Go Back   Canon Digital Photography Forums > 'Photo Sharing' section > Sports
Reply
Thread Tools Display Modes
Old 20th of January 2011 (Thu)   #1
patrickf117
patrickf117's Avatar
Default Surf's Up @ HB
HB Surfers....
patrickf117 is offline   Reply With Quote
Old 20th of January 2011 (Thu)   #2
patrickf117
Default Re: Surf's Up @ HB
HB Surfers...
Old 20th of January 2011 (Thu)   #3
effstop
I like the pier shots but you might want to try to straighten the horizon.
1D MKII | 28-80mm 2.8-4.0 L | 80-200MM 2.8 L | 400mm 5.6 L| 50mm 1.4
effstop is offline   Reply With Quote
Old 20th of January 2011 (Thu)   #4
jodelak
jodelak's Avatar
looks like it wasn't a clear day. i like the action though
jodelak is offline   Reply With Quote
Old 20th of January 2011 (Thu)   #5
StellaBlue71
StellaBlue71's Avatar
2 can be real cool with a little PP..
T2i w/ Grip :18-55mm IS, 28mm f/1.8, 85mm f/1.8, 70-200 f/4L, 100-400mmf/4.5-5.6L IS, 430ex II
StellaBlue71 is offline   Reply With Quote
Old 21st of January 2011 (Fri)   #6
patrickf117
Here it is....
Old 21st of January 2011 (Fri)   #7
patrickf117
Here it is...still learnin'. Thanks for the input.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Surf pics - Over exposed Surf bigmark100 Sports 11 15th of January 2011 (Sat) 12:12
Surf..... Harleypugs Still Life, B/W & Experimental 1 2nd of April 2009 (Thu) 13:41
A little bit more Surf. Trevi Sports 1 26th of January 2009 (Mon) 14:46
Just one (surf) rippanics Sports 1 17th of April 2007 (Tue) 15:20
