Thread started 19 Feb 2011 (Saturday) 20:07
Off camera flash. What do i need?
LOKPhotography
Feb 19, 2011 20:07 |  #1
I have a 1000D and a 430EX II and all i need is a transceiver for the shoe on my camera right? The flash has the wireless built into it. What would you recommend?
60D Gripped, 1000d Gripped, 70-200L f4 USM, 50mm f1.8 "Nifty Fifty" (R.I.Pieces), Sigma 50mm Macro f2.8, Tokina 12-24 f4, 430EX II, Cactus V5's, PS CS5, Lightroom 3, BR RS7 Strap.
QueenChatty
Feb 19, 2011 20:16 |  #2
That depends on if you want to be wired or if you want the wireless operation.
You need both the transceiver and receiver to go wireless. If you want to go the cheaper route via sync cord is the way to start.
5D MarkII | 50D Canon 17-40mm|55-250 | 60mm Macro | 50mm 1.4 | 24-105L IS | 580EXII | 70-200L F2.8 IS II | Ultra Zap 800 |StarFlash 300 X2 | AB 400X 2 Flickr  (external link)
elevenbangbang
Feb 19, 2011 20:16 |  #3
You could either use an ETTL cord or use Canon's ST-E2 wireless transmitter. There are cheaper options but they won't let you use ETTL.
LOKPhotography
Feb 20, 2011 21:24 |  #4
i want wireless. I thought the flash had it built into it?
C.Michael
Feb 20, 2011 21:31 |  #5
LOKPhotography wrote in post #11882011 (external link)
The flash does....to an extent.
It can be used wirelessly with a 7D, 60D or one of the newer cameras with built in flash control. Since you have a 1000D, you will need both a tranceiver (body) and a receiver (flash). I suggest going with a long E-TTL cord.
www.christophermorriso​n.com.au (external link)
Canon 5D Classic w/ grip | 50mm f/1.8 | 85 f/1.8 | 430EX II + YN460II
LOKPhotography
Feb 20, 2011 23:22 |  #6
C.Michael wrote in post #11882052 (external link)
awesome thank you sir. yeah i thought itd work because my buddy was using it with a 7d and didnt hook anything up to it. I figured if i had something on my camera to send the signal out id be ok. I guess ill get a cord then. thanks
wunhang
Feb 21, 2011 13:32 |  #7
LOKPhotography wrote in post #11882527 (external link)
If you want to what your friend was doing with the 7D, you can get the Canon ST-E2 and have the same function. Of course, it really depends on what capabilities you want. If you just want the ability to have the flash fire, cheap radio triggers could do it. If you need communication between the flash and camera to get the right amount of flash (E-TTL), then it starts getting expensive (ST-E2, or E-TTL capable radio triggers) or cumbersome (long wires)
Canon 5D IV | Canon 5D II | XSI (Infrared modified) | SL1 | 16-35mm L f/4.0 IS | 24-70mm L f/2.8 II | 40mm f/2.8 | 85mm f/1.8 | 70-200mm L f/4.0 IS | Rokinon 14mm f/2.8 | C/Y 28mm f/2.8 | Tamron 35mm f/1.8 VC | C/Y 50mm f/1.7 | Zeiss 100mm MP
::SmugMug (external link)::
Gizmo1137
Feb 21, 2011 13:41 as a reply to  @ wunhang's post |  #8
Also depends on what "off camera" means to you? Are you just wanting to relocate the flash off the hot shoe, in which case a flash bracket and the cable already mentioned is what's required. Or are you wanting to mount the flash on a stand, monopod etc. for more flexibility, in which case wireless would offer the most flexibility.
Best, Bruce
LOKPhotography
Apr 14, 2011 09:41 |  #9
i was thinking about getting this for now for a learning experience with lighting. Not worried about ETTL use right now. Ill be getting a 7d this fall so i wont need these. this is just for practice.
http://www.bhphotovide​o.com …_AC_16_Channel_​Radio.html (external link)
LOKPhotography
Apr 14, 2011 09:45 |  #10
These look kind of ghetto but its just for practice.
http://cgi.ebay.com …ain_0&hash=item​588b121a17 (external link)
wunhang
Apr 14, 2011 15:14 |  #11
You won't have any sort of ETTL capability with these - It will basically be "camera tells transmitter to flash, transmitter tells flash to flash". You'll have to use manual settings on your 430ex.
1,258 views & 0 likes for this thread, 6 members have posted to it.
2759 guests, 145 members online
