Thread started 15 Feb 2011 (Tuesday) 06:17
DPP problem
Ralpho
Feb 15, 2011 06:17 |  #1
When I try to access Preferences in Digital Photo Professional I get the following error message: "An error occurred. Digital Photo Professional will be closed." I click OK, and it closes as promised.
I tried deleting the program and reloading. No change. The version I'm using is the one that came with my 7D 13 months ago. And I'm running it on a newer iMac desktop.
Any ideas how I can change this and access DPP preferences?
Sdiver2489
Joined Sep 2009
Feb 15, 2011 07:45 |  #2
EDIT: Nevermind, you are running a mac.
Please visit my Flickr (external link) and leave a comment!
Gear:
Canon 5D III, Canon 24-70L F4 IS, Canon 70-300L F4-F5.6 IS, Canon 100mm F2.8L IS Macro, Canon 35mm F2.0 IS, Canon 430EX II-RT, Canon 600EX II-RT
Ralpho
Feb 15, 2011 08:39 |  #3
Sdiver2489 wrote in post #11846703 (external link)
Please explain the significance of your comment.
Sdiver2489
Joined Sep 2009
Feb 15, 2011 08:45 |  #4
Ralpho wrote in post #11846977 (external link)
Sure, I had a nice long explanation about how I would go about fixing your problem posted. Then I reread your post and you said you were using a mac. The solution I posted had to do with the registry which the mac does not use. Therefore my comment was not a solution to your issue so I edited my post and deleted it due to it not being relevant to the OS you were using.
Gear:
Ralpho
Feb 15, 2011 08:54 |  #5
Sdiver2489 wrote in post #11847013 (external link)
Thanks for the explanation.
tzalman
Fatal attraction.
Feb 15, 2011 09:01 |  #6
I would try downloading and installing the newer version (3.9) after removing the present installation. If the updater asks for proof of possession of an earlier version, it should be enough to simply put the CD in the drive.
Elie / אלי
René ­ Damkot
Feb 15, 2011 09:46 |  #7
Or you could try to manually thrash the .plist file. It should then create a new one when you restart DPP.
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
Ralpho
Feb 15, 2011 10:50 |  #8
René Damkot wrote in post #11847335 (external link)
How does one go about manually thrashing the .plist file?
Ben ­ Daniels
Feb 15, 2011 10:56 as a reply to  @ Ralpho's post |  #9
What us the latest version for PC?
I have 3.4.1.1
If there is a more up to date version, is it on the Canon site?
5DMK2 w/Grip: 40D w/Grip: Canon D60: 100mm F2.8 Macro USM : EF17-35mm F2.8
L : EF70-200mm f4L IS : Canon 1.4x Converter II : BG-E2 grip :TC420EX : Tamrac Ex5 bag :Manfrotto 055XPROB:Lee Filter System
tzalman
Fatal attraction.
Feb 15, 2011 11:42 |  #10
Ben Daniels wrote in post #11847726 (external link)
I have 3.4.1.1
http://software.canon-europe.com/products/00​10911.asp (external link)
V. 3.9.3
Put in your OS and language, click Submit, item #3 on the list.
Elie / אלי
Ben ­ Daniels
Feb 15, 2011 16:10 |  #11
tzalman wrote in post #11847979 (external link)
V. 3.9.3
Thanks for the link.
Actually I needed #18 in the list.
# 3 is for the 60D manual :)
René ­ Damkot
Feb 16, 2011 11:34 |  #12
Ralpho wrote in post #11847687 (external link)
Find it, select it, Cmd+backspace (or just drag to trash)
http://www.fredmiranda​.com/forum/topic/81130​6 (external link)
2,857 views & 0 likes for this thread, 5 members have posted to it.
DPP problem
1206 guests, 128 members online
