Thread started 21 Feb 2011 (Monday) 10:43
Ranger rx was having seizures???
suecassidy
Feb 21, 2011 10:43 |  #1
I was shooting marketing pics yesterday and my strobe head started firing in short bursts continously. I unplugged it and plugged it in, again bam*bam*bam*bam, it would do it again. Turned on and off, plugged into different socket on pack, same thing. The thing was possessed by the lighting devil, I swear it. Eventually, it stopped that nonsense, but what was THAT about? Any ideas?
Sue Cassidy
GEAR: Canon 1ds, Canon 1d Mark iii, Sony RX 100, Canon 50mmL 1.2, Canon 70-200L 2.8 IS, Canon 100-400L IS, Canon 14mm L, 2.8, . Lighting: Elinchrom Rangers, D-lite 400s, Canon 580/550 flashes. 74 ' Octabank, 27' Rotalux. Editing: Aperture 3
Mike ­ Panic
Joined Jan 2005
Feb 21, 2011 10:51 |  #2
What kind of triggers do you use, and how is the battery in them?
MikePanic.com (external link) photography | web design | social media | content creation
CripsyHundos.com (external link) instagram photos for your viewing pleasure
PacAce
Joined Feb 2003
Feb 21, 2011 11:01 |  #3
suecassidy wrote in post #11884775 (external link)
I had that happen to me the first time I ever used my Ranger RX. I was using the head with an umbrella. Were you using an umbrella also? If so, check to see if the pigtail wire that wraps around the flash tube is hanging away from the tube and making contact with the umbrella shaft. If it is, just wrap the pigtail wire around the flash tube, so that it's not hanging free, and away from the umbrella shaft.
If the above isn't your problem, then may I suggest calling a local Catholic church to see if they do exorcisms. :D :lol: ;)
...Leo
suecassidy
Feb 21, 2011 12:03 |  #4
I was using skyport triggers, and a fresh battery in that. That's a valid point to trouble shoot in the future though, for sure. The head was in a big ass octabank and it never occurred to me to take the cover off and see if anything was wonky there. PaceAce, the last exorcism done by my local Catholic Church was done on ME, they won't talk to me. ; )
Sue Cassidy
Wilt
Feb 21, 2011 12:15 |  #5
Too much rigamarole to get exorcism performed...eat a head of garlic next time!
PacAce
Joined Feb 2003
Feb 21, 2011 12:57 |  #6
suecassidy wrote in post #11885256 (external link)
You might want to check the pigtail wire anyway to make sure it's not dangling free. That's the wire that triggers the flash and if it's shorted to ground, it'll set the flash off. The flash tube is close enough to the metal built-in reflector that the wire could be touching that instead.
...Leo
bobbyz
Feb 21, 2011 16:23 |  #7
Seems like very poor design if what Leo is saying is the case.
Fuji XT-1, 18-55mm
Cathpah
Feb 21, 2011 17:27 |  #8
bobbyz wrote in post #11886935 (external link)
Given it happens pretty rarely (I've only heard of it a few times, and own a couple rangers myself), I don't know if this qualifies as poor design. Moreso just a bit of bad luck.
Architecture (external link) | Fashion + Beauty (external link) | Travel (external link) | Mayhem (external link) | Instagram (external link)
tools of the trade
My name is Jeff, and I'm addicted to shadows in fashion and brights in architecture. "Hiiiiii Jeff."
bobbyz
Feb 21, 2011 18:43 |  #9
Cathpah wrote in post #11887309 (external link)
If there is wire which can touch the umbrella shaft and make the strobe go haywire, I say poor design even if it happens once in a while. There will be bunch of regular jumping up/down if it was AB strobe instead of Elinchrom:D
Fuji XT-1, 18-55mm
PacAce
Joined Feb 2003
Feb 21, 2011 19:31 |  #10
bobbyz wrote in post #11887771 (external link)
It's not poor design, Bobby. It's just that Elinchrom, for some reason, decided to keep the pigtail longer than other makes do. If you take a look at your AB strobes, you'll see the same kind of pigtails, too. Except they're cut shorter.
...Leo
Semmonka
Feb 22, 2011 00:51 |  #11
Make also sure that photocell is turned off. Sometimes when bright light hits the photocell it makes
the unit fire. Never heard of bursts but its worth checking imo
Vesa
"Opinions are like a$$holes, everybody has one"
Flick (external link)r (external link) | MM (external link)
Hermes
Feb 22, 2011 04:50 |  #12
PacAce wrote in post #11888096 (external link)
I've always found that his wire touching an umbrella shaft will stop the strobe firing altogether. It's also always been the retaining clip for me, never the actual wire.
Could be better designed but their goal was obviously to get the umbrella mount as central as possible bringing it in close proximity to the tube. If the clip rotates out of place or is left a little too long it can short the head in a pretty baffling way. Fortunately trimming a couple of mm off with a wire cutter is a 2 second job.
In this case, I'd be more inclined to think it was something to do with the triggering. A sync cable not fully in the socket can produce this effect. A dodgy test button or radio interference could also do it. All have simple solutions if you can narrow it down to the right one.
PacAce
Joined Feb 2003
Feb 22, 2011 07:08 |  #13
Hermes wrote in post #11890473 (external link)
Can you explain what you mean by the retaining clip. I didn't see anything on either Freelite heads near the umbrella shaft (or the whole front face of the head, for that matter) that looks like it could be called a retaining clip.
...Leo
uyarchie
Feb 22, 2011 07:26 |  #14
Semmonka wrote in post #11889872 (external link)
+1. I had seizures with mine as well. lol.
Hermes
Feb 22, 2011 12:32 |  #15
PacAce wrote in post #11890794 (external link)
Don't know about the freelite heads but on the RXs there is a thicker wire that wraps around the flashtube just above the umbrella mount to hold down the thinner flashtube wire, Not really a clip but it does the same job.
2,625 views & 0 likes for this thread, 10 members have posted to it.
1684 guests, 140 members online
