Thread started 21 Sep 2005 (Wednesday) 00:23
Hyperfocal settings for the S2 IS???
dcains
Sep 21, 2005 00:23 |  #1
Hi Group:
Anyone know offhand the hyperfocal settings for the S2 IS? TIA.
Regards,
Dean
Lutz, FL
G6, G5, S410, S2
dcains
Sep 21, 2005 15:42 |  #2
I just got around to doing the math myself. With the focal length set to 6mm (effective), an aperture of f5.6, and a manual focus set to 5', that gives a DOF starting at just over 2 feet from the camera and extending into infinity. Not something I use very often, but it's nice to have available as an option.
Curtis ­ N
Master Flasher
Sep 21, 2005 15:56 as a reply to  @ dcains's post |  #3
Hold on there!
"Effective" focal length is a dubious term, useful only for comparing small format cameras to 35mm film in terms of field of view. Using a fictitious number to calculate DOF doesn't work.
Or did you mean 6mm actual focal length?
dcains
Sep 21, 2005 17:17 as a reply to  @ Curtis N's post |  #4
Hi Curtis:
You're correct, you caught my error. I meant to say "actual", not "effective". The settings I came up with are correct, though, and I spent a little while testing them when the sun peeked out for a few minutes today. Thanks.
quietman
Sep 21, 2005 19:32 as a reply to  @ dcains's post |  #5
I'm very interested.
What are you guys talking about...
...and how can I use it?
thanks!
John Roe
www.roenation.com (external link)
Curtis ­ N
Master Flasher
Sep 21, 2005 20:32 |  #6
Hyperfocal distance is the distance at which everything from half that distance to infinity will be in acceptably sharp focus. It's a concept related to depth-of-field, and is determined by the lens focal length, the aperture setting, and a somewhat subjective variable called the "circle of confusion" which is related to the magnification of the image required to create a print of a certain size.
You can learn more about hyperfocal distance and depth-of-field here (external link).
Here is an Excel file (external link)you can download to creat depth-of-field tables and other neat stuff.
1,717 views & 0 likes for this thread, 3 members have posted to it.
1424 guests, 126 members online
