Thread started 02 Jan 2011 (Sunday) 19:56
Prev/next
How do I upload RAW images onto my iMac?
MindlessConsumer
MindlessConsumer's Avatar
Jan 02, 2011 19:56 |  #1
Im not sure how to get them onto my computer.
Ive been using iPhoto to get my images off of my 40D and onto my computer. From there I just put them into a folder for processing.
I tried this after switching my camera to capture images in RAW and once i put them into the folder, it is saving them there as Jpegs :(
Im not sure how to get them onto my computer and keep them as RAW files.
Any help would be appreciated.
tonylong
...winded
tonylong's Avatar
Gallery: 60 photos
Vancouver, WA USA
Jan 02, 2011 20:08 |  #2
Do you have Aperture or Lightroom or Photoshop? If not what Raw processor are you using?
To start out, you should install the Canon software Digital Photo Professional to process your Raw files. You can aso install ZoomBrowser and EOS Utilities -- ZoomBrowser can help you download them from a card reader and, possibly, your camera. EOS Utilities has downloading from the camera (as well as tethered shooting. Install these things using the software that came with your camera and then upgrade to the latest from the Canon site.
Tony
Tony Long Photos on PBaseexternal link
Wildlife project pics hereexternal link, Biking Photog shoots hereexternal link, "Suburbia" project hereexternal link! Mount St. Helens, Mount Hood pics hereexternal link
MindlessConsumer
Jan 02, 2011 20:50 |  #3
I have CS3, but by the time I can get the image to PhotoShop it is already a Jpeg.
And no, I do not have DPP. I bought my 40D used, so I didnt get any software. Is there a place to download it?
Also, there must be another way to upload photos off of my camera and onto my computer (an iMac) other than using iPhoto and a USB cable??
Presha
Jan 02, 2011 21:29 |  #4
MindlessConsumer
CS3 WILL NOT PROCESS RAW! iphoto, aperture3, CS5, your camera's software and a host of other software will process raw. As for transferring files to your computer, a card reader or direct connect from your camera is about the only way to do it.
Fuji 617| Phase one 645 DF+| phase one p65+| 80mm 2.8 LS | 35mm AF
mguffin
mguffin's Avatar
Allendale, NJ
Jan 02, 2011 21:45 |  #5
You can use GIMP (www.gimp.orgexternal link), and download the Mac version and the UFRaw plug-in which is the RAW converter... Both free...
Mike
5D Mark II ~ 35 f/2 IS ~ Sigma 50 f/1.4 ~ 85 f/1.8
S.E.V.
/Include subdirectories, empty directories, and verify.
S.E.V.'s Avatar
Agoura Hills, CA
Jan 02, 2011 22:40 |  #6
What about getting a card reader and then just copying them into the desired folder? I don't see the imac converting them automatically if you do it that way. iphoto might be converting them. Or have you tried using EOS utility? It will pull them off the camera via the cable connected to the 40D. The simplest way is the card reader and the fastest. A no brainer really.
ShotsInTimeexternal link / Gear List /Flickrexternal link / Canon Family Portraitexternal link
- Don't Argue With A Stupid Person, They Will Bring You Down To Their Level And Beat You With Experience.
PixelMagic
Racine, WI
Jan 02, 2011 22:58 |  #7
You need to update your operating system to a version that supports Raw files from the Canon 40D. I don't use Macs so I can't tell you the specific version number but I do know that on Macs support for Raw files is built into the OS.
The reason for this is that by default an operating system will not recognize a Raw file because they are not standard image file format like a JPEG. So until that support for a specific camera model is added to the operating system, it will not know how to handle those files. The alternative is to use a card reader to get around the limitation of the OS.
And whomever said that CS3 will not edit Raw files is simply incorrect. Support for the Canon 40D was added in Adobe Camera Raw version 4.2. So I'd suggest you also update your Camera Raw plug-in to the last version that was compatible with CS3 which is version 4.6. You can download and install ACR 4.6 from here: http://www.adobe.com ...sp?ftpID=4033&fileI​D=3759external link
MindlessConsumer wrote in post #11560569external link
tonylong
...winded
tonylong's Avatar
Gallery: 60 photos
Vancouver, WA USA
Jan 02, 2011 23:50 |  #8
MindlessConsumer wrote in post #11560942external link
You have CS3 and, like was said above, CS3 will handle your Raw files -- you can do fine with CS3 until you get a camera from the next generations.
To download the Raw files to me the most efficient way is to use a card reader. Adobe does have a downloader which you can check out.
But, you also have the option of using the Canon software EOS Utilities.
Check this site out --
http://www.northlight-images.co.uk ...stall_canon_softwar​e.htmlexternal link
Work through the whole page -- it'll have a lot of Windows stuff but also Mac stuff, incuding an "original" version that you can download and install. Then, you will be able to go to the Canon site for a newer camera and download and install the updates for DPP, EOS Utilities and ZoomBrowser, which has some interesting utilities which could give you quick alternatives to downloading your Raw files. You have to go to the Drivers and Software tab, select your OS, then individually run each upgrade.
And, make sure you go to the Brochures and Manuals page and download the Users Guides for each app you download.
Card reader fastest and simpler on the system. Camera, slooooower and prone to driver messups at times.
Tony
MindlessConsumer
Jan 03, 2011 07:34 |  #9
Presha wrote in post #11561215external link
CS3 WILL NOT PROCESS RAW! .
tonylong wrote in post #11562054external link
Im a little confused, haha.
Tony-S
Tony-S's Avatar
Fort Collins, Colorado, USA
Jan 03, 2011 09:09 |  #10
Can you tell us:
1. What camera you have.
2. What version of OS X you have (from the Apple > About This Mac).
"Raw" is not an acronym, abbreviation, nor a proper noun; thus, it should not be in capital letters.
S.E.V.
S.E.V.'s Avatar
Agoura Hills, CA
Jan 03, 2011 10:53 |  #11
Tony-S wrote in post #11563512external link
Can you tell us:
He has a 40D as stated in the OP. OS X is still unknown.
MindlessConsumer
Jan 03, 2011 13:12 |  #12
Canon 40D
OS X 10.6.5
ArcticShooter
ArcticShooter's Avatar
Arctic Norway (Tromsø)
Jan 03, 2011 13:45 |  #13
Just use the CD that came with the camera!
It have all necessary software you need to download and edit RAW
Digital Professional Photo for editing and Image Browser for downloading the images to the mac
But as mentioned earlier get the card reader. It will be faster and if the imac have firewire that is the best option. If not get the regular usb reader
If your images still comes onto the hard drive as jpeg try to change the settings in the download window. You should find it under preference. I normally just move the RAW files to a new folder.
Helge
Summer is great :)
My gearMyexternal linkFlickr external link
external link
G+external link
S.E.V.
S.E.V.'s Avatar
Agoura Hills, CA
Jan 03, 2011 14:00 |  #14
ArcticShooter wrote in post #11565116external link
He bought the body used and it did not come with any software. As stated above.
Tony-S
Tony-S's Avatar
Jan 03, 2011 15:01 |  #15
MindlessConsumer wrote in post #11564915external link
Canon 40D
OS X 10.6.5
40D support is native to 10.6.5. You can move the raw files from your camera to your computer using Image Capture in your applications folder.
16,979 views & 0 likes for this thread
made in Finland
by Pekka Saarinen
Spent 0.00796 for 4 database queries.
PAGE COMPLETED IN 0.05s
Latest registered member is Willow-wisp
983 guests, 458 members online
