Reply
Thread Tools Display Modes
Old 9th of December 2010 (Thu)   #1
tkbslc
Default Updated Tamron 18-270 announced.
Tamron just announced a new 18-270 model with "PZD" AF. Seems odd that it isn't USD like their new 70-300. ANyway, it's avaialble in like a week:
http://www.tamron.com/en/photolens/d..._one/b008.html
"The acclaimed Tamron 18-270mm VC ultra zoom for APS-C format DSLRs has reached an astonishing new level of compactness, performance, and speed with the addition of PZD (Piezo Drive), an innovative ultrasonic autofocus motor based on an advanced piezoelectric design. The result is a lens that's considerably lighter, and noticeably shorter and slimmer (filter diameter: 62mm) than any previous lens in its class, and provides faster, quieter auto-focusing. Signature features that have made this amazingly versatile lens the world standard in its class have been retained. They include a 28-419mm equivalent (15X) zoom range, an improved, lightweight, compact Vibration Compensation (VC) system, macro focusing to 0.49m (19.3 inches) throughout, and, of course, superlative imaging performance."
One cool thing is that it seems to be roughly the size of the old Tamron 18-200, which was really compact.
Taylor
Galleries: Flickr Photoshop.com
60D - ELPH 100HS - 15-85 - 30 1.4 - 50-135 2.8 - 55-250 IS
tkbslc is online now   Reply With Quote
Old 9th of December 2010 (Thu)   #2
nepali
nepali's Avatar
Default Re: Updated Tamron 18-270 announced.
http://photography-on-the.net/forum/...d.php?t=969701
[ Gears: 7D | Sigma 30 ƒ/1.4 | Canon 85 ƒ/1.8 | 430EX ]
[ Feedbacks:
#1, #2 ]
nepali is offline   Reply With Quote
Old 9th of December 2010 (Thu)   #3
gasrocks
gasrocks's Avatar
Gee gosh.
gasrocks is offline   Reply With Quote
Old 9th of December 2010 (Thu)   #4
themadman
themadman's Avatar
To save you all the trouble
From Wikipedia
Piezoelectric motors
Types of piezoelectric motor include:
The travelling-wave motor used for auto-focus in reflex cameras
Inchworm motors for linear motion
Rectangular four-quadrant motors with high power density (2.5 watt/cm3) and speed ranging from 10 nm/s to 800 mm/s.
Stepping piezo motor, using stick-slip effect.
All these motors, except the stepping stick-slip motor work on the same principle. Driven by dual orthogonal vibration modes with a phase difference of 90°, the contact point between two surfaces vibrates in an elliptical path, producing a frictional force between the surfaces. Usually, one surface is fixed causing the other to move. In most piezoelectric motors the piezoelectric crystal is excited by a sine wave signal at the resonant frequency of the motor. Using the resonance effect, a much lower voltage can be used to produce a high vibration amplitude.
Stick-slip motor works using the inertia of a mass and the friction of a clamp. Such motors can be very small. Some are used for camera sensor displacement, allowing anti shake function.
Will | WilliamLiuPhotography.com | Gear List and Feedback | CPS Member | Have you Pre-Ordered Your 3Dx Yet? | HorusBennu Discussion | In honor of Uncle Steve, thanks for everything! 10-5-2011
themadman is offline   Reply With Quote
Old 9th of December 2010 (Thu)   #5
tkbslc
Originally Posted by nepali View Post
I swear I looked.
Taylor
Old 9th of December 2010 (Thu)   #6
nepali
nepali's Avatar
I swear I looked.
LOL!
[ Feedbacks:
#1, #2 ]
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Tamron SP AF10-24mm Di II High-Performance Ultra Wide-Angle Zoom Lens Announced m-bartelt Canon EF and EF-S Lenses 4 3rd of September 2008 (Wed) 20:07
Tamron 28-75 v Canon 28-135 IS (Pictures inside) *UPDATED* OviV Canon EOS Digital Cameras 11 28th of February 2007 (Wed) 23:34
Tamron announced over a year ago Headcase650 Canon EOS Digital Cameras 0 19th of October 2004 (Tue) 18:30
