#1 |
Why do people say that FF has shallower depth of field than crop in the same conditions?
| sponsored links |
#2 |
Because to take the same image (same perspective, same framing) a FF camera must be shot with a lens focal length that is 60% longer.
That's really all it is, longer focal length (for the same photo) = shallower DOF.
My personal stuff:http://www.flickr.com/photos/jngirbach/ Commercial sports:http://girbach.zenfolio.com/ I use a Canon 5D and 1DIV and a Panasonic GF-1 Gear List: http://photography-on-the.net/forum/...postcount=1550 |
#3 |
They have the same focal length it's just cropped, but when I crop my images I don't really see a loss in the depth of field.
| sponsored links |
#4 |
If you use same FL, to get equivalent field of view on both you have to either move closer with the FF camera (less DOF) or back off with the crop (increased DOF).
Canon 5D, 50D EF 20mm f/2.8, EF 28mm f/1.8, EF 50mm f/1.4, EF 85mm f/1.8, EF 100mm f/2.8 Macro EF 24-85mm f/3.5-4.5, EF 70-210mm f/3.5-4.5 Mir-1B 37/2.8, Helios 44-2 - 58/2, Jupiter 11A - 135/4 |
#5 |
Yes, i know that distance is a factor in DOF, but this doesn't explain why FF has shallower DOF as other people said
#6 | |
Suppose you take a picture with a 7D using a focal length of 50mm. Now take the 7D off the tripod and mount a 5D. To take the same picture using the 5D you will have to use a lens with a focal length of 80mm. This change (from 50mm to 80mm) is why the FF camera has less DOF. If you take both pictures using a 50mm lens, the field of view from the 5D photo will be much larger and the pictures will not be the same (but will have essentially the same DOF).
#7 |
This is the best post regarding FF vs Crop DOF. http://photography-on-the.net/forum/...6&postcount=10
Read through the thread as well.
SOSKIphoto | Blog | facebook! 5D3 | EF 24-70 | EF 70-200 II | EF 28 f/1.8 | EF 50 f/1.4 | 600EX-RT's | |
#8 | |
This.... Or, use the same focal length in both cases and you have to move 60% closer to your subject to get the same framing.... Either way, the effective DOF is reduced with full frame. It's approx. one stop worth... i.e., f2.8 on a cropper equals f4 on FF, etc.
Alan Myers "Walk softly and carry a big lens." GEAR: 5DII, 7D(x2), 50D(x3), some other cameras, a bunch of lenses & accessories - FLICKR - PRINTROOM |
#9 | |
will have 0,5 ft DOF for FF sensor and 0,32 ft on 1.6x crop, which is actually the other way around (less DOF on the crop). The difference in the DoF comes only because to frame the same subject with the same FoV you need to move (change subject distance) or use shorter/wider lens on the crop.
Canon 5D, 50D EF 20mm f/2.8, EF 28mm f/1.8, EF 50mm f/1.4, EF 85mm f/1.8, EF 100mm f/2.8 Macro EF 24-85mm f/3.5-4.5, EF 70-210mm f/3.5-4.5 Mir-1B 37/2.8, Helios 44-2 - 58/2, Jupiter 11A - 135/4 Last edited by mury : 19th of December 2010 (Sun) at 18:58. |
#10 | |
But this difference is really small and totally swamped by the effect of focal length needed to frame the shot the same. IMO since you would never use the same focal length on each format, this information winds up being just a bit of trivia.
#11 |
This is why I got rid of my crop (40D) and moved to FF. Couldn't be happier!
5D | 7D | 50 1.4 | 24-105L | 70-200 2.8L | 580EX |
#12 | |
#13 |
Here is a sample I did comparing the DOF between the 7D and 5D2
7D | 100L | 24-70L | 70-200L f2.8 IS | Σ 50-500 OS | Σ 50 1.4 | Tok 11-16 | 18-55 IS | 55-250 IS Past Equipment | My Gallery | My Mini-Reviews Resources For Sale: Focus Genie MicroAdjustment Chart | Gel Genie Flash Gel Holder | High ISO Denoiser Action |
#14 |
#15 |
True, I was trying to show Jeffrey's point that assuming you want the same image across both, then only changing the FL gives that DOF difference. I really don't get the OP's question because I wouldn't really ever want to crop out a 1.6 crop's image from a FF, and lose all that resolution, I would rather zoom in a bit more (or foot zoom) at least so I don't crop as much.
| Thread Tools | |
| Display Modes | |
| Question for Lightroom users: Do you crop originals or make virtual copies to crop? | TMR Design | RAW, Post Processing and Printing | 54 | 7th of April 2012 (Sat) 21:45 |
| Crop an FF shot, or shoot crop? | Headshotzx | Canon EOS Digital Cameras | 39 | 1st of September 2009 (Tue) 00:09 |
| 10-22mm on 1.6 crop = What lens @ 1.3 Crop | Paul S | Canon EF and EF-S Lenses | 12 | 24th of May 2008 (Sat) 11:04 |
| crop vs full frame - anyone prefer a crop set up | bowlesbe | Canon EOS Digital Cameras | 124 | 12th of April 2007 (Thu) 21:20 |
| Summer Morning Haze - to crop or not to crop? | Sailor Don | Critique Corner | 5 | 26th of July 2004 (Mon) 04:34 |
