Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > RAW, Post Processing and Printing
Reply
Thread Tools Display Modes
Old 10th of January 2011 (Mon)   #1
Qbx
Default Hahnemuhle photo rag color prints
I have an Epson R2400 and made a color print on Hahnemuhle photo rag Satin paper. Shadow areas show banding. I used Best Photo & Archival Matte Paper settings in the printer properties. I used Photoshop manages colors, HFA_Eps2400_MK_PhotoRag printer profile and Relative Colorimetric. I am using MK black ink.
If I print with Pearl paper, PK ink and profile the print looks fine.
Computer is Thinkpad W700 laptop with Spyder calibration.
Is Photo-Rag Satin suitable for color prints or just B&W? Or could the profile be bad? Any help would be appreciated.
Qbx is offline   Reply With Quote
Old 10th of January 2011 (Mon)   #2
R Hardman
R Hardman's Avatar
Default Re: Hahnemuhle photo rag color prints
I use Photo Rag Bright White 310gsm for large color prints all the time on Canon's IPF5000. Spot on with no banding in any areas with the profile on Hahnemuhle's site. Check to see if you're also banding in large single tone gradients such as blue sky as it may help narrow down the issue. Hope this helps.
"Whatever you can do to avoid Photoshop is worth it"
EOS 7D, EOS 350D, EF 17-40mm f/4L USM, EF 70-200mm f/4L USM, EF-S 18-55mm f/3.5-5.6 USM (Kit)
Rick's Digital Desert
R Hardman is offline   Reply With Quote
Old 11th of January 2011 (Tue)   #3
Picture North Carolina
Gaaaaa! DOH!! Oops!
Yes, HFA is great for color. Not familiar with the 2400 driver, but isn't HFA supposed to be set at Velvet Fine Art Matte and not Archival Matte?
What is the native resolution of the image and what size are you printing to? Also, are you printing at the native resolution of the printer? Again, been years since using a 2400 but if I recall, it's 360. I prefer to have PS translate the file as opposed to the epson driver.
The 2400 and the original 3800 are very similar in the way they print, the drivers, etc. You might find some help on Eric Chan's epson 3800 pages.
Fine Art America | Red Bubble | Website | Blog
Gear list: Mine is bigger than yours.
Picture North Carolina is offline   Reply With Quote
Old 11th of January 2011 (Tue)   #4
Qbx
Thanks R Hardman & N. Carolina for the inputs. I usually shoot with a Canon 5D II but I was testing a new Lumix GH2 at max resolution of 16 mp. The print resolution shows as 352 PPI at a 51% scale about a 10x13 inch print. I don't know how to answer the question about printing to the printer's native resolution. I'm just following the standard printing menus through Photoshop. I tried a lot of different combinations of profiles etc. I found that the best result is obtained using an Epson profile (SPR2400 EnhancedMatte). Using Printer Manages Colors also eliminated the banding; but had an unpleasant color shift so it wasn't useful.
Old 11th of January 2011 (Tue)   #5
Gaaaaa! DOH!! Oops!
Originally Posted by Qbx View Post
TI'm just following the standard printing menus through Photoshop. I tried a lot of different combinations of profiles etc.
When printing to any good quality paper, it is always best to go to the support website of that paper, download (and use) their profiles, and follow the paper manufacturer's instructions for printing with your specific paper/printer combination.
http://www.hahnemuehle.com/site/us/4...-profiles.html
Also, I hate to mention the obvious, but did you clean and test the nozzles?
Old 21st of January 2011 (Fri)   #6
Qbx
Thanks Dan, Yes I did to a nozzle check and all was OK. As mentioned just using a different profile (or Printer manages colors) resolved the banding problem. It seems like a problem with the Hahnemuhle R2400 (downloaded from their site) profile to me.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Color Managed Browser and Prints Dr. Gonzo RAW, Post Processing and Printing 5 23rd of October 2010 (Sat) 11:30
prints seem off -color dba1954 RAW, Post Processing and Printing 43 29th of January 2010 (Fri) 13:06
Hahnemuhle's Photo Rag Satin paper : Is it good? hassiman RAW, Post Processing and Printing 2 4th of March 2009 (Wed) 13:21
Color Difference in Prints Between Lightroom and CS3 bob16946 RAW, Post Processing and Printing 35 5th of July 2008 (Sat) 17:26
Printers and Color Prints Embers RAW, Post Processing and Printing 2 28th of January 2008 (Mon) 18:58
