Hi folks,
I only joined POTN a couple days ago, but I thought it was time to contribute something besides just replying to other threads.
Seeing a lot of requests for sample shots with the Extender 2x III, I decided to post the results of a recent comparison between that and the Kenko Pro 2x DGX on the 70-200mm f/2.8L IS II. While I was at it, I decided to test every combination of these three plus the 100-400mm f/4.5-5.6L IS (eight combinations in all).
Since the forum image size limit is too small (each crop below is 800x800 at full size), I'm just going to link to my Flickr post, which has more detail about the test. Please read about the test setup before raising any objections - I controlled for many variables, but I can only do so much with the time, space, and equipment available. And before you ask: yes, I did test the corners too, but the test was inconclusive - i.e., I was seeing some inconsistencies that I could not eliminate experimental error as an explanation for.
To sum up a few image-quality observations from the linked Flickr posts:
- The Kenko resolves more than the Canon TC.
- The Canon TC has better contrast and color than the Kenko.
- A single 2x TC beats upsampling the bare lens.
- Stacked 2x TCs resolve more than upsampled single 2x TCs, but not by much, and at the cost of further deterioration of color and contrast (not to mention 2 stops).
- My pick of the litter is 100-400 + 2x III, because I value contrast more than resolution - although I can easily see the case for the 100-400 + 2x DGX too. Then again, I rarely shoot manual-focus at 800mm f/11, so this is a largely theoretical preference.
- As for 70-200II+2xIII vs. 100-400, the latter clearly holds the image quality edge at f/5.6 and a slight edge at f/8 (also true in practice, where the loss of contrast with the TC is more painful than the lowish resolution).
Having said that, I'm leaning towards keeping the 2x III, purely for practical reasons. I don't see myself ever carrying both the 70-200 and 100-400 anywhere, so if it's a choice between somewhat reduced image quality and AF speed at 200-400mm and somewhat greater weight and bulk versus the loss of 70-100mm, shallow DoF capability, low-light capability, and every other advantage of the 70-200 within its native range... well, it's a tough call. And yes, I realize I'm lucky to have the choice to make.
eight ways to reach
