#1 |
I was taking pictures today, and i had set my exposure comp at around -1 2/3. I had taken these photos (all in jpeg
![]() keep in mind this was shot around noon. anyway, i tried to salvage the images in photoshop, but could only manage to get this: ![]() I cant get the colors any more saturated, and everything is noisy and dull. do any of you pros have a way that i can salvage my photos in photoshop?
A560 will have to do... for now |
| sponsored links |
#2 |
Hi 4nR,
I'm not a pro. However, if you want the person to show better in a backlit situation. The exposure compensation should be +1 2/3, but not - 1 2/3. Samm |
#3 |
use the flash too
| sponsored links |
#4 |
Hiding Under a Rock
Try using the Shadows in Shadow/Highlights, you probably need to pull it up pretty high to get some detail in the shadow areas.
/Petra Hall Click here to view my geeky gear list I shoot as much as possible in available light... sometimes, my flash is available – Joe Buissink |
#5 |
i did use the shadows option, in addition to the exposure options as well (in cs2) and also screened several layers. the end result is the second photo. the colors are all washed out, and saturation doesnt seem to help either. are there any other tricks i can use?
#6 |
Hiding Under a Rock
Try this:
Auto Color (yeah, it's cheezy, but it helps a bit) Shadows/Highlights (set the amount to zero for highlights and full blast in shadows - 100%) and at the bottom with the color adjustments, blast that up too, to +100%. That should increase the color saturation. Since I'm sitting with a small image, it's hard to do much about it... but there's info there.
#7 |
when i increased the color sat, it just became messy. i think i might have to settle for just making it b&w. (repeatedly hits head against wall)
#8 |
Honorary Moderator |
We have a regular challenge in the competitions forum where people post under/overexposed photos so our serious PS gurus can work on improving them. I'd suggest posting your photo there.
This is a particularly good example: http://www.photography-on-the.net/fo...ad.php?t=81742
www.pbase.com/sam_blackie |
#9 |
Hiding Under a Rock
Since I don't know what you want from this image, it's a bit hard to edit it (plus it's a low-res image). But I'd suggest you try what I did.
1. Auto Color 2. Shadow/Highlights (full blast on Shadows, Highlights zero and at the bottom full blast on the color adjustment) 3. Play in curves or levels, plus perhaps increase saturation more 4. A pass through some noise reduction if it's too noisy This is my 2 min quick-fix: ![]()
#10 | |
#11 |
heres my quick attempt hahah. im not sure what you're looking for, but it seemed like you wanted higher sat, so i tried to raise it up a bit.
#12 |
Trigger Man - POTN Retired
My attempt. Pretty dull compared to Nicky's, but I was really trying to pull out the face. This is a great shot, by the way.
![]() And the History of what I did: Curves Curves Adjustment: curves adjustment list curves adjustment Channel: composite channel Curve: point list point: 0, 0 point: 21, 116 point: 83, 184 point: 136, 152 point: 222, 195 point: 255, 255 Shadow/Highlight Shadow/Highlight Shadow: Parameters Amount: 34% Tone Width: 24% Radius: 36 Highlight: Parameters Amount: 63% Tone Width: 50% Radius: 31 Black Clip: 0.01 White Clip: 0.01 Contrast: -19 Color Correction: 20 Flatten Image Flatten Image Play action “Contrast 6” of set “My Actions” Undo Redo Undo Redo Play action “sRGB” of set “My Actions” Export Using: Save For Web
You can take my 100-400 L away when you pry it from my cold, dead fingers. Scottes' Rum Pages - Rum Reviews And Info Finally, I have a Gallery! Follower of Fidget - Joined the cult of HAMSTTR© |
#13 |
thanks. I've actually moved this thread over to competitions, as suggested by big ben. http://photography-on-the.net/forum/...ad.php?t=97852
| Thread Tools | |
| Display Modes | |
| Ok so I screwed myself | 05Xrunner | Canon EF and EF-S Lenses | 28 | 6th of March 2006 (Mon) 01:16 |
| Did I get screwed? | MC82 | Canon EF and EF-S Lenses | 22 | 12th of September 2005 (Mon) 01:33 |
