Thread started 10 Feb 2011 (Thursday) 09:37
Kacey 22" Beauty Dish vs. Cheeta Speed Pro 16" Beauty Dish ??
m.shalaby
Feb 10, 2011 09:37 |  #1
22" Kacey: - $279 solution with bracket
http://www.kaceyenterp​rises.com/?page_id=461 (external link)
16" Cheeta: $129 solution with bracket
http://www.cheetahstan​d.com …d-Pro-16%22-Beauty/Detail (external link)
I'm considering both of these for indoor & outdoor shoots with my 430EX. I would get the appropriate shoe mount adapter for each.
As it stand, the Cheeta is about 1/2 the price total with mount adapter so I'm leaning toward that, but beauty dishes are new to me so looking for input. 16" vs. 22" ?
What do you recommend and why?
m.shalaby
Feb 10, 2011 10:06 |  #2
just to add, the Cheeta adds a sock diffuser as well in the price, while the Kacey is extra.
from my research, it seems the Cheeta is a bargain... also considering i have a Qbox 24 on the way, perhaps having a smaller 16" light modifier would be nice for versitility.
but at the same time, i'm wondering if i'm missing something here... if there's a big difference i'm not 'in the know' about....
any input guys?
KurtGoss
Feb 10, 2011 10:12 as a reply to  @ m.shalaby's post |  #3
16" vs 22" is a major difference in size, if you put them next to each other it is surprising how much there is a difference.
TMR ­ Design
Joined Feb 2006
Feb 10, 2011 10:29 as a reply to  @ KurtGoss's post |  #4
That 6" difference in diameter is significant. If you're just using it as a reflector for fill or accents then it's no big deal but if you're using it as your main light source then the difference is huge, both in terms of quality of light and coverage.
The smaller dish will require that you use it closer than the 22" to achieve the same quality of light and if you want soft light you really must add the sock and work it VERY close to your subject.
The 16" dish is nice but I don't particularly care for it as a main light source.
Robert
m.shalaby
Feb 10, 2011 10:30 as a reply to  @ KurtGoss's post |  #5
yeah, size is the ovbious difference.
I should note, I have a QBox 24 in transit to me right now... and I believe the 22" Kacey will yield a similar look being its a white dish - do you think it will be a little redundant?
while the Cheeta is silver coated, so it should yield a more contrasty higher efficient light.
If you had the QBox 24 already, which would you go with?
TMR ­ Design
Joined Feb 2006
Feb 10, 2011 10:44 as a reply to  @ m.shalaby's post |  #6
I own a Cheetah Qbox24 and a Speedotron 22" beauty dish. They are very different animals.
The dish is shallow, the qbox is deep. The dish, even with a white interior has no other diffusion and less travel for the light to further diffuse. The qbox can have up to 2 layers of diffusion. That and the depth of the box contribute to a very soft, diffused light.
I don't consider a 22" beauty dish and a 24" softbox to be at all redundant.
Robert
bobbyz
Feb 10, 2011 10:53 |  #7
I have kacey dish (dual speedlite option) and QBox, like Robert mentioned two different things. But I would just play with QBox24" right now and then add dish later.
5dmk3, 35L, 85L II, 300mm f2.8 IS I, 400mm f5.6
Fuji XT-1, 14mm f2.8, 23mm f1.4, 35mm f1.4, 56mm f1.2, 90mm f2, 50-140mm f2.8
m.shalaby
Feb 10, 2011 11:02 as a reply to  @ bobbyz's post |  #8
Gotcha, thanks for the input guys.
I take it you like the Kacey better than the Cheeta overall than due to size, silver vs. white aside?
bobbyz
Feb 10, 2011 11:44 |  #9
Kacey is better build, can support dual speedlites and bigger.
m.shalaby
Feb 10, 2011 12:17 as a reply to  @ bobbyz's post |  #10
you guys are saying the Qbox and B-Dish are "two totally different things". What are the exact differences? i know, i know... noob question
i know you'll get round catch lights vs. square in eyes, but other then that ??
bobbyz
Feb 10, 2011 14:26 |  #11
Honestly I would try some reading on what the beauty dish does. Look at some beauty dish shots vs softbox.
Here is one the sites which will show comparison. Select beauty dish on one and softbox on other.
http://www.hensel.eu …?no_cache=1&lca​t=7&rcat=9 (external link)
m.shalaby
Feb 10, 2011 15:35 |  #12
bobbyz wrote in post #11816876 (external link)
excellent! thanks!
i really like the lighting a beauty dish provides...
so I guess i'm back to my original question comparing the Cheeta vs. the Kacey.
The Cheeta comes with a white sock diffuser. Do you think this will give the 'white dish look' ?
m.shalaby
Feb 11, 2011 08:15 |  #13
m.shalaby wrote in post #11817320 (external link)
excellent! thanks!
anyone on this last question^ ?
bobbyz
Feb 11, 2011 08:23 |  #14
I haven't used sock on my dish but I would assume it will give more a look of the softbox. Generally you want the use the dish pretty close so 22" is better in that regard than 16".
TMR ­ Design
Joined Feb 2006
Feb 11, 2011 08:25 as a reply to  @ m.shalaby's post |  #15
If you're still comparing the 16" to the 22" they're still very different. I might be alone here but I just don't find that any modification to the 16" dish gives 1. The look I like, or 2. The look of the 22" dish.
As I mentioned earlier, versatility of the 22" is much greater and you're not forced to work so close to the subject.
If you use the very loose rule of thumb that says the optimal distance for a modifier is between 1 and 1.5 times the diameter, or longest edge in the case of a softbox.
That puts the 16" dish between 16" and 24". That's pretty close and you'll be framing very tightly.
Using the rule of thumb with a 22" dish puts you between 22" and 33". I find that to be a much better working distance. Many people use the 22" dish at about 3 feet from the subject and it's a great look.
So, if you're dead set on getting the 16" dish then the diffusion sock helps but won't get you the same look at the 22" unless you're super close.
Robert
12,481 views & 0 likes for this thread
version 2.0 /
Latest registered member is mason.snipes
583 guests, 320 members online
