Thread started 17 Nov 2010 (Wednesday) 02:30
Scan or photograph old photos?
hania
Nov 17, 2010 02:30 |  #1
Any ideas which may give the better results?
Scanning will takes ages but can do a whole sheet at a time - these are photos from the 1940's and so are only about 3x2 in.
photographing - can get in really close with macro lens - but have to do each individually - could do a whole page i suppose but harder to get exactly parallel.
any ideas ? not sure if this is in right place; I did try searching forums but didn't find anything.
crn3371
Nov 17, 2010 08:50 |  #2
I'd get an inexpensive flatbed scanner. They should scan fairly quick as you don't need to scan at a very high resolution for prints. 300 dpi, 600 dpi max.
ChasP505
"brain damaged old guy"
Nov 17, 2010 10:27 |  #3
hania wrote in post #11299077 (external link)
Any ideas which may give the better results?.
Scan. But first get Ctein's book, Digital Restoration from Start to Finish, 2nd Edition.
Also Katrin Eismann's Photoshop Restoration & Retouching.
Chas P
"It doesn't matter how you get there if you don't know where you're going!"http://photography-on-the.net …p?p=10864029#po​st10864029
mbellot
"My dog ate my title"
Nov 17, 2010 10:27 as a reply to  @ crn3371's post |  #4
The other issue with photographing the prints will be lighting/glare.
Get a scanner, it will be much faster and give more consistent results.
Wilt
Nov 17, 2010 10:45 |  #5
I got curious about the relative quality, so I just did this quick test. I took a 4x6 photo (originally shot on film), and scanned it with a Canon 8800F scanner at 600 dpi. Then I photographed it using a 40D with a Tamron 90mm f/2.5 macro lens at ISO 400 using f/4, mounted on tripod (admittedly shot under CFL, so I had to correct WB during post processing) as a RAW file converted with Lightroom 2.
As scanned, the result was 3512x2376 pixels; as shot the result was 3888x2592 pixels. I then took about a 10% section of each photo (leaving sections at 100%)...
As scanned...
http://i69.photobucket​.com …ltonw/as_scanne​dphoto.jpg (external link)
As shot...
http://i69.photobucket​.com …ltonw/as_photog​raphed.jpg (external link)
Not sure if I could improve the photographic version with changes in post processing settings or by shooting at f/5.6, but based upon this quick test, I would not bother with the photography, but I would use the scanner.
You need to give me OK to edit your image and repost! Keep POTN alive and well with member support http://photography-on-the.net/forum/donate.p​hp
René ­ Damkot
Nov 17, 2010 10:54 |  #6
I'd take a look at your sharpening / NR settings in LR. Or try DPP.
The "shot" image could be much better with decent sharpening IMO.
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
Wilt
Nov 17, 2010 11:06 |  #7
René Damkot wrote in post #11300611 (external link)
Originally used sharpening settings of 132/1.7/57/49 in LR. I altered the Radius from 1.7 to 3.0 and output this, as shot...
http://i69.photobucket​.com …/i63/wiltonw/as​_shot2.jpg (external link)
As scanned...
No doubt futher tweaking of brightness and contrast, etc. in post processing could get more improvement from the as-shot version, but with the immediate and easy superiority of the scanned version, I don't think I'd want to spend the time and effort of tweaking the photographic process further. Way too easy to plunk the photo on the scanner, compared to having to mount it temporarily on a flat surface to photograph.
René ­ Damkot
Nov 17, 2010 11:29 |  #8
Wilt wrote in post #11300665 (external link)
Agree with that.
Oh, and linked the images since they were larger then 1024 px ;)
Wilt
Nov 17, 2010 11:34 |  #9
René Damkot wrote in post #11300803 (external link)
Agree with that.
mea culpa! Thanks for remedying the oversight, René. My brain had 1280 as the max just now.
ChasP505
Nov 17, 2010 11:59 as a reply to  @ Wilt's post |  #10
I scan old photos at 600dpi, 48 bit mode (16 x 3), and either Adobe RGB or ProPhoto RGB.
When rephotographing, there's no reason not to use HDR techniques just like any other photography.
Chas P
kirkt
Nov 17, 2010 12:33 |  #11
As long as your scanner is set up correctly and profiled, like your camera (in RAW) is, then color reproduction should be no problem. If your scanner produces color results that shift or cause issues in a color managed workflow, then you should address that before having to correct all of the images you scan. With photographing using RAW, you can shoot a CC target under the lighting conditions you set up (2 lights at 45 degrees to the photo surface) and get an accurate color profile that you can apply in batch to all of the images, in a RAW converter like LR.
If the photos are aged and may have issues with mounting for photography or may get damaged in a flatbed scanner, that may something to consider.
Kirk
Kirk
hania
Nov 17, 2010 13:12 as a reply to  @ kirkt's post |  #12
many thanks to you all - shall scan I think !
tonylong
...winded
Gallery: 60 photos
Nov 17, 2010 14:48 |  #13
I haven't used a scanner in some time, but I know that at least some scanning software will recognize multiple "objects" which could be a huge plus with smaller photos -- scan 6 or 8 snaps at a time and they are automatically saved as separate images.
Tony
René ­ Damkot
Nov 17, 2010 15:11 |  #14
tonylong wrote in post #11301895 (external link)
Photoshop (CS and newer I think) can do this as well.
http://help.adobe.com …3e41001031ab64-762ea.html (external link)
8,191 views & 0 likes for this thread
version 2.0 /
Latest registered member is ppahv
746 guests, 393 members online
