Thread started 25 Feb 2011 (Friday) 04:10
Off Camera flash options (HELP)
ChewieT
Joined Nov 2010
Feb 25, 2011 04:10 |  #1
Hi, total newbie when it comes to off Camera flash. I have a 430 EXII which I have used on my camera and I have ordered a 580 EXII which is in the post. I want to get into portrait photography so am looking at getting a couple of stands with umbrellas.
My initial intention was to use the 580 on the camera and use it as a master to the 430 on a stand with an umbrella, am I right in thinking then that the system could use E-TTL and set the correct power output for each of the flashes.
While I was looking for stands and umbrellas I came across this
http://www.amazon.co.u​k …TF8&qid=1298628​380&sr=1-1 (external link)
I am assuming that with this setup I could not have a flash on the camera, they would both need to be on stands, am I also right in assuming that I would need to set the power of the flashes manually. Has anybody used this iShoot system ?
I am also looking for a radio remote shutter and was hoping to get a system which could control the flash and the shutter at the same time which I dont think this iShoot gear can do. Any recommendations for something that can, or maybe a decent seperate remote shutter control.
Many thanks
Craig
Gripped Canon 7D | Gripped Canon 50D | EF 70-200mm f/2.8L IS MkII | EF 24-70mm f/2.8L | EF 135mm f/2.0L | EF 24mm f/1.4L II | EF-S 10-22mm f/3.5-4.5 USM | EF-S 18-55mm f/3.5-5.6 IS | EF-S 55-250mm f/4-5.6 IS Lens | 2 x 580EX Mk II | Manfrotto 055CXPRO3 | Manfrotto ball head Midi 498RC2 | Lowepro Flipside 400AW
http://www.tuckshots.c​o.uk (external link)
ChewieT
Joined Nov 2010
Feb 25, 2011 04:18 |  #2
Oh I forgot to add I am also planning on getting a 7D soon. Would this them mean I could use both the 430 and 580 off camera and retain E-TTL
Matthew ­ Patrick
Feb 25, 2011 07:17 |  #3
ChewieT wrote in post #11910726 (external link)
Yes, it would.
ChewieT
Joined Nov 2010
Feb 25, 2011 08:02 |  #4
Another question, If I were to go for this ishoot system, which I am assuming would require the flashes to be set manually, would I then also need a lightmeter. How would I know what power to set the flashes. Thanks.
mizer357
Feb 25, 2011 08:21 |  #5
no experience with the ishoot products you linked to, but they look the same as any simple radio triggering system. you're correct that you'd need to set your flashes manually. i like using a meter, but they're not absolutely necessary. without the meter, i typically lock down my shutter speed at or below x-sync speed and ballpark the aperture, then adjust the aperture accordingly.
ChewieT
Joined Nov 2010
Feb 25, 2011 08:42 |  #6
How do you gauge what power to set each flash to, is it just trial and error. Can you use the camera to give you a meter reading ?. Sorry totally new to this and want some idea of what I will be doing before spending my cash :)
mizer357
Feb 25, 2011 09:23 |  #7
yes, it is trial and error, but, as you go along, you'll see your ballpark guesses get better and better quite quickly :). camera won't help metering the flash in this case. it can help meter ambient light outdoors to give you a working shutter speed, but the aperture, which controls your flash exposure, will still have to be manually dialed in without help from the camera.
697 views & 0 likes for this thread, 3 members have posted to it.
2888 guests, 133 members online
