Since getting the Chimera Quick Release speed ring and Chimera 54" x 72" softbox I've had many people ask me about the speed ring and how it works, so I decided to show some images of the ring in action.
My overall impression of the Quick Ring is that I like it a lot. It's very different from the Bowens Quick Release but accomplishes the same thing.
This first image shows the rod from the large Chimera softbox. It's pretty obvious that the rod is very different from the rods we're used to seeing in lightboxes.
The tip is inserted into one of the rod mounts and a brass set screw is tightened to hold the rod in place. This is actually pretty important with the large softbox. Its size makes it a bit unwieldy and just handing the assembly can easily cause the rods to come out and flop around if they weren't locked into the rod mount. I've also shown one of the rods folded down and locked into position.
![]() | HTTP response: NOT FOUND | MIME changed to 'image/gif' | Redirected to error image by FLICKR |
This second set of images shows all four rods installed and the ring is floating on top of them in a completely unlocked state with no tension.
Here you can see the ring with all 4 rods locked in position. The big difference between the Chimera Quick Release and the Bowens Quick Ring is the method of assembly and disassembly. With the Bowens Quick Ring you insert all 4 rods with no tension and then one corner is lifted into position, creating all the tension and locking in place. When you disassemble, you press the release lever, that one corner releases and the box can be collapsed.
The Chimera Quick Release has a lock and release in each corner, independent of each other. Releasing one does not release the others or the rest of the tension.
When assembling the box you work your way around and lock them in place one by one. Actually, once you lock the first two you can easily just press down on the center of the ring and the other two snap into place and lock. There is a black release lever on each mount and the way you release it is by applying a small amount of pressure to that corner of the ring and then you just pull back on the lever. Release the remaining three mounts and the box collapses.
The final image in this set shows an Elinchrom 600RX mounted to the speed ring.
And finally, these last two images show the softbox assembled on the Quick Release and then mounted to an Elinchrom 600RX. Despite the fact that the shots are head on you can still see how far forward the rear deflector and flash tube are in the Chimera insert.
