#1 |
Hi all,
I've been reading up on the iMac calibration issues people have had, and it's making me stress! So, I'm hoping someone can suggest a tried and true method of getting screen and print colours matching up? Some people say Colormunki, others use the Spyder, I just want to know which will give me solid results and is fairly easy to use. I use a Canon 7D and Aperture, do I need to calibrate these? If not, what colour setting should I be using. Finally, what photo printer do you guys use? I need to get a new one, but would like to hear what is suggested first. Thanks. |
| sponsored links |
#2 |
"brain damaged old guy"
ColorMunki, Spyder3 Elite, or ColorEyes Display Pro software with the puck of your choice will all be able to calibrate the iMacs automatically via software... No need to make any adjustments via monitor controls.
My first choice would be the ColorMunki since it does a great job of monitor calibration AND creates custom printer profiles. Second choice, CEDP software. For a printer, I have a long discontued HP 8750. It uses 9 inks, including black, medium gray, and light gray, for excellent B&W. Among current printers, look at the Epson 2880 or 3880, or the Canon Pixma Pro 9000 MkII and 9500 MkII.
Chas P "It doesn't matter how you get there if you don't know where you're going!" Last edited by ChasP505 : 18th of November 2010 (Thu) at 07:57. |
#3 |
Have you actually calibrated an iMac 27" with any of these devices? If so which did you use/which gave the best results?
I have read the luminance is an issue which must be addressed with ColorEyes, and the reflective screen also gives trouble. Not to mention a lot of poor reviews for all on Amazon. Until I hear from iMac owners who have successful calibrated their own, I'm a bit nervous about taking a leap. Thanks for the printer suggestions. 9000 looks good. |
| sponsored links |
#4 |
I realize this is now an older post but..
I've had the same issues trying to find the right device to calibrate my 27" iMac as well. I tried the Eye-One display 2 and that didn't work because you can't adjust the RGB sliders. However, I discovered that you can use the puck along with the ColorEyes and it will create a profile. What sucked though is... once i made a profile i was NOT happy with the results because the screen was so dim and the colors all seemed to get muddy and washed out instead of "popping" like they do when i have my iMac set to default. *Sighhhh* .. so, I'm thinking of buying a Color Munki at this point. I really don't want to spend the money but if it's going to do the job then it's money well spent. Does anyone know how close or far off iMacs tend to be right out of factory anyway?? Cheers, Kelli |
#5 |
Kelli, you can buy a Spyder3 Express kit and use the hardware with your ColorEyes software. The Spyder3 puck is more suited for wide gamut and LED backlit displays.
Chas P "It doesn't matter how you get there if you don't know where you're going!" Last edited by ChasP505 : 10th of February 2011 (Thu) at 15:37. |
#6 |
Is that what you use for your own iMac? Sounds like a plan although there's alot of Spyder rumors and they're not good.
I'll look into it though, thanks! |
#7 | |
Yes, I still use a Spyder3 puck with CEDP software. |
#8 |
The Color Eyes comes with a Spyder 3 calibrator or you can buy the software stand alone. If you go with the Spyder 3 system make sure you get the Elite otherwise you can't set the luminance.
Out of the box the iMacs are too bright so your prints will be dark compared to the display. Otherwise the iMac display is very good. Also Color Eyes sells monitor hoods for the iMacs which are very helpful because of the glossy display. |
#9 | |
CEDP software automatically adjusts the Brightness of the iMac via DDC communication. You enter the target luminance value in the software and it automatically sets the monitor brightness. |
#10 |
I see that the CEDP adjusted the brightness nicely, but my colors look extremely desaturated. Is this normal??
#11 |
It often takes time to get used to a dimmer monitor. Judge from your screen to print matching.
#12 |
What Chas says.
Bohdan - I may be, and probably am, completely wrong. Gear List Montreal Concert, Event and Portrait Photographer Flickr |
#13 | |
I use a Canon Pro 9000 and I can get excellent screen print match using Canon's papers and inks. Attaching the correct print profile for your paper and ink combination is critical. Aperture gives you the opportunity to apply the correct profile at the print stage. But if you stray into using 3rd party papers and/or inks you can get you deep into colour problem solving while trying to establish a good print profile. My suggestion is 'don't go there' but if you do, you're likely to need a device for making print profiles too - in that case the Colormunki might be a good choice because you can use it to profile both monitor and printer paper/ink. Cheers Tim Last edited by Pekka : 27th of April 2011 (Wed) at 06:58. Reason: quote fix |
| Thread Tools | |
| Display Modes | |
| If I go iMac or MBP, do I need all new PP software?? | HarrisonClicks | Computers | 17 | 3rd of November 2009 (Tue) 13:21 |
| Which device do you use to calibrate your monitor? | Thorrulz | RAW, Post Processing and Printing | 40 | 5th of October 2009 (Mon) 00:39 |
| need a software to calibrate my monitor,please help me | mantra | RAW, Post Processing and Printing | 11 | 16th of June 2009 (Tue) 00:29 |
| Software to Calibrate Monitor | Souwalker | Accessories & Storage | 2 | 25th of July 2008 (Fri) 09:39 |
| software to calibrate monitor | jackprks | The POTN Lounge | 3 | 28th of July 2007 (Sat) 22:42 |
