FORUMS Post Processing, Marketing & Presenting Photos Presentation & Building Galleries
Thread started 18 Feb 2011 (Friday) 19:22
Need blog help...
SnapsbyPoteat
Feb 18, 2011 19:22 |  #1
Hi!
I've been messing around with a wordpress blog and seem to have messed something up.
here is the address: www.snapsbypoteat.com/​playground (external link)
as you can see the flashfader is shifted to the left and the content is super wide! I only want the entire column to be as wide as the flashfader.
I imported content from my current blog which is why you see posts on it. It's not anywhere near close to being public yet. I've just been messing with different sized in the css editing and can't figure out what is causing this! My column width is set to 1000 and this is showing it a lot wider!
Help! :)
Gear list: Canon 5D Mk II, 7D tokina 11-16/2.8, Sigma 30 1.4 , Canon 50 1.2 L, 85 1.8,100 2.8 L macro, 580ex,
www.snapsbypoteat.com (external link) . Facebook Page (external link)The Blog (external link)
The wedding page www.melaniepoteat.com (external link)
SnapsbyPoteat
Feb 19, 2011 00:12 |  #2
hmmm no suggestions..... ? bummer.
ShotByTom
Gallery: 23 photos
Feb 20, 2011 20:03 |  #3
Sorry I can't help, but I thought it looked fine!
If you'e using wordpress, you might look HERE (external link) for some help, they really helped me get started!
Gear
Website (external link)
Grumbledook
Feb 21, 2011 10:40 |  #4
not sure what it is meant to look like, should there be a side bar down the right hand side?
I think you may be better off just installing a theme and customising that slightly, I would also use a javascript slider rather than that flash one (fade is just one transition on what is more commonly called a slider)
one example (there are hundreds of sliders out there, I don't necessarily mean use this one, it was just the first one I found to link, a lot of good themes will have one built in which may differ slightly) with some good demos (11 different transitions) http://nivo.dev7studio​s.com/demos/ (external link) the bottom one uses random ones so enough changes you should see them all
there are some very good ones on themeforest for ~$20 - $40
mosabi
Apr 23, 2011 09:20 |  #5
SnapsbyPoteat wrote in post #11871807 (external link)
I'm no pro but give this a shot. If you look in your HTML of the page look for width="1000": Try changing that to like 2000.
<div id="slideshow"> <object type="application/x-shockwave-flash" data="http://snapsbypo​teat.com/playground/wp​-content/plugins/flashf​ader.swf" width="1000" height="400"><param name="bgcolor" value="#ffffff" /><param name="movie" value="http://snapsbyp​oteat.com/playground/w​p-content/plugins/flashf​ader.swf" /><param name="FlashVars" value="path2xml=http:/​/snapsbypoteat.com/pla​yground/wp-content/flashfader/ima​ges.xml" /><param name="quality" value="high" /></object> </div>
This may result in stretched images maybe not. See what it looks like and go from there. I am just starting my own blog on blogspot so I feel your pain. Best of luck to you.
http://nickluchau.blog​spot.com (external link)
Website:
www.nickluchau.zenfoli​o.com (external link)
40Dx2 gripped | 17-55 f/2.8 | 50 f/1.8 mk1 | 430ex II
1,116 views & 0 likes for this thread, 4 members have posted to it.
Need blog help...
1127 guests, 111 members online
