| sponsored links |
| View Poll Results: Do you use a filter holder for your GNDs? | |||
| Yes, I use a holder |
15 | 88.24% |
| No, I hand-hold my filters |
2 | 11.76% |
| Voters: 17. You may not vote on this poll | |||
Thread Tools | Display Modes |
#1 |
I have recently got a Lee filter system holder and some GND filters. Only used them twice.
First time I used the holder, but wasn't happy with the horizon. I think the filter was a little lower in the holder than it should have been. My fault through inexperience. I mentioned this to someone who does some awesome landscapes using hand-held GND filters, and he swears by that method and has neved used a holder. So on my second outing I tried this hand-holding but for 30s exposures I couldn't hold it steady enough, my fingers wobbled into shot a bit, and the horizon was a bit of a mess. I do have pretty steady hands IMO. Ended up going back to the filter holder and was very happy with the results this time: http://photography-on-the.net/forum/...d.php?t=992153 I know it's probably practise like everything else. Wondering if you have any tips for me? PS - thought I'd add a poll on whether you hand-hold or use the holder |
| sponsored links |
#2 |
Hi...I also use the Lee filter system and have 3 soft GND filters, .3, .6, and .9 plus the holder. The filters are the 4"X6" size which easily facilitates hand holding them. What size are you using? If you're using the smaller size, they are harder to hand hold. Typically I hand hold the filter for most exposures and for exposures of a few seconds or so it isn't a problem. I read somewhere, and my apologies I don't recall where, that you can use drafting tape to tape just enough of the long edges of the filters to hold them together so the taped edges can't be seen in the image. This will allow you to put multiple filters together aligned in the way you want them and then hand hold them for the exposure. This would work ok for short exposures but as you found out would still be a problem to long exposures. Like you, I have pretty steady hands. I would try the drafting tape and see if that works for you. Make sure it's drafing tape that you use since the adhesive is fairly light and won't stick to the surface of the filter.
Good luck, Jeff
Jeff |http://www.jeffsagar.com Canon EOS 5D Mark II|17-40 f/4 L|24-105 f/4 L|70-200 f2.8 L|100 f/2.8 macro Gitzo GT3531 LSV tripod|Arca-Swiss Monoball Z-1 tripod head |
#3 |
I've got the 4x6 filters - a 3 stop hard, 3 stop reverse, and 2 stop soft. Lens was a 17-40L.
Mighth just have to practise a bit (lot?) more |
| sponsored links |
#4 |
Practice. Also, you can use your DOF preview button to help with seeing the placement of the gradient. Handholding, which I'll do on occasion, also increases the chances for scratching the filters through contact with the lens barrel.
"Fat, drunk and stupid is no way to go through life, son". - Dean Wormer GEAR LIST |
| Thread Tools | |
| Display Modes | |
| 2 UV filters at the same time? "17-55mm EF-S/Canon UV/Boya UV" ?? | StructuredAmazing | Canon EF and EF-S Lenses | 32 | 23rd of November 2010 (Tue) 01:10 |
| What Canon says about "digital lenses" and flare from filters | RDKirk | Canon EOS Digital Cameras | 6 | 22nd of March 2009 (Sun) 20:20 |
| UWA Lenses and Cokin "P" series Filters - Need info | Dorman | Canon EF and EF-S Lenses | 14 | 23rd of April 2007 (Mon) 11:25 |
| Using "close-up" lenses/filters to improve tele capacity | Faustini | Canon EOS Digital Cameras | 2 | 24th of February 2006 (Fri) 11:05 |
