Reply
Thread Tools Display Modes
Old 18th of April 2003 (Fri)   #1
BartS
Default Your experiences with Truecolor profiles?
I was wondering what your experiences are with the Truecolor profiles for the G3?
I got the free non-linear Truecolor profile, but when I apply this most pictures have a quite severe blue/magenta cast.
Some info:
-Monitor is calibrated (w. spyder) to 6500k.
-I use AdobeRGB as colorspace
-In PS I assign the truecolor profile to the image (JPG shot with auto white balance).
-Later I want to convert to sRGB (the digital printing lab uses that...)
I was wondering about the following:
-Am I missing something in my setup? There are so many things to consider with colormanagent...
-Can these profiles only be used to convert RAW images, or is it OK to use them on JPG's as well??
Thanks,
Bart
BartS is offline   Reply With Quote
Old 18th of April 2003 (Fri)   #2
PFlor
Default Re: Your experiences with Truecolor profiles?
Where did you get this free profile? I'm not aware of any free ones for the G3. The one I use is the non-linear G3 true color profile included in Breezebrowser and the results are great. The only thing you have to do after applying this profile is to apply a subtle S curve in Photoshop in increase the contrast a bit.
PFlor is offline   Reply With Quote
Old 18th of April 2003 (Fri)   #3
BartS
I got the profile from Breezebrowser (not using that anymore, it is a very good program but don't have the $$ right now...). Well, I assumed it was included as a free sample with BB.
So we're talking about the same profile.
I wonder why it is not working for me... Do you apply the profile to JPG's as well?
Old 19th of April 2003 (Sat)   #4
PFlor
Default Re: Re: Your experiences with Truecolor profiles?
Yup, I assign it to jpgs as well. You should only get a slight color shift and a reduction in contrast but once you apply the S curve it should look fine. Maybe the color shift is what you're talking about? It's hard to tell what's wrong without seeing a sample.
Old 21st of April 2003 (Mon)   #5
BartS
I put some examples in my webspace (there is no website yet, sorry...).
http://www.xs4all.nl/~bstolk
Color in the 'a' pictures are as from camera, the 'b' pictures use the Truecolor profile.
The first two were shot as JPG, number 3 is converted from RAW (with no profile and the Truecolor profile resp.)
It's the colorshift I'm puzzled about. In general I think the profile is OK, colours that are more true to the original. But on the other hand the profile seems much too blue and I'd do some colorbalancing. Specially skintones seem to look a bit "unhealthy".
What do you think looking at the pictures.
Old 21st of April 2003 (Mon)   #6
PFlor
I just checked your images and this is normal behavior of the profile. What you need to do after applying the profile is to make a subtle S curve adjustment in Photoshop (assuming this is what you use). You can either try to do this on your own or download some preset ones here:
http://aboutdigicam.com/forum/viewtopic.php?t=128
Old 22nd of April 2003 (Tue)   #7
BartS
Thanks PFlor for your help! I'll play around with those curves a bit and see.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
your experiences dave_borg98 Canon EOS Digital Cameras 3 25th of October 2006 (Wed) 11:17
Calibration, Printer profiles vs monitor profiles--I GIVE UP!!!! AliAyson RAW, Post Processing and Printing 6 26th of June 2006 (Mon) 02:18
Monocular experiences tuomon Canon G-series Digital Cameras 5 19th of April 2003 (Sat) 10:49
Truecolor ICC profile too blue? BartS Canon G-series Digital Cameras 0 11th of April 2003 (Fri) 16:23
Underwater Experiences Panayotis Small Compact Digitals by Canon 2 25th of October 2002 (Fri) 15:54
