Thread started 15 Feb 2011 (Tuesday) 23:35
My first in Lightroom 3. C&C please
StayLucky
Feb 15, 2011 23:35 |  #1
My fiance is a teacher at two local high schools and one of the schools she teaches at is offering a digital media class from now until april 10th. For taking it she gets a free copy of lightroom 3, PS elements, and a digital camera that takes stills and video.
I installed LR tonight and went straight to work playing in it. I took this pic she took of her car and toyed with it.
Before
DSC_0401 (external link) by derek.m.fulmer (external link), on Flickr
After
DSC_0401-1 (external link) by derek.m.fulmer (external link), on Flickr
avinersan
Feb 16, 2011 07:25 |  #2
you just alterd the wb ?
original is more correct then the edit..
the wb is incorrect , highlights look more blown out because of the colors (probably)
recommend some tutorials before actually editing pictures
just my 2 cents
StayLucky
Feb 16, 2011 12:05 |  #3
WB, and other really minor adjustments. I definitely don't this particular edit seriously at all as I was just playing with the software trying to get acclimated with it somewhat. I liked what came out of it and wanted some advice. Thanks for yours .
cacawcacaw
Feb 16, 2011 12:37 as a reply to  @ StayLucky's post |  #4
I like what you were going for with the blue in the upper left corner. Perhaps a blue gradient in that corner would have given you a similar effect while maintaining the original white balance for the rest of the image.
Have you discovered the white balance eyedropper tool yet. So nice, you can move the eyedropper around the photo and see the effects on white balance in the small preview window. One of my favorite features.
There are zillions of tutorial videos our there. The more you learn, the more you'll realize how much there is to learn.
Replacing my Canon 7D, Tokina 12-24mm, Canon 17-55mm, Sigma 30mm f/1.4, 85mm f/1.4, and 150-500mm with a Panasonic Lumix FZ1000. I still have the 17-55 and the 30 available for sale.
TheLostVertex
Feb 16, 2011 12:59 |  #5
I see some color noise that you should be able to get rid of pretty easily in the detail tab. Whenever you push a file to a higher exposure, remember that you will introduce more noise into the image and you may have to compensate for that. I dont mind the shift the the bluer tone, it adds more of a mood, as an off white balance often does. That said, you went slightly too far I think, and id pull it back a little bit. It looks like the highlights on the car are being blown out, which is fairly unattractive in this particular case. You can try and use the recovery slider under the basic tab to bring back some lost detail. You can also use the tone curve to reduce unwanted highlights.
I see crude on the tire, which you can remove with the spot removal tool. Same with whats on the ground by the tire. Remember there are 2 modes with the spot tool, healing and clone. Switch between them and use what ever works best. When ever i work with the spot removal tool I make sure is display mode is set on auto(from the default always). You can check to make sure in the tool bar under the photo, if that tool bar isnt there press T and it will show up. When its on auto you can move your cursor out of the image area and get a quick idea of what everything looks like without the spot overlays. Good for checking for seams.
Steven R.
500px (external link)
StayLucky
Feb 16, 2011 12:59 |  #6
cacawcacaw wrote in post #11855295 (external link)
I really wanted a more "blue" look over all so I changed that with the temperature slider.
Found the videos in the Lightroom sticky on Adobe.com, truly a wealth of info.
elogical
Feb 16, 2011 17:14 |  #7
StayLucky wrote in post #11855414 (external link)
Nothing wrong with using a "creatively incorrect" white balance so long as you realize what you're doing and don't end up doing that inadvertently where it doesn't work.
Enjoy playing around with it, it's a lot of fun just experimenting with things in lightroom while you're getting to know it. Tutorials are very necessary, but I also found it quite helpful to just open a picture up and go through all the settings one at a time and move the sliders around to watch the effect everything has.
Gear
freebird
Feb 16, 2011 20:07 as a reply to  @ elogical's post |  #8
Practice practice practice.........creat​ive minds are all start somewhere.
Have fun with it:)
879 views & 0 likes for this thread, 6 members have posted to it.
2862 guests, 161 members online
