Thread started 15 Feb 2011 (Tuesday) 09:53
Arca Swiss P0?
jacobsen1
Feb 15, 2011 09:53 |  #1
anyone have one of these yet?
http://www.bhphotovide​o.com …ball_P0_with_Pa​nning.html (external link)
IMAGE: http://www.bhphotovideo.com/images/largeimages/658802.jpg
$228 w/o clamp
Height 2.91" (74mm)
Maximum Diameter 2.36" (60mm)
Maximum Load 44.09 lb (20 kg)
Weight 9.9 oz (280.66 g)
the aspect of it that I really like is that there are no knobs really. That silver ring is the only knob on the head for locking the ball and because it's a ring it's always accessible? I like that a lot honestly. I actually wish it did NOT have the panning base on it as it'd then be even lighter and have only the one ring to use, but the functionality is nice I suppose.
For the price I'm tempted...
here's a video of it: http://www.youtube.com​/watch?v=wP24yVv6on0 (external link)
My Gear List
my sites:
benjacobsenphoto.com (external link) | newschoolofphotography​.com (external link)
GND buyers FAQ
FOR SALE: 5Dii RRS L-bracket, 430II, 12mm macro tube PM ME!
cacawcacaw
Feb 15, 2011 10:37 |  #2
That looks sweet!
I like the ring tightener, particularly because it applies even pressure to the ball but I'm trying to figure out the implications of the lower rotating point. Just thinking out loud, if the pivot point is further from the camera, to reach a given angle, the camera has to move further along a bigger arc. Sounds like it would smoother and easier to make adjustments to the camera angle. I think I would like this design better than a conventional ball head.
The price for a complete system is higher, though. Amazon has the Monoball with Quick Release for $289 (external link)but the special Quick Release Plate (external link) is another $48.
At $228, it sounds pretty good (I'm still thinking of the Smith Victor BH8 (external link) at $58 (the price of the Arca QR plate!) or the Vanguard SBH-300 (external link) for $100 as two less expensive alternatives. I still can't wrap my head around the idea that I need an $800 tripod setup but I am headed in that direction.
Replacing my Canon 7D, Tokina 12-24mm, Canon 17-55mm, Sigma 30mm f/1.4, 85mm f/1.4, and 150-500mm with a Panasonic Lumix FZ1000. I still have the 17-55 and the 30 available for sale.
jacobsen1
Feb 15, 2011 12:01 |  #3
well, it's $228 for this -vs- $290 for the acratech GV2 I already have. Both were sold w/o clamps...
My Gear List
my sites:
GND buyers FAQ
GeneC
Feb 15, 2011 14:23 |  #4
I tried one and really didn't care for it. However I did buy it used but it appeared to be in perfect condition. My main dislike was the fact that it had an annoying amount of rotational play in the mechanism, a degree maybe or even less but annoying. I questioned the original owner about the play, he agreed that the play was there and that he always applied slight pressure to one side to eliminate it. My other dislike was that it was difficult to get under your gear to release tension and when you did it was often hard to keep the camera upright not having 2 hands. Long story short, it wasn't for me. Maybe the play wasn't supposed to be there but the fact that it was turned me off. Whether this is a characteristic of this BH, I wouldn't know. I would think not considering the great reputation enjoyed by ARCA SWISS.
Gene
Canon 5D3 with lenses, Sony A7r with lenses, Nikon D810 with lenses. Olympus EP-5 with lenses, Gitzo, RRS Markins and Acratech.
cacawcacaw
Feb 15, 2011 17:08 as a reply to  @ GeneC's post |  #5
Thanks Gene, great information - you just saved me $225. At least until I get tired of the bargain ball head I'm going to order.
jacobsen1
Feb 15, 2011 17:18 |  #6
cacawcacaw wrote in post #11850040 (external link)
Thanks Gene, great information.
+1
except now I'm more curious to try one.... :confused:
My Gear List
my sites:
GND buyers FAQ
GeneC
Feb 15, 2011 18:04 |  #7
Another thing I didn't like about it. When you relax tension with the locking ring, it doesn't release immediately, you have to turn it like almost a turn for full release. It releases gradually. The feel of the ring is such that it feels like there are small gears inside, like a planatary gear system. It's not smooth at all and just felt like it lacks refinement.
Gene
Mike ­ K
Joined Apr 2001
Feb 15, 2011 19:30 |  #8
jacobsen1 wrote in post #11847368 (external link)
I tried one out at B&H. As the picture shows its quite compact and light. With the ballhead unloaded I wish it moved a bit more smoothly. This characteristic was also commented upon by a few Adorama customers. Perhaps I needed to unscrew the main tension more. That ring controlling the main tension could have been made wider, there is not a lot to grip on to. I was not at all attracted to the siderail clamp that it normally ships with. I have really come to like the RRS lever clamp.
