Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > RAW, Post Processing and Printing
Reply
Thread Tools Display Modes
Old 29th of December 2010 (Wed)   #1
cokethenwpepsi
cokethenwpepsi's Avatar
Default Question of RAW conversion to JPEG
So I know the basics of a RAW file, I just have one simple question.
If you take a RAW photo, download it from your camera or card to your computer, edit it in a RAW editor, then open it in Photoshop and save it as a JPEG (for web upload or whatever), is any detail lost in that conversion even though it was originally taken and edited as a RAW file?
Alex
7D | 5D Mark ii | 85 f/1.8 | 70-200 f/4L IS | 17-55 f/2.8 IS | 50 f/1.8 | 430EX II
My Site
cokethenwpepsi is offline   Reply With Quote
Old 29th of December 2010 (Wed)   #2
enrigonz
enrigonz's Avatar
Default Re: Question of RAW conversion to JPEG
yes, I'm afraid....
None of my jpegs look as good as the RAW files, sometimes you'll have a hard time noticing in the beginning but after some time you'll be able to notice
Canon Stuff |Flickr | Facebook
enrigonz is offline   Reply With Quote
Old 29th of December 2010 (Wed)   #3
cokethenwpepsi
So with that clarified, what advantage does RAW have that wouldn't be lost in a jpeg conversion?
Alex
My Site
Old 29th of December 2010 (Wed)   #4
derangedhermit
derangedhermit's Avatar
jpeg is a distribution and display format, not a working format. Editing with RAW files (or TIFF files, or PNG (lossless compression), or Adobe PSD format...) lets you keep higher image quality throughout the editing process. When you are finished editing, then you can output a jpeg for putting on the web.
derangedhermit is offline   Reply With Quote
Old 29th of December 2010 (Wed)   #5
Peano
Peano's Avatar
When you shoot jpeg or convert a raw file to jpeg, anywhere from one-third to one-half of the image data is thrown away. In many images, that wouldn't make any difference at all. But in the ones that count, it can make all the difference.
Shadow details that are blocked in the jpeg can often be recovered in the raw file. On the other end of the spectrum, highlight details that are blown in the jpeg can often be salvaged from the raw file.
In some cases, I do one raw "exposure" for the midtones, a second for the highlights, and a third for the shadows. By bringing all three into Photoshop and blending them using layer masks, I can get a much higher dynamic range than could be had from a straight conversion to jpeg.
Peano
RadiantPics.com
Peano is offline   Reply With Quote
Old 29th of December 2010 (Wed)   #6
cokethenwpepsi
So if you were to take a photo in RAW and were able to recover shadow and/or highlight detail then convert to jpeg, you would then have a jpeg with shadow and/or highlight detail, rather than if the image had originally been shot in jpeg, in which case those details would be permanently lost? So basically the question that nags me is: when a RAW file is converted to jpeg, then the modifications made before conversion are not lost, correct?
Alex
My Site
Old 29th of December 2010 (Wed)   #7
Peano
Peano's Avatar
Correct. If you keep the raw file, it remains unchanged. You can't make any permanent changes to a raw file. All edits go as instructions into a little "sidecar" text file. When you save it as a jpeg, those changes get "baked into" the jpeg.
Peano
RadiantPics.com
Old 29th of December 2010 (Wed)   #8
cokethenwpepsi
Excellent. Thank you for clearing that up for me.
Alex
My Site
Old 29th of December 2010 (Wed)   #9
tonylong
....winded
tonylong's Avatar
I'll just add to your question about detail.
If you convert from a Raw file to a full-size high-quality jpeg the compression that gets applied is minimal and you will have a full resolution pixel-wise so detail will be retained. I know the earlier poster said that "after a while" he noticed a difference but I doubt it is actual detail "missing" because all the pixels are reproduced in the jpeg. I'd be interested in seeing a 100% crop of the Raw and a jpeg that was converted at full size and high quality showing detail loss.
But when you resize an image during a conversion to a jpeg or tiff or whatever for, like you mentioned something like saving for the Web, you are throwing pixels away, and that means that finer detail will just disappear.
