Thread started 14 Feb 2011 (Monday) 05:26
Focus issues & MA: Why send it for calibration?
Logan7
Feb 14, 2011 05:26 |  #1
I've read a lot of posts that say something like: "I have to set my (insert lens here) to +9 MA, so I'm sending it in for calibration."
I don't own a camera with MA, but this seems strange to me. If you can MA a lens so it focuses accurately, what's the point of sending it in for calibration? MA is there so you don't have to get the lenses fine tuned for AF at the service center, and more importantly so you can fine tune them to your particular body. Right? Like I said, I don't own a MA body, so I'm speaking outside my own experience.
5Dc - Sigmalux - Canon 100mm F2
guntoter
Feb 14, 2011 05:57 |  #2
I wondered that too until I heard folks talking that even after MA that the lens would still be OOF at different distances than where the did the MA or at different FL on a zoom.
If MA works, great. If it only works at the MA distance/zoom then not so great.
Joel
GEAR
JeffreyG
Gallery: 42 photos
Feb 14, 2011 06:29 |  #3
My general opinion is that MA is not as useful as a lot of people expected. Zoom lenses in particular often cannot be corrected with MA as they want different amounts and directions through the zoom range.
All that said, if I owned a lens that worked absolutely fine for focus despite needing a large amount of MA, I would not sent that lens in for adjustment. I don't fix what isn't broken.
M.Quick
Feb 14, 2011 06:46 |  #4
Can't you set MA for different focal lengths? Or is it only one general MA-setting for the whole range and specific lens?
Though i guess if you need to set it at different focal lengths to get it corrected, then i would assue it really needs to be calibrated?
Or what are your thoughts about this guys?
My "cheap" pro-setup;
Canon EOS 450D | Canon 50mm f1.8 II | Canon EF 70-200L f2.8 IS USM | YN-468 v2
8GB SDHC Class10 | BG-E5 + 4xLP-E5 | RC-4 | Canon E1 | Lowepro Exchange Messenger bag
smorter
Feb 14, 2011 06:48 |  #5
MA is helpful, but far from a cure
As mentioned, issues like distance, focal length
I recently purchased a 5D but it's useless with my 85L as it just back focuses, and without MA, I would need to pay over $200 to get them calibrated to each other (thereby taking them out of sync against my other lenses)
Wedding Photography Melbourneexternal link
Reviews: 85LII
M.Quick
Feb 14, 2011 06:54 |  #6
I wish canon would extend the functionallity of the MA on the cameras that support it so that you could add MA to different focal lengths on the same lens... That would be neat!
guntoter
Feb 14, 2011 07:06 |  #7
M.Quick wrote in post #11839691 (external link)
Don't know how pratical that would be to implement or how much skill the photog would have to have to do the multiple MA, but it is a nice "wish list" item.
Joel
GEAR
Sir_Loin
Feb 14, 2011 07:22 |  #8
If MA cures focussing accuracy at all distances (taking in to account the occasional focussing error that does happen, particularly with very fast lenses), then there's absolutely NO NEED to send it for re-calibration to Canon. But as others have said, if it's still very erratic then it's best Canon have a look. My 24L f/1.4 II needed +12 and 85L f/1.2 II needed +7, well within tolerance so I felt no need whatsoever to send them to Canon.
EOS 1D4, 5D3, EF 24-70mm f/2.8L II, EF 70-200mm f/2.8L II IS, EF 50mm f/1.8 STM, EF 85mm f/1.2L II * EOS R6, RF 24-105mm f/4.0-7.1 * EOS M5, EF-M 11-22mm f/4.0-5.6 IS, EF-M 18-55mm f/3.5-5.6 IS, EF-M 55-200mm f/4.5-6.3 IS, EF-M 22mm f/2.0, EF-M 28mm f/3.5 Macro IS * FL-F 300mm f/5.6 FLUORITE, FD 55mm f/1.2 ASPHERICAL, FD 24-35mm f/3.5L, FD 50mm f/1.2L, FD 300mm f/2.8L, FD 50-300mm f/4.5L
EL_PIC
Feb 14, 2011 07:40 |  #9
Lenes / Cameras should focus correctly out of the box from manufacturer.
Adjusting a lenes / camera with MA makes about as much sense as adjusting
your auto engine to run to the automakers specs.
EL_PIC - RIT BS Photo '78 - Photomask Engineering Mgr
Canon DSLR - Nikon SLR - Phase One 60MP MFDSLR
http://www.Photo-Image-Creations.com (external link)
http://www.musecube.co​m/el_pic/ (external link)
http://www.facebook.co​m/PhotoImageCreations (external link)
Sir_Loin
Feb 14, 2011 07:49 |  #10
EL_PIC wrote in post #11839828 (external link)
I suggest you read these then if you think every lens and camera body should be 100% accurate out of the box;
http://www.lensrentals​.com/news/2008...nd-other-myths (external link)
http://www.lensrentals​.com/news/2010...nd-other-facts (external link)
smorter
Feb 14, 2011 07:49 |  #11
EL_PIC, I wish you were CEO of Canon Inc...alas it is not so
Reviews: 85LII
M.Quick
Feb 14, 2011 08:10 |  #12
I wish you where right, but unfortunately you're not. There is always gonna be room for error, no matter what you buy. Some has more and some has less product errors than others.
In the perfect world you would be right, but it's not.. :(
guntoter
Feb 14, 2011 09:08 |  #13
I would actually like to know the percent of "out of spec" lenses/cameras that each manufacture puts out.
We hear about problems on POTN, but how many are there really compared to the equipment built?
I know that all of my lenses have been good out of the box as far as focus is concerned.
Joel
GEAR
gasrocks
Feb 14, 2011 09:15 |  #14
Not even one has MA. You can only adjust a zoom for one mm setting. You can only adjust one lens for one distance. And if your MA reuires a lot of adjustment - i.e. at the end of the scale you have, what will you do when it changes and it can? Many just feel better having the experts adjust it like it should be.
smorter
Feb 14, 2011 09:27 |  #15
guntoter wrote in post #11840222 (external link)
Out of all my lenses, all require MA except for my 100 mm Macro, because I use it in Manual Focus mode
My 85 f/1.2, 35 f/1.4 and 200 f/2 are the most annoying
Reviews: 85LII
4,292 views & 0 likes for this thread, 16 members have posted to it.
Latest registered member is droneworx
912 guests, 196 members online