If compactness and light were the priority, I think I might be more attracted to this ballhead as its a innovative design. Perhaps the larger P1 would be more my cup of tea.
Mike K
Canon 6D, 1DmkII, IR modified 5DII with lots of Canon L, TSE and Zeiss ZE lenses
jacobsen1
Feb 16, 2011 08:27 |  #9
GeneC wrote in post #11850433 (external link)
Gene
right, but that's part of the idea that I like? Instead of 2 knobs on a normal ballhead, one for the drag and one for the release, this combines both into one no? So release it a little and it moves but not freely, release it a lot and it's loose?
but again, that's why I need to see one IRL to see if I'd like it myself... I like my acratech GV2 a lot and it's light, but this is smaller/lighter w/o decreasing the load and it's removed all but ONE knob form the head. I can't tell you how often I setup my head aimed the wrong way and end up blindly feeling for the knobs in the dark... Yes I can rotate it to fix that, but having the only knob be 360ยบ around the head might be a better solution for me.
Mike K wrote in post #11850921 (external link)
yeah, that's also a concern with me, how easy would this be to grab in the cold with gloves on? Does it need a lot of pressure to rotate when loaded?
exactly, but that's why I'm all over the $230 option, I'd put my RRS lever clamp (that's on my GV2) on this in a heartbeat. I DO NOT LIKE KNOBS!!!! :lol:
this is my current setup:
IMAGE: http://www.benjacobsenphoto.com/blog/wp-content/gallery/canon-100-400l/img_2373.jpg
only on a taller set of induros now..
My Gear List
my sites:
GND buyers FAQ
GeneC
Feb 16, 2011 10:21 |  #10
Well, I admit, the concept is good, my argument is with the excecution and lack of refinement. For one, you loosen the ring a little and not much happens. That's why I mentioned that the ring needs to be loosened a lot before it is loose unlike most any other BH. It doesn't have a tactile feel like you are in control. How hard will it be to loosen the ring in the winter with gloves? I'd say, hard. Also, you do realize that there is no drop notch right?
I would say give it a go, who knows, it might be your cup of tea. What I have said is all based on my personal feelings, my comparisons are based on what I now use which is an Arca Z1 and Markins M10.
jacobsen1
Feb 16, 2011 11:39 |  #11
GeneC wrote in post #11854452 (external link)
but there is one drop notch?
not that it matters though, I'm an L-bracket guy? (I do use the notch very rarely when shooting at a very odd angle...)
as you said on the amount of turns to loosen it, I'd agree, but I'd also have to see for myself how much turning gets you what results. That's why I'm so interested. There's probably a 50/50 chance that I'll either agree with you and like the concept but hate the implementation, or that I'll actually like it... :lol:
My Gear List
my sites:
GND buyers FAQ
GeneC
Feb 16, 2011 13:23 |  #12
Nope, not even one, it's dropnotchless. As I recall the tilt was less than 45 degrees but I could be wrong there. You are definitely going to need your L bracket.
It's not actually turns to loosen it, just a lot more than typical. The feel in mine anyway was far from nice. You'll have to try it, it may be just right for your needs. I guess it depends on what you are used to as well. For me it was a wierd duck!
jacobsen1
Feb 16, 2011 16:27 |  #13
it definitely has a drop notch:
IMAGE: http://www.bhphotovideo.com/images/multiple_images/item_images/IMG_132207.jpg
IMAGE: http://www.bhphotovideo.com/images/multiple_images/item_images/IMG_132208.jpg
you just have to remember that the entire thing is basically upside down as well. ;)
My Gear List
my sites:
GND buyers FAQ
GeneC
Feb 16, 2011 16:40 |  #14
I know, but I had one to play with for 3 days. Oh well it's been 6 months:cool::lol:
jacobsen1
Nov 11, 2011 20:36 |  #15
OK, so I bought one and got it this week. I've got it mounted up with my RRS lever clamp. Used it for the first time tonight and so far I like it a lot. I've got to learn which way is tight -vs- loose (from sailing, shrouds are backwards there, so it's just an issue from dealing with that a lot in the summer for me) but otherwise I LOVE having just one knob. I'll be keeping my acratech GV2 for a long time though since I also like it, but so far the P0 is a very nice option. It's .05lb light (both w/o a clamp, .70 -vs- .75). The way the knob/dial works, is from full loose it's around 1/3 of a turn to be tight enough to hold a 5Dii w/17-40 and filters, but you have a full turn until you can't go anymore. So as I use it more if I get to trust it it'll be SUPER fast, but right now I'm tightening all the way. I love the way my hand naturally cradles the whole thing as I adjust it though, and no more fussing with where the knobs are. :)
My Gear List
my sites:
GND buyers FAQ
26,362 views & 0 likes for this thread, 16 members have posted to it.
Arca Swiss P0?
973 guests, 107 members online