And, at lower quality settings you are eventually going to see other issues -- not detail loss as such but the lower the quality the more strange "artifacts" can be seen. This also happens when you save, open and re-save a jpeg multiple times -- eventually it can have a pretty ugly affect.
So, a good workflow is to do all you can in Raw, then, if you need to work on an image in Photoshop you can, and then if you have a project that you want to keep as a "working project" the "best practice" is to save as a tiff. At the point that you actually need to save for the Web, email, print, whatever is when you save the jpeg at the right size and quality for your intended use.
Tony
Tony Long Photos on PBase
Wildlife project pics here, Biking Photog shoots here, "Suburbia" project here! Mount St. Helens, Mount Hood pics here
tonylong is offline   Reply With Quote
Old 29th of December 2010 (Wed)   #10
cokethenwpepsi
Awesome. Also, is the sharpening applied to a RAW more effective or advantageous in any way over sharpening jpegs?
Alex
My Site
Old 30th of December 2010 (Thu)   #11
tzalman
Fatal attraction.
tzalman's Avatar
The designers of Lightroom, where the conversion from linear RAW space to the skewered gamma corrected space of a rendered format is done only as the last step in the workflow, claim that any image adjustment is better if it is done in linear space - including sharpening and noise reduction. The difference might not be apparent if all you ever do is post to Facebook and print 4x6s, but the larger you print the more important the quality of the editing becomes.
Elie / אלי
"If you presume to love something, you must love the process of it much more than you love the finished product." John Irving, 5/2012. "In theory there is no difference between practice and theory, but in practice there is." Yogi Berra
Site
tzalman is offline   Reply With Quote
Old 30th of December 2010 (Thu)   #12
tonylong
....winded
tonylong's Avatar
Elie, could you give some specific info about this, like how different approaches might give different results?
Tony
Old 30th of December 2010 (Thu)   #13
tzalman
Fatal attraction.
tzalman's Avatar
Tony, the reason that I qualified the above by saying that this is the LR designer's claim rather than making a flat statement of fact is that I am not entirely convinced. It seems to me that as long as the white point and black point are not clipped a 16 bit tif will contain all the RAW data and any alteration (editing) of that data can be done as well. OTOH, I understand that for manipulations of linear data the algorithms are simpler. If this makes them better I'm not qualified to say. Maybe Peano or others more knowledgeable than me will have comments.
Elie / אלי
Site
Old 30th of December 2010 (Thu)   #14
enrigonz
enrigonz's Avatar
When you throw out 50% of information in an image, you will loose detail, if you have a good eye you can see it. Is the same a MP3 compression, most people wouldn't notice the difference between and uncompressed or a less compress file over a 128kb MP3 file but I sure can. Is all about what you're eyes and ears get used to seeing or hearing, after a while you get use to it and it really doesn't matter for most, we train our eyes and ears to"make up" for the lost details and those details are filled by us in our sub-conscience one way or another. Lots of scientific studies have been done on stuff like this, easy to look up.
Old 30th of December 2010 (Thu)   #15
tonylong
....winded
tonylong's Avatar
If you resize the image or highly compress it then yes, you lose a lot of detail. But a fresh conversion to a full-size jpeg at high quality should not result in noticeable detail loss and a very minimal and unnoticeable amount of artifacts.
But, like I said, it would be informative if you could post a couple comparison photos -- a screen shot of a 100% view of a Raw file with a 100% crop of a full-sized high quality jpeg showing loss of detail would help us to give an objective analysis instead of subjective opinions!
Tony
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
RAW Conversion to JPEG and Use pophoto Canon EOS Digital Cameras 11 7th of July 2010 (Wed) 16:01
T2i - Raw to Jpeg Conversion Mundty RAW, Post Processing and Printing 5 5th of March 2010 (Fri) 13:58
RAW conversion to JPEG in PS CS2 Kui RAW, Post Processing and Printing 17 25th of July 2007 (Wed) 22:23
DPP RAW->JPEG conversion question Raj RAW, Post Processing and Printing 12 26th of January 2007 (Fri) 09:04
jpeg conversion steve_shelly People 11 1st of March 2006 (Wed) 06:33
