Thread started 13 Feb 2011 (Sunday) 15:22
Ball Head for Monopod
kitjv
Feb 13, 2011 15:22 |  #1
I have a Slik Pro Pod 382CF monopod & am in need of a recommendation for a ball head. The head will support up to a maximum weight of 5 lbs. And since the reason I bought the 382CF monopod was for it's light weight, I am looking for a ball head that is lightweight as well.
Thank you for any recommendations. I appreciate it.
MOkoFOko
nut impotent and avoiding Geoff
Joined Jun 2010
Feb 13, 2011 15:53 |  #2
It depends what your price range is. As a cheapo though, I would recommend the Benro B0 or B1 ballheads. You can get each for about $100 if you know where to look. If you can afford $400 ballheads though, the world opens up for you!
My Gearlist
Houston1863
Feb 13, 2011 17:02 as a reply to  @ MOkoFOko's post |  #3
I bought a Giottos MH1302-652 to go with my monopod in November. Looking up Adoroma's site, I think the updated equivalent could be the MH-1001. It has a calibrated tension control which you can set the friction to suit the weight of your camera and lens combination.
Take a look -
http://www.adorama.com​/GTBHMWQR.html (external link)
Cheers
IMAGE: http://www.cosgan.de/images/smilie/froehlich/a010.gif
H
IMAGE: http://www.cosgan.de/images/smilie/nahrung/a035.gif
2x5D3, 16-35L, 24-70L, 70-200/2.8L IS,15 FE, 50L,100L, 2x580EXII, 1x430Exll, Fuji X10, YN-622Cs, Manfrotto Neotec legs, various bits and pieces, my Apples ( 2 living MacBook Pro, 1 dormant PowerBook G4 ), bags and bits of Think Tank stuff
www.picture-u.net (external link)
www.picturing-u.blogspot.com (external link)
Quad
Joined Nov 2005
Feb 13, 2011 17:17 as a reply to  @ Houston1863's post |  #4
I use either a Manfrotto 482
http://www.bhphotovide​o.com …_492_Micro_Ball​_Head.html (external link)
or a large leica
http://www.adorama.com​/LCBSHL.html (external link)
The Manfrotto is very small and the Leica has a very sure grip with little pressure and is quick and easy to adjust due to the ribbed ball . I does have a bit of heft though. I got it in the mid to early 80's so it is durable. I got the Manfrotto to support a flash but I use it for a camera if I want the smallest package on my monopod.
The Manfrotto 494 is also possible but I have not used it
http://www.adorama.com​/BG494.html (external link)
lannes
Feb 13, 2011 21:35 |  #5
I'm using the Slik 320DQ
IMAGE: http://i81.photobucket.com/albums/j226/lannes2007/IMG_8888sharpened-1-1.jpg
But I recommend the 280DQ
kitjv
Feb 13, 2011 22:13 |  #6
Thank you for the suggestions. Lightweight will be important. I will use the monopod primarily when I travel. And since I carry no more than can fit in an airplane's overhead bin, size & weight will take precedence over superior quality.
Raven
Joined Jan 2005
Feb 13, 2011 22:56 |  #7
I use an RRS MH-01 with B2-Pro II QR head. Very smooth and only 13 oz. total for the combo. Stated capacity is 75 lb so that should cover your needs :-)
http://reallyrightstuf​f.com …ad-with-B2-Pro-II&key=ait (external link)
Jim ~ Canon EOS 7D & 40D | Canon Powershot G5x, G16, G12 & G10 | Sony Cyber-shot RX100 M2 | Canon 17-40mm f/4 L | Canon 24-105mm f/4 L IS | Canon 70-200mm f/4 L IS | Canon 100mm f/2.8 Macro |
Canon 60mm f/2.8 Macro | Tamron 28-75mm f/2.8 | Tokina 12-24mm f/4 | Kenko 1.4x Pro300 DG TC
kitjv
Feb 14, 2011 10:58 |  #8
Raven wrote in post #11838471 (external link)
I will check it out. Thanks, Raven.
1,709 views & 0 likes for this thread, 6 members have posted to it.
1040 guests, 107 members online
