Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Canon EOS Digital Cameras
Reply
Thread Tools Display Modes
Old 9th of September 2005 (Fri)   #1
Redbird_xo
Redbird_xo's Avatar
Talking To all prospective 5D purchasers
What is your number one reason to consider buying a 5D.
1. Sensor: 35.8 x 23.9mm CMOS sensor with essentially the same pixel density with the 1DMK2.
2. Viewfinder: Pentaprism, 0.71x magnification, 20mm eyepoint, 3 types of interchangeable focusing screens, etc. (Yes, just like the 1-series. True?)
3. Focusing system: 9-point AF (plus 6 invisible Assist AF points).
4. LCD monitor: 2.5" TFT, approx. 230k pixel.
5. Metering modes: The usual plus center spot metering (approx. 3.5% viewfinder at center).
6. ISO speed: 100-1600 (in 1/3-stop increments) plus the 50 and 3200 expansion by custom function.
7. Shutter release: Soft touch electromagnetic release.
8. File format: Folder creation & selection is possible.
9. Others. Please specify.
1. does it for me.
Redbird_xo is offline   Reply With Quote
Old 9th of September 2005 (Fri)   #2
cosworth
I'm comfortable with my masculinity
cosworth's Avatar
Default Re: To all prospective 5D purchasers
Sensor size. Nothing else. A 70-200 length should mean 70-200 etc.
In a couple years we'll have no complaints about sensor size...thus I shy away from EF-S lenses.
jasonhollister.com
Think your camera is noisy at high ISO? Click here
People will always try to stop you doing the right thing if it is unconventional
cosworth is offline   Reply With Quote
Old 9th of September 2005 (Fri)   #3
BillMarks
1 is the number one reason for me too. But if it didn't have 2, 5 and 6 I probably wouldn't be seriously considering it.
BillMarks is offline   Reply With Quote
Old 9th of September 2005 (Fri)   #4
RJCONKLIN
low noise at high iso
RJCONKLIN is offline   Reply With Quote
Old 9th of September 2005 (Fri)   #5
Andy_T
Hehe, shouldn't that read "A 17-40 lens should mean 17-40 mm"?
Most people don't exactly mind if their 70-200/2.8 'behaves' like a 100-300/2.8
Best regards,
Andy
Andy_T is offline   Reply With Quote
Old 9th of September 2005 (Fri)   #6
CorruptedPhotographer
CorruptedPhotographer's Avatar
you got it baby
Member since 2005 ^_^
CorruptedPhotographer is offline   Reply With Quote
Old 9th of September 2005 (Fri)   #7
mebailey
Number 1 does it for me. I can finally get my wide angles back.
mebailey is online now   Reply With Quote
Old 9th of September 2005 (Fri)   #8
ssim
ssim's Avatar
Basically I am a camera junkie. I probably didn't need to order it but for those occasions where my wide angles just aren't wide enough, this will partially fix it.
Most of the other things on your list I have in my 1DMKII.
Sheldon Simpson | My Gallery | My Gear updated: 20JUL12
ssim is offline   Reply With Quote
Old 9th of September 2005 (Fri)   #9
karusel
karusel's Avatar
While I really like 1. I don't much fancy 3. Also, I'll rather buy the 1.3x 1D MKII when it's price drops a bit more. I'm not that much of a pixel guy, right now 6 million of them are perfectly sufficient, as I don't like cropping my photos much.
5D and holy trinity of primes. Now the 90mm TS-E TS-E fly bit me. I hate these forums.
karusel is offline   Reply With Quote
Old 9th of September 2005 (Fri)   #10
Johnny Thunder
Caution, Cant keep clothes on
Johnny Thunder's Avatar
#1 for me, with #2 and #6 being Mighty fine as well, and truth be told, #4 is pretty nice.
-Johnny
T2i gripped with kit lens
Johnny Thunder is offline   Reply With Quote
Old 9th of September 2005 (Fri)   #11
cosworth
cosworth's Avatar
hmmm. buy a 20D now then sell it at a loss a couple years from now go get full frame... or buy a full frame 5D now, get the extended warranty and shoot with it as long as I did with my AE-1? Will technology just jump leaps an bounds again and again or will camera design/technology plateau for a bit and stabilize like we did from classic 35mm (ae1 MF stuff) to EOS and then EOS to EOS DLSR.
Go buy the camera you like...
jasonhollister.com
Old 9th of September 2005 (Fri)   #12
Pekka
El General Moderator
Pekka's Avatar
I was interested in 5D as a wide angle 2nd camera but it has too compromised a feature set to be truly "captive". And I have realised that for me a 1D series body is a requirement for practical reasons. But as I am sometimes in need of _very_ wide FoV, 5D would be a solution...
PS. If I had the money I would buy all Canons
This signature signifies my significance significantly
Photo Gallery
Pekka is offline   Reply With Quote
Old 9th of September 2005 (Fri)   #13
HrcRacing
HrcRacing's Avatar
Number one makes me want it but number $3,200.00 makes me think I'll just stick with my 10D.
Robert
Canon 40D | Canon EOS Elan 7
HrcRacing is offline   Reply With Quote
Old 12th of September 2005 (Mon)   #14
Jon
Moderator
Cocker Spaniel Mod
Jon's Avatar
How's this for rationalization?
I figure that by getting a FF body, I'll save the $500-$800 I'd otherwise have to spend on a 10-?? lens since I'll be able to use my current Sigma 15-30 as an ultra-wide! So a 5D will really only cost me between $2400-$2700, and I won't have that other lens to haul around.
Jon
EOS, Powershot and Domke - it doesn't get any better than this!
T90 and stuff | F-1n, New F-1, FTb and more stuff out on loan
Cocker Spaniels
DC Cherry Blossoms
Jon is offline   Reply With Quote
Old 12th of September 2005 (Mon)   #15
BlueTit
BlueTit's Avatar
Jon I love your logic, that's the way I go about justifying purchases that I really should not make. Number 1 and 5 do it for me. However I am interested in the new N too and cant decide which I would get the most use from, as they are both a lot of money I am treating them as the same price for comparison purposes, the debate goes on ... internally.
Daragh
Some Photos: http://www.flickr.com/photos/bluetit
BlueTit is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Recent purchasers of SanDisk 16gb Ext. III Beware.... paddler Canon EOS Digital Cameras 14 29th of May 2007 (Tue) 12:23
Choosing A3 Printer - Views from recent Purchasers Please Taxboy RAW, Post Processing and Printing 2 17th of February 2007 (Sat) 13:41
A610 Prospective Buyer koreyisbored Small Compact Digitals by Canon 3 25th of November 2005 (Fri) 13:37
Help with prospective purchase?? woollyback Canon EOS Digital Cameras 6 10th of October 2005 (Mon) 11:41
A few questions from a prospective G1 buyer... Paul V Canon G-series Digital Cameras 5 17th of July 2001 (Tue) 21:06
