Hey guys, have been shooting with a Canon 5Dmk2 and curious if anyone has insight on a certain issue. Interested to see if anyone has any thoughts / or can tell me what causes this issue ?? At first I assumed it was jpeg compression just not being able to make smooth gradients which I noticed a while back when shooting sunsets (wasnt using RAW at the time) - the compression would occur in gradual color gradients appearing as bands..
However after seeing the same banding in RAW images today - I am not sure what to think...
Firstly all of these images have been resized and resaved in photoshop - so there is quality loss compared to the original files - however due to re-compression the issue I am investigating should become more obvious - The issue is on all these shots, both original out of camera JPEG's and original CR2 raw files - both exhibit forms of this banding - the JPEGs compression making it incredibly more obvious.
Resized Original Sunset photo (taken as JPEGS) : Canon 5Dmk2 - 24-70mm 2.8:
![]() | HTTP response: NOT FOUND | MIME changed to 'image/gif' | Redirected to error image by FLICKR |
Same shot with mid levels tweaked to illustrate the banding better:
Resized Testshots: The 50mm shots are quite subtle - but if you look you can notice the color banding as the light dissipates on the wall.
Canon 5Dmk2 + 50mm - CR2 raw - resized then saved as JPEG.
Canon 5Dmk2 + 50mm - resized JPEG straight out of camera
Canon 5Dmk2 + 21mm Zeiss - CR2 raw - resized then saved as JPEG.
Canon 5Dmk2 + 21mm Zeiss - resized then saved as JPEG.
As you can see in the right circumstances it appears to be quite noticeable - Still learning this camera and if this is something obvious in workflow - or settings I should check please let me know.Just to make sure people understand - the light colored banding / banding you see IS present when viewing the actual RAW file in LR and Photoshop.
