Reply
Thread Tools Display Modes
Old 22nd of January 2011 (Sat)   #1
stephyvic
Default G12 depth/aperture help
I'm hoping someone can answer this question for me. I have been fiddling around with the aperture to focus on a closer object so that everything in the background and further distance is blury. It's working great except for when I try to use the self timer and step into the shot. It just keeps everything in focus. It doesn't seem to focus on me or the object alone. I've tested this i.e. I put the self timer on and THEN put an object within the frame and then everything goes into focus. but when I use the self timer on something that is already within the frame the effect works perfectly (object is in focus while everything else is blury). Is there a way to get this effect if the object (like myself) steps into the frame after I've set the timer to go
Thanks!
stephyvic is offline   Reply With Quote
Old 22nd of January 2011 (Sat)   #2
Trelawney
Default Re: G12 depth/aperture help
Try using manual focus.
Trelawney is offline   Reply With Quote
Old 22nd of January 2011 (Sat)   #3
02Pilot
+1. In my (limited) experience with the G12, the only way you'll get a blurred background of any sort in the vast majority of situations is to use manual focus.
02Pilot is offline   Reply With Quote
Old 22nd of January 2011 (Sat)   #4
GordonSBuck
... and the background won't be particularly out of focus unless it is very far away in comparison to the subject.
GordonSBuck is offline   Reply With Quote
Old 22nd of January 2011 (Sat)   #5
mastertech01
mastertech01's Avatar
I dont know for sure if this is you answer, but I purchased one of those cheap "Aputure" wireless remotes that works great for remote shooting. You can then step in when you like and use the remote to get focus confirm and then fire just like you were standing behind it with your finger on the shutter button.
Its on sale too!
http://cgi.ebay.com/Aputure-Coworker...item53dca6c13e
mastertech01 is offline   Reply With Quote
Old 22nd of January 2011 (Sat)   #6
avondale87
avondale87's Avatar
does that gizmo work with the G12? Or only on DSLR's.
I'd be interested in one if it does for bird photos.
Hopefully I'd get more than a glorified perch for the little fella's
avondale87 is offline   Reply With Quote
Old 22nd of January 2011 (Sat)   #7
mastertech01
Now sir you dont think I would recommend it if it didnt work on the G12?
That is why I linked to the particular model that I posted the URL too because that is the one I am using on my G12
It should work great for birding. It can be used without the wireless remote for wired remote use, though the cable is pretty short. You can buy or make a longer cable for it though. I used this same remote on my 1D Mark III with a different cable, and made a 25 foot extension cord for that one. For its modest price it was worth a gamble to me. I do recommend taking the battery out of the wireless remote though when not in use as it seems to drain the battery down if you dont.
Old 22nd of January 2011 (Sat)   #8
avondale87
avondale87's Avatar
I suppose thats what happens when a 'Member' queries a 'Senior Member'
I did assume that was the case thanks, but wanted to make sure as I am just sending some other Canon gear back that was bought in good faith only to find it doesn't fit as well as it should and one doesn't fit at all for my G12 and S3.
I looked down that linked page and not seeing a mention of G12 decided to come back with my query.
Old 22nd of January 2011 (Sat)   #9
mastertech01
Heh, no sweat, I didnt know either. Just had to purchase it and try it and am reporting for the benefit of those who would like to know. Ive bought plenty of stuff that was supposed to work too... still trying to get rid of some of it. It happens..
Old 22nd of January 2011 (Sat)   #10
avondale87
avondale87's Avatar
stephyvic can you do what you descibe but replace 'the object' with your self?
Ie, focus on something where you will stand, press the shutter button and hold after it focus's, then shift (if needed) the camera (point to) where you will stand and then move quickly.
I have done this with focusing on close items with success.
You may have to watch the exposure and fiddle with that by under/over compensating.
I don't use Auto - prefer AV.
Old 23rd of January 2011 (Sun)   #11
stephyvic
Avon and master thanks so much for your help!
I'll try putting a "model" object as myself before stepping into the frame and see if that works. I had this idea in mind as well. It would be a temporary solution. And this switch sounds like a great idea! I'll definitely buy one.
I guess there is no way to do it other than those two options. I've tried with manual focus
thanks again guys!
Old 23rd of January 2011 (Sun)   #12
dacale
dacale's Avatar
a blurry background is not working with a compact camera when you make a portret
because the sensor is to small.(it's not working with compact camera's)
you need a DSLR or a camera with a bigger sensor and a lens with a aperture of 2.8
only in macro mode it works.
leon
http://www.flickr.com/photos/8323118@N08/
greetings leon
dacale is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Aperture 3 picture finding problem, (possible relevant to non aperture users) mjHession RAW, Post Processing and Printing 0 25th of March 2010 (Thu) 14:18
Scheimpflug: Depth of field VS Depth of focus alteschule101 General Photography Talk 12 22nd of September 2007 (Sat) 09:40
Depth of field and aperture selection question. s_erez The POTN Lounge 4 16th of December 2006 (Sat) 11:37
depth or no depth....that is the question Boosting1Bar Critique Corner 6 27th of July 2004 (Tue) 15:16
Aperture and depth-of-field peabobb Small Compact Digitals by Canon 3 10th of April 2003 (Thu) 06:45
