Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Talk About Photography > Macro Talk
Reply
Thread Tools Display Modes
Old 27th of December 2010 (Mon)   #1
Ed The Shed
Ed The Shed's Avatar
Default Advice Needed Please on Set Up
Hi All,
Going to buy the Canon 100mm L Macro Lens soon and I'm looking at also getting the 580 EX II to go with it.
I have been reading the "Show Use Your Rig" thread to get some ideas.
However I need a little help with off camera brackets. I haven't got a clue on which would be better for macro stuff. The Delta flexible arm seems to grab me but have you guys got any thoughts please.
Also I'm going to need a diffuser for the flash, but again haven't got a clue, some people seem to use the Lumiquest mini softbox, are they any good ?
Just one last question, for now at least, do flashes come with a cable for use off camera or do I need to budget for one of those has well.
Thanks for you help
Ed The Shed is offline   Reply With Quote
Old 27th of December 2010 (Mon)   #2
racketman
racketman's Avatar
Default Re: Advice Needed Please on Set Up
you will need to buy an off camera cable, I have been using a Jessops version for some years without problems.
A home made diffuser like Brians is a good idea.
I have heard the Delta arm which you would have to order from US creeps a bit.
Toby
Flickr collections
ipernity gallery
Gear
racketman is offline   Reply With Quote
Old 27th of December 2010 (Mon)   #3
Ed The Shed
Thanks for that Racketman.
Creep - I hadn't thought of that so thanks.
Cheers for the link as well to the Jessops cable
I had thought about Brian's coke can diffuser but I'm not sure how robust it will be, I do tend to wander around quite a bit so it need to survive being in my camera bag etc....
Old 29th of December 2010 (Wed)   #4
archer1960
archer1960's Avatar
Even a white paper towel (or 2 or 3) over the flash can be a perfectly adequate diffuser.
T1i (500D), A2E film body, Tokina 11-16, Tamron 18-270 VC, Canon 85 f/1.8, Canon FD 100 f/4.0 macro, Canon EX-430 flash, Vivitar DF-383 flash, Astro-Tech AT6RC telescope, various other semi-crappy manual lenses and stuff.
archer1960 is offline   Reply With Quote
Old 30th of December 2010 (Thu)   #5
Ed The Shed
Thanks Archer.
I've order the lense and flash now, will have a go at Brians coke can diffuser. Still need to sort a bracket for holding the flash off camera.
Does anyone know if the 580EX would depress enough to cast light just in front of the 100mm macro
Old 30th of December 2010 (Thu)   #6
Wallpap3r
Wallpap3r's Avatar
x2 on the coke can diffuser. It is fragile but I guess if you make a box for it or something it wont get squashed as easily in the bag. Old metal video camera brackets work pretty well, Im using a really old straight light bracket at the moment and it works reasonably well. Ebay might have some
For the TTL cord I use an Opteka ttl flash cord. Seems like alright quality to me but not everyone seems to like it at much. It was $20 on amazon if I remember correctly.
40D || 50 1.8 II || 18-55IS || 85 1.8 || 430EXII || YN560 x2 || Cheap umbrellas x2 || QBox 24 || Cheap macro crap
Wallpap3r is offline   Reply With Quote
Old 30th of December 2010 (Thu)   #7
Ed The Shed
Thanks Wallpap3r
There seems to be a million and one things that you can use to make a bracket out of .
I have decided to wait until I have the lense and the flash so I can have a closer look at exactly what I need.
Although saying that I did see some "C" brackets for holding flashes that seemed like a good idea. Need to look into this more though.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
ADVICE NEEDED mdaddyrabbit General Photography Talk 4 14th of February 2008 (Thu) 08:30
Advice needed jack Sparrow General Photography Talk 15 29th of January 2008 (Tue) 05:10
Advice Needed aces40love Canon EF and EF-S Lenses 10 26th of August 2007 (Sun) 12:07
Advice needed toyya Canon EF and EF-S Lenses 14 11th of January 2007 (Thu) 10:39
Advice needed Borderfox Canon EF and EF-S Lenses 6 20th of July 2006 (Thu) 18:26
