Thread started 22 Sep 2005 (Thursday) 00:55
Challenge : Perspective correction
yb98
Joined Feb 2003
Sep 22, 2005 00:55 |  #1
I was in the car when I took this pic. Can you correct the perspective and explain how you did ? Thanks.
Best DPP Threads
DPP++ Video Channel (external link)
New Version DPP++ 11.3 released (external link)
Scottes
Trigger Man - POTN Retired
Joined Nov 2003
Sep 22, 2005 07:07 |  #2
I can't do it right now - I'm in work - but I would select the entre image with the Marquee, then increase the size of the canvas substantially, then click on Edit... Transform... Skew. Grab the handle in the top right corner and move it away from the center of the shot. The Transform selection (marching ants) will look like a parallelogram now. Basically just pull the handle until the tower is stright. Hopefully then the opposite side will also be straight. If not, Edit... Transform... Something...
When you're happy with the straightening just crop the excess.
(Somebody correct me if I'm wrong about the Transform choices... But I think I'm right....)
You can take my 100-400 L away when you pry it from my cold, dead fingers.
Scottes' Rum Pages - Rum Reviews And Info (external link)
Follower of Fidget - Joined the cult of HAMSTTR©
foobar
Sep 22, 2005 14:45 as a reply to  @ Scottes's post |  #3
SPAM PUT AWAY
This post is marked as spam.
bthurlow
Sep 28, 2005 22:52 as a reply to  @ foobar's post |  #4
Here's my take on it. This was all done in the PS 9 crop tool with the perspective box checked. The first thing I did was straighten the photo to square off the verticals in the photo (also with the crop tool).
-BKT
20D, 1N
Wishlist: more time to shoot!
Moppie
Moderator
Gallery: 24 photos
Joined Sep 2004
Sep 28, 2005 23:40 |  #5
I did this for a photo of a door for our works website (don't ask, its not your normal door).
As every one suggest, use the Skew Transform, however, first turn on the Grid, it will make getting everything straight much easier ;)
You can also play with the center spot in the transform grip, it alters the centre point of the transform, in this case maybe move it towards the tower?
Have you Calibrated your Monkey lately?
Now more than ever we need to be a community, working together and for each other, as photographers, as lovers of photography and as members of POTN.
Moppie
Moderator
Gallery: 24 photos
Joined Sep 2004
Sep 28, 2005 23:54 |  #6
Open image
Layers box, double click background layer to creat duplicate layer
View-Show-Grid
Edit-Transform-Skew
Move the centre point to the bottom centre of image
Move the top left and right corners around till you find an angle that looks good.
You might also have to move the bottom corners in a little to get it looking just right, and even have a play with moving them up and down outside the image box.
Then
Layers-Flatten image.
Crop to make it square again and save.
I had a play, but couldn't do anything better than whats been done above, just thought you might like some easy to follow directions.
yb98
Joined Feb 2003
Sep 29, 2005 11:17 as a reply to  @ Moppie's post |  #7
Thanks, nice work everyone.
Best DPP Threads
2,268 views & 0 likes for this thread, 5 members have posted to it.
899 guests, 120 members online
