#1 |
I'm about to pull the trigger on the 70-200 f4. The price right now is perfect. Only negative I hear is that its slow and poor in low light. Will this be a big issue for me? I mainly will use it at outdoor sports events. I shoot alot of youth baseball and soccer. I recently purchased a 85 1.8 for basketball which worked incredible. I'm thinking if I ever need low light lens I can switch to the 85 outdoors. I have close access to all events I shoot so the range wouldnt be a issue. I have a 7D and wondering how is it with the 70-200 f4. Any help is appreciated.
| sponsored links |
#2 |
im sure youll be fine.
Filters are like Condoms ... Protection at loss of some quality. |
#3 |
Outdoor with good light pretty much negates the poor light issue. As for the slow auto focus, this lens is one of the few lenses on Amazon with a 5.0 rating. I don't think it's too bad. (several review sites don't think it is either)
| sponsored links |
#4 |
Thanks I always shoot in bright conditions outside during the early day. I really was concerned with the slow focus but the reviews on Amazon and B&H are 5 star. It should be fine.
#5 |
For outdoor sport it will be fine, I use it too for school sport documentary, and it's perfectly fine.
You will get about 1/500 s at ISO 200
[size="1"]Flickr X-Pro1 + 35 f/1.4, G12, 5D II, 500D, 24-70-200L, TS-E 24 f/3.5L II, 35, 50, 100L IS |
#6 |
How sharp are the sports action shots with this lens? In perfect conditions of course. Just wondering how sharp it is compared to the 2.8.
#7 |
Here is an example gallery. I used a 7D w/300 f2.8 some of which I had the 1.4x added for greater reach. For the close up shots, I used the 70-200 f/2.8 on the MK3.
If you are shooting high school soccer or in this case, field hockey, the fields are big. Youth fields are a lot smaller so the 70-200 will probably work until it gets late in the day. You'll be out of luck when the sun sets. Hope this helps. Mike |
#8 |
Thanks Mike. Gonna check out the gallery.
#9 |
If you want to be real sure, go out with another lens set at F/4 and see what exposures you get. Also with a shorter lens you can crop them to 200mm equiv to see what sort of coverage 200mm will get you.
Honestly I think F/4 @ 200mm is fine exposure wise, but 200mm simply isn't enough for many sports unless you limit yourself to those at your end/side of the field. |
#10 |
Great idea phreeky! Yes I'm definately limiting myself at 200 but I do move around alot and get some great shots. Once day I will go longer..
#11 |
You will have no issues with the 70-200/4 L in bright conditions, and the lens is already sharp wide open. If you need reach, this lens takes a 1.4 TC very well and it'll get you an extra 90mm on the long end. You'll lose a stop, but if it's bright you've got no worries.
Jason C
Equipment & Feedback "I am not interested in shooting new things-I am interested to see things new"--Ernst Haas |
#12 |
Thanks Jason. I will definately look into the extender too. I can't wait until I get this now. I shot with a old 100-300 usm 4.5-5.6 last year and got some really good results. I was lacking the sharpness that I wanted but my clients thought they were great. So this definately should be a step up.
#13 |
I just went the route of 70-200 f4 is with 1.4x tc. Will test it out later today. I've owned the cheaper 70-300 is USM and 55-250 is so I'm hoping for better images.
Canon 60D w/ BG-E9 | Tamron SP AF 17-50mm ƒ/2.8 VC | Σ 30mm ƒ/1.4 EX DG HSM | Canon 85mm ƒ/1.8 USM | Canon 70-200mm ƒ4L IS | Σ 70-200mm ƒ/2.8 EX OS DG HSM | Canon 430EX II | Kenko 1.4x + 2x | Think Tank Sreetwalker HardDrive | Vanguard UP-Rise 38 | Flickr | |
| Thread Tools | |
| Display Modes | |
| Looking for new glass for outdoor sports | dman64 | Sports Talk | 15 | 25th of March 2009 (Wed) 06:58 |
| Is there an all around sports and outdoor lens | mep42 | General Photography Talk | 3 | 11th of October 2008 (Sat) 14:36 |
| Next lens for outdoor sports | run53 | Sports Talk | 9 | 28th of March 2008 (Fri) 13:47 |
| Outdoor Sports Len | HuskiesD1 | Sports Talk | 22 | 19th of April 2007 (Thu) 20:53 |
| Canon S2 IS and outdoor sports | mattr2 | Small Compact Digitals by Canon | 2 | 17th of April 2006 (Mon) 09:25 |
