Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Accessories & Storage
Reply
Thread Tools Display Modes
Old 31st of January 2011 (Mon)   #1
Cokeman
Default Remote shutter release and back button focus
Should be a fairly straight-forward answer to this question...
If you use back-button focus, and wanted to use a remote shutter release, where the remote provides the half-press focus feature, does focus work with the half-press? Or does the back-button focus require focusing ahead of time?
T2i, 70-200/4, 28/1.8, 85/1.8, 28-135, 18-55, 55-250, 430EXII
Cokeman is offline   Reply With Quote
Old 31st of January 2011 (Mon)   #2
bohdank
bohdank's Avatar
Default Re: Remote shutter release and back button focus
You have to move the focusing back to the shutter.
Montreal Concert, Event and Portrait Photographer
Flickr
bohdank is offline   Reply With Quote
Old 31st of January 2011 (Mon)   #3
Cokeman
Thanks!
Does back-button focus still work with the remote shutter release? i.e., can I use back-button focus first, and then ignore the half-press on the remote?
Old 31st of January 2011 (Mon)   #4
Echo63
Echo63's Avatar
Originally Posted by Cokeman View Post
Thanks!
Yes
You can either prefocus with the back button, and the remotes half press will do nothing (except start metering and image stabilizing)
OR
You can set the focus back to half press (cfn 4.0 I think) and the camera will AF when you half press the remote
My Best Images[/size]www.echo63.deviantart.com
Gear listhttp://photography-on-the.net/forum/...&postcount=385
Echo63 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Remote shutter release w/ MLU versus remote shutter release w/ MLU w/ 2 secon timer. Tomash General Photography Talk 7 19th of January 2011 (Wed) 18:05
40D back focus button? Better than using shutter? Jenniferrose Canon EOS Digital Cameras 24 8th of August 2008 (Fri) 13:04
Focus with * button or shutter release button? Keydogg General Photography Talk 20 30th of July 2007 (Mon) 00:11
Shutter Release button on 5D and 30D jestergx4 Canon EOS Digital Cameras 4 31st of January 2007 (Wed) 20:16
Nokia Hands-free Remote Control as a Remote Shutter Release 4walls Canon EOS Digital Cameras 0 28th of March 2004 (Sun) 20:52
