Thread started 25 Feb 2011 (Friday) 09:51
Picture of Kacey dish with AB strobes
bobbyz
Feb 25, 2011 09:51 |  #1
I am just trying to see how all this fits together. I have dual flahs bracket. Do I remove it and use the AB/WL adapter than Jerry sells to use with his dish?
Would love to see some actual shots of these two together. Jerry's web site is not that informative in this regard. I asked him and he says remove the bracket and use the adapter but there is no picture of the adapter.
Fuji XT-1, 18-55mm
Marloon
Feb 25, 2011 10:59 |  #2
bobbyz wrote in post #11911763 (external link)
It's pretty easy to remove the dual flash bracket and mount the AB adapter.
Remove the thumbscrews that hold the diffusor, and then remove the posts that hold the difussor. Just unscrew the screws off and unmount the adapter. just reverse the process to put it all back together.
I'm MARLON
Former Canon Platinum CPS member
5DII • 24L • 35L • 50L • 85L • 135L • 200LIS
Wordpress Blog (external link)Youtube Channel (external link)Twitter (external link)Gear List (external link)
tetrode
I am a walking repository of thoroughly useless information
Feb 25, 2011 11:17 |  #3
... but there is no picture of the adapter.
Sure there is:
http://www.smugmug.com​/photos/482042801_DHkG​X-XL.jpg (external link)
It's just a flat, 6-1/8" diameter disk with an AB type mounting flange in the center and four holes pre-drilled that conform to the mounting holes in a Kacey (and Speedotron) dish.
Dave F.
bobbyz
Feb 25, 2011 15:00 |  #4
Thanks guys. So that is all I need I guess.
Fuji XT-1, 18-55mm
bobbyz
Mar 01, 2011 15:20 |  #5
One more thing, do I need to get the white diffuser when using AB strobes even if I don't use modelling lights?
Fuji XT-1, 18-55mm
Marloon
Mar 02, 2011 02:18 |  #6
bobbyz wrote in post #11937393 (external link)
Make sure that you get the optional white diffuser. It works quite well in allowing you to use the modeling lights. if you spend that extra 23 dollars, you definitely won't run into the issue of accidentally melting the acrylic diffuser. As always, it's better to have it and not need it than to need it and not have it.
I'm MARLON
bobbyz
Mar 02, 2011 08:38 |  #7
Marloon wrote in post #11940481 (external link)
Thanks.
Fuji XT-1, 18-55mm
AlanU
Gallery: 144 photos
Mar 02, 2011 10:08 |  #8
jerry asked me if I intended on using his BD with strobe. I purchased the metal "plate" to be safe. Its his recommendations anyways.
5Dmkiv |5Dmkiii | 24LmkII | 85 mkII L | | 16-35L mkII | 24-70 f/2.8L mkii| 70-200 f/2.8 ISL mkII| 600EX-RT x2 | 580 EX II x2 | Einstein's
Fuji - gone
Sony 2 x A7iii w/ Sigma MC-11 adapter | GM16-35 f/2.8 | Sigma 24-70 ART | GM70-200 f/2.8 |Sigma Art 24 f/1.4 | Sigma ART 35 f/1.2 | FE85 f/1.8 | Sigma ART 105 f/1.4 | Godox V860iiS & V1S
1,660 views & 0 likes for this thread, 4 members have posted to it.
2864 guests, 132 members online
