#1 |
I'm at a loss deciding which diffuser to get. Could you please explain the differences, pros and cons between the different available diffusers? I need help deciding what to buy for my 580ex II
Here are some links for what I was looking at: Adorama Mini Softbox Photoflex XTCII LumiQuest Mini Softbox I'm open to suggestions as to what to buy. Thanks so much for your help! |
| sponsored links |
#2 | |
#3 |
The gain you get from these devices is probably not worth the extra ridicule you get with that on your flash!
| sponsored links |
#4 | |
(umbrellas/lightstands/etc out of my budget) What do you recommend instead? |
#5 | |
When you can't bounce: Available light or Softbox/umbrellas. Money is no excuse - for the $$$ you spend on those devices, you can get an ebay umbrella mount ($10), an ok umbrella ($20), and you can use your tripod as the lightstand |
#6 |
I didn't realize there were umbrellas that cheap. Everything I saw was quite a bit more expensive. I'll look again!
#7 |
These are to small to do anything. I've got the Lumiquest LQ-107:
http://www.lumiquest.com/products/softbox.htm It works well for close up and macro work, but anything over 14" it's to small. |
#8 |
promaster
mike 40D, 350d xt, canon TC 1.4, canon 70 200mm f2.8 tamron 28 75mm f2.8 |
#9 |
I am of the belief that there are times when simply no other light modifier will work to soften the light of on-camera flash. And in those circumstances, any increase of the light from the few square inches of the flash lens is an improvement, even those mini softboxes that are 5x7" (35 sq.in. area) Any help is better than no help at all.
Showing only a small section of the full frame, here is what a 5x7" softbox can do at a shooting distance of 20' to improve the shadow cast by the arm... ![]() and the native flash lens only, at shooting distance of 20' ![]()
Canon dSLR system, Olympus OM 35mm system, Bronica ETRSi 645 system, Horseman LS 4x5 system, Metz flashes, Dynalite studio lighting, and too many accessories to mention Keep POTN alive and well with member support http://photography-on-the.net/forum/donate.php |
#10 |
Well this has at least told me one thing...
If using a mini softbox, bigger = better |
#11 |
I guess if it were not for better performance, why would anybody choose to carry around those huge softboxes and umbrellas? Maybe to compensate for lack of size in other key assets?
#12 |
i recently got the flashbender and it seems to be working well
5D Mark II | 17-40 f4L | 24-105 f4L | 70-200 f4L | Sigma 70-200 f2.8 | Sigma 50 f1.4 | 100 f2.8 macro | 15 f2.8 fisheye 580ex II | Slik 814 CFII + AF2100 For sale: Sigma 30mm f1.4 |
#13 | |
"Bigger means softer" ...about photographic lighting, of course!
| Thread Tools | |
| Display Modes | |
| Hot shoe mounted flash for macro? | thegrandpoohbah | Macro Talk | 6 | 8th of October 2010 (Fri) 04:46 |
| DIY Hot-Shoe Diffusers - Show Me Yours! | Golf Nut | Small Flash and Studio Lighting | 2 | 7th of January 2008 (Mon) 16:44 |
| Flashes! vs. Flashes! & radio off shoe transmitting. | ALaS | Small Flash and Studio Lighting | 3 | 6th of January 2008 (Sun) 22:41 |
| Serious discussion about hot shoe flash and large diffusers softboxes etc | pcunite | Small Flash and Studio Lighting | 1 | 31st of October 2007 (Wed) 11:11 |
| Diffusers (homemade or not) for EOS flashes? | markubig | Small Flash and Studio Lighting | 16 | 29th of January 2005 (Sat) 12:52 |
