (Fri)   #7
Paul_B
I also have a 70-200 2.8 Sigma, that I use mostly for the same thing. Would anyone have (or link to) a before and after. I'd like to see the difference. If it gives it a good "punch" to the pictures, I'd like to buy one and try it.
I've never or owned any, do they come in certain color's for different scenes ?. What kind would one want for outdoor soccer ?.
1D Mk2N / 20D
Sigma 17-70 F2.8 - 4.5 Macro DC
Canon EF 100-400 L IS
Sigma 70-200 2.8 EX HSM
Nifty Fifty
Paul_B is offline   Reply With Quote
Old 2nd of September 2005 (Fri)   #8
smassey
I plan on shooting a lot of soccer and tennis during afternoon games, and my problem is the outdoor stadium I am in gets a lot of direct afternoon sun. This tends to blow out the white jerseys of the home team. Would a polarizer help in that situation?
Sean Massey
Massey Photography
Canon 20D
Canon 70-200 f/2.8L
Canon 50mm f/1.4
Old 2nd of September 2005 (Fri)   #9
CoolToolGuy
There are different quality levels, like all filters - cheap ones, Hoya and B+W, plain and muli-coated. In addition, there is a type known as a Kaesemann (sp?) that is supposed to produce better results. But none of those intentionally produce different colors.
There are some exceptions. One criticism of polarizers is that they make the colors (especially the sky) colder. There are warming polarizers that have a colored glass that warms up the colors a bit. I see and understand the propaganda, but I have never seen the need to get one. Some day I may try one and do a comparison. In addition, there are now some other color-enhancing polarizers, but they are pretty specialized, and very expensive. I found this link on them:
http://www.singh-ray.com/polarizers.html
As for the comment that outdoor photography doesn't require a polarizer, I suggest you take a polarizer outside and train it on a car in the sun, especially including the windshield. Turn that baby (the polarizer) through a couple of revolutions and you will see the colors become purer as the reflections are reduced, and you will find the point at which you will be able to see right through the windshield. With a driver there (like in a race car) it can make all the difference.
My additional 2 cents.
Have Fun,
Rick
My Gear list
Old 2nd of September 2005 (Fri)   #10
grego
grego's Avatar
For sports, you'll be fine with a UV filter. You can use a polarizer, but you'll be fine with an affordable UV filter.
Go UCLA!! |Gear|SportsShooter|Flickr|
grego is offline   Reply With Quote
Old 2nd of September 2005 (Fri)   #11
Elisabeth-Ann
Elisabeth-Ann's Avatar
I use a polarizer or ND filter for landscapes and especially since I live in an area where the sun shines a lot, and we have a lot of sand and sea, hence a lot of glare. I don't use it for action shots, always have a UV filter on my lens.
Twelve significant photographs in any one year is a good crop. -Ansel Adams
Please visit my website at www.expressionsbyann.com
350D
300D
Tokina 24-70mm
Canon 75-300mm, Canon 430EX Speedlite
18-55mm kit
Singh-Ray gold'n'blue polarizer
Tiffen ND, and polarizer
Elisabeth-Ann is offline   Reply With Quote
Old 2nd of September 2005 (Fri)   #12
Wilt
Wilt's Avatar
<I plan on shooting a lot of soccer and tennis during afternoon games, and my problem is the outdoor stadium I am in gets a lot of direct afternoon sun. This tends to blow out the white jerseys of the home team. Would a polarizer help in that situation?>
The prime benefit of a polarizer is that it can reduce the amount of light which is reflected off a surface, but only if it hits your lens from a certain angle. That is why you can see some reflected light disappear, while some also appears affected very little.
Any light bouncing off the jerseys MIGHT be polarized and would be reduced by the filter, but much of the brightness is simply the relative intensity of the jerseys in the sunlight rather than any polarization of that light!
Wilt is online now   Reply With Quote
Old 2nd of September 2005 (Fri)   #13
KennyG
KennyG's Avatar
A downside with using a polarizer for motorpsort is it can show up the stresses in laminated widshields at certain angles. As you have no control over the angle of a racing car, it is really only of any use on open wheel single seaters, and even then due to the changing angles it is hit-miss.
For 'blown out' clothing, such as jerseys, the problem is exposure, not reflected light and a polarizer is unlikely to help.
Ken
Professional Motorsport Photographer
2 x 1D MK-II, 7D, 17-40L, 24-70L, 70-200 2.8L IS, 100-400L,
300 2.8L IS, 500 4.0L IS, 85 1.8, 50 1.4, 1.4 & 2.0 MK-II TC.
KennyG is offline   Reply With Quote
Old 2nd of September 2005 (Fri)   #14
CoolToolGuy
I haven't sold nearly as many images as Kenny, but for closed cars the difference between seeing a reflection of the sky in the windshield and seeing the driver is enough for me. And the difference between glare coming off of the hood and fenders and the color of the car is significant as well.
Then again, he shoots a lot in the UK - I heard that the sun actually came out during a race there once
Have Fun,
Rick
My Gear list
Old 2nd of September 2005 (Fri)   #15
neil_r
Cream of the Proverbial Crop
neil_r's Avatar
Originally Posted by CoolToolGuy
I
Thats right...... They had to red flag it.
Neil - © NHR Photography
There are no rules for good photographs, there are only good photographs. ~ Ansel Adams
neil_r is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Sports photography with a S3 IS ddphoto Canon G-series Digital Cameras 9 30th of July 2007 (Mon) 21:11
cheap polarizers vs expensive polarizers Livinthalife Canon EF and EF-S Lenses 32 1st of May 2007 (Tue) 17:20
sports photography fox au Sports Talk 7 16th of March 2007 (Fri) 21:39
Help with sports photography Ron Burgundy Canon EOS Digital Cameras 14 19th of July 2006 (Wed) 14:01
Polarizers in auto photography KennyG Accessories & Storage 6 15th of February 2004 (Sun) 20:50
