Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > The Business of Photography
Reply
Thread Tools Display Modes
Old 9th of September 2005 (Fri)   #1
joko
Default help with a dictionary
Hello to everyone,
I’m a foreign student of translation and for my final thesis I’m doing a bilingual dictionary on the subject of photography. I need some help with some terms and meanings.
1. telephoto lens, long-focus lens (Do these two terms have the same meaning? Which of them is used more often?)
2. golden section, golden ratio, golden mean (Are these terms interchangeable? Which is used more often?)
3. high camera angle, bird’s eye view (Do these terms have the same meaning?)
4. low camera angle, frog’s eye view (Do these terms have the same meaning?)
5. resin-coated paper, RC, PE, plastic paper (Are all these terms interchangeable?)
6. processing, developing?? (Do you say to develop a film, a picture or just to process it? So, do you talk about developing a picture (since you talk about a developer)…)
Thanks,
Jana
joko is offline   Reply With Quote
Old 9th of September 2005 (Fri)   #2
MattyB
MattyB's Avatar
Default Re: help with a dictionary
1. telephoto lens, long-focus lens (Do these two terms have the same meaning? Which of them is used more often?) i've only ever heard "telephoto" here in australia.
2. golden section, golden ratio, golden mean (Are these terms interchangeable? Which is used more often?) "golden mean" is the most popular
3. high camera angle, bird’s eye view (Do these terms have the same meaning?) i suppose they're roughly the same angle - as far as i know, 'birds eye view' is way up in the sky.
4. low camera angle, frog’s eye view (Do these terms have the same meaning?) never heard 'frogs eye view' before.
6. processing, developing?? (Do you say to develop a film, a picture or just to process it? So, do you talk about developing a picture (since you talk about a developer)…) the way i understand it, you process a digital image on your computer, and develop film negatives to turn them into prints.
i suppose you could process film aswell, but i've never heard of developing a digital image.
hope i helped.
Matt Bennell
Camera: Canon EOS 300D DSLR Black
Extras: 18-55mm, 50mm 1.8, Tripod, Imagination
Field: You name it, I've shot it.. Or about to shoot it today
Recently Updated Folio/Gallery -> http://mbp.fotopic.net/
MattyB is offline   Reply With Quote
Old 9th of September 2005 (Fri)   #3
Wilt
Wilt's Avatar
Technically 'long focus' is merely a long focal length that must be spaced that same distance to the film plane to focus. 'Telephoto' is a long focal length which can be physically closer than its focal length to be properly focused.
(off the top of my head, may not be totally accurate) Generally refers to the relative ratios of the lengths of side of photos, or placement of objects within the frame, etc. for 'good composition'
Similar, but not the same.
'High camera angle' just means higher than your usual eye-level view
'Birds eye view' is like the view seen if you are flying high above everything!
Similar but not the same:
'Low camera angle' probably applies to things seen from at or below your normal waist level .
'Frog's eye level'...from the ground.
Pretty interchangeable. Resin-coated started as conventional paper coated to be less absorbent of the photo chemicals in processing. Later evolved to use plastic in lieu of conventional paper base.
Equivalent terms in the chemical photography world. For digital, many people 'process' things in software like Photoshop, but no one 'develops'.
Wilt is online now   Reply With Quote
Old 18th of September 2005 (Sun)   #4
joko
thank both of you.
jana
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Photography Vocabulary Dictionary crayfish13 General Photography Talk 5 14th of February 2007 (Wed) 18:54
Photographic Dictionary 20droger The POTN Lounge 0 25th of December 2006 (Mon) 13:06
Photo Jargon Dictionary cjm General Photography Talk 34 20th of June 2006 (Tue) 15:32
Photography dictionary? Tmizzle Canon EOS Digital Cameras 3 24th of February 2005 (Thu) 15:55
The Photographers Dictionary garethhhhh The POTN Lounge 1 26th of April 2004 (Mon) 10:43
